1607|7
7209
【CW32L052评测】2、点亮LED灯 [复制链接]
  1. 创建工程文件夹,并赋予可读可写权限:
  • lugl@lugl-virtual-machine:~$ mkdir cw32l052_pro
  • lugl@lugl-virtual-machine:~$ chmod 777 -R cw32l052_pro/
2. 初始化git仓库,以便同步到远程创库:进入刚进入的文件夹,执行git init 并用git config --global user.name "name", git config --global user.email "email@qq.com"
  • lugl@lugl-virtual-machine:~/cw32l052_pro$ git init
  • 已初始化空的 Git 仓库于 /home/lugl/cw32l052_pro/.git/
  • lugl@lugl-virtual-machine:~/cw32l052_pro$ git config --global user.mane "name"
  • lugl@lugl-virtual-machine:~/cw32l052_pro$ git config --global user.email "name@qq.com"
3. 在gitee上新一个创库,并下载一下仓库:
  • lugl@lugl-virtual-machine:~/cw32l052_pro$ git clone https://gitee.com/lugl/cw32l052.git
  • 正克隆到 'cw32l052'...
  • remote: Enumerating objects: 9, done.
  • remote: Counting objects: 100% (9/9), done.
  • remote: Compressing objects: 100% (9/9), done.
  • remote: Total 9 (delta 0), reused 0 (delta 0), pack-reused 0
  • 展开对象中: 100% (9/9), 6.91 KiB | 6.91 MiB/s, 完成.
4. 把cw32l052的gcc工程模块复制进cw32l052_pro/cw32l052文件下
  5. git add . 以及git commit 同时把push到远程仓库
  • lugl@lugl-virtual-machine:~/cw32l052_pro/cw32l052$ git push
  • 枚举对象中: 144, 完成.
  • 对象计数中: 100% (144/144), 完成.
  • 使用 8 个线程进行压缩
  • 压缩对象中: 100% (143/143), 完成.
  • 写入对象中: 100% (143/143), 947.84 KiB | 8.46 MiB/s, 完成.
  • 总共 143 (差异 41),复用 0 (差异 0
  • remote: Resolving deltas: 100% (41/41), completed with 1 local object.
  • remote: Powered by GITEE.COM [GNK-6.4]
  • To https://gitee.com/lugl/cw32l052.git
  • a0b3de8..1cf0224 master -> master
6. 用vscode 打开工程文件夹
  7. make一下:
  • lugl@lugl-virtual-machine:~/cw32l052_pro/cw32l052/cw32l052_gcc$ make
  • [DUMP] build_exec/template.elf -> build_exec/template.s
  • [SIZE] build_exec/template.elf
  • text data bss dec hex filename
  • 1500 20 1572 3092 c14 build_exec/template.elf
  • -e Build Finish
8. 修改主程序:
  • static inline void LED_Init()
  • GPIO_InitTypeDef GPIO_InitStruct;
  • RCC_AHBPeriphClk_Enable(RCC_AHB_PERIPH_GPIOC, ENABLE);
  • GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  • GPIO_InitStruct.IT = GPIO_IT_NONE;
  • GPIO_InitStruct.Pins = GPIO_PIN_10;
  • GPIO_Init(CW_GPIOC, &GPIO_InitStruct);
  • int main(void)
  • LED_Init();
  • InitTick(24000000);
  • // 开启两线调试接口
  • RCC_SWDIO_Config(RCC_SYSCTRL_SWDIOEN);
  • while (1)
  • GPIO_TogglePin(CW_GPIOC, GPIO_PIN_10);
  • SysTickDelay(500);
  • return 0;
9. 执行make flash:
  • lugl@lugl-virtual-machine:~/cw32l052_pro/cw32l052/cw32l052_gcc$ make flash
  • -e Start pyOCD
  • 0000739 I Loading /home/lugl/cw32l052_pro/cw32l052/cw32l052_gcc/build_exec/template.elf [load_cmd]
  • [==================================================] 100%
  • 0001348 I Erased 0 bytes (0 sectors), programmed 0 bytes (0 pages), skipped 1536 bytes (3 pages) at 2.47 kB/s [loader]
这样我们可以看到LED在闪烁了。
感谢楼主分享,先收藏后慢慢学习.   详情 回复 发表于 2023-7-13 08:34
1747
CW32L052点亮LED灯这个更easy
感谢大佬的肯定。  详情 回复 发表于 2023-7-12 09:03
7209
火辣西米秀 发表于 2023-7-12 08:55 CW32L052点亮LED灯这个更easy
感谢大佬的肯定。
6188
楼主辛苦了!
感谢版主大佬的关注!  详情 回复 发表于 2023-7-12 10:39
7209
感谢版主大佬的关注!
7793
谢谢分享!
多谢大佬的关注。  详情 回复 发表于 2023-7-12 20:43
默认摸鱼,再摸鱼。2022、9、28
7209
多谢大佬的关注。
感谢楼主分享,先收藏后慢慢学习.
