【Microchip WBZ451 Curiosity】-6- gpio驱动
GPIO是非常重要的外设,本文以驱动WBZ451的PB7引脚为例,展示基于MPLABX ide MCC图形化配置工具的快速GPIO驱动设计。
WBZ451模块引脚不多,PB7在好奇开发板上连接到是用户LED,比较直观。
1. 从IDE主界面进入MCC:
2. 在PLUGINs下来菜单中,选择“Pin Configuration”,自此进入GPIO编辑界面。
3. 针对PB7,可以自定义引脚名称,设置Function为GPIO,方向为OUT
4. 在项目图中,点击System,展开Ports->Pin Configuration,可以看到步骤3中编辑的条目已经显示出来了。
5. 点击Generate,自动生成代码。
6. 到task.c中新创建一个Task:LED_BLINKY,专门用于点灯。
void SYS_Tasks ( void )
/* Maintain system services */
/* Maintain Device Drivers */
/* Maintain Middleware & Other Libraries */
if (xTaskCreate(BM_Task, "BLE", TASK_BLE_STACK_SIZE, NULL , TASK_BLE_PRIORITY, NULL) != pdPASS)
while (1);
/* Maintain the application's state machine. */
/* Create OS Thread for APP_Tasks. */
xTaskCreate((TaskFunction_t) _APP_Tasks,
"APP_Tasks",
1024,
NULL,
1,
&xAPP_Tasks);
xTaskCreate((TaskFunction_t) _LED_Blinky,
"LED_Tasks",
1024,
NULL,
1,
&xLED_Blinky);
/* Start RTOS Scheduler. */
* Create all Threads for APP Tasks before starting FreeRTOS Scheduler *
vTaskStartScheduler(); /* This function never returns. */
这个task的入口函数定义如下,其中精确延迟采用了freeRTOS推荐的API.
void _LED_Blinky( void *pvParameters ){
while(1){
GPIO_RB7_Toggle();
vTaskDelay(1000/portTICK_PERIOD_MS);
7. 编译,烧录。
Currently loaded versions:
Application version...........00.06.60
Boot version..................01.01.41
Script version................00.05.72
Script build number...........2889965820
Tool pack version ............1.11.1054
Target voltage detected
Target device WBZ451 found.
Device Revision Id = 0xfbf
Device Id = 0x9b8f
Calculating memory ranges for operation...
Erasing...
The following memory area(s) will be programmed:
program memory: start address = 0x1004000, end address = 0x1025fff
configuration memory
boot config memory
Programming/Verify complete
8. 结果:
