墨水屏以低功耗、停止供电后还可以显不,常常为电子标签所有。这里向大家介绍如何驱动墨子屏
1、定义墨水屏的Display_EPD_W21_spi.h:
- #ifndef INC_DISPLAY_EPD_W21_SPI_C_
- #define INC_DISPLAY_EPD_W21_SPI_C_
- #include "main.h"
- #define EPD_W21_MOSI_0 EP_MOSI_GPIO_Port->BRR = (uint32_t)EP_MOSI_Pin
- #define EPD_W21_MOSI_1 EP_MOSI_GPIO_Port->BSRR = (uint32_t)EP_MOSI_Pin
- #define EPD_W21_CLK_0 EP_SCK_GPIO_Port->BRR = (uint32_t)EP_SCK_Pin
- #define EPD_W21_CLK_1 EP_SCK_GPIO_Port->BSRR = (uint32_t)EP_SCK_Pin
- #define EPD_W21_CS_0 EP_CS_GPIO_Port->BRR = (uint32_t)EP_CS_Pin
- #define EPD_W21_CS_1 EP_CS_GPIO_Port->BSRR = (uint32_t)EP_CS_Pin
- #define EPD_W21_DC_0 EP_DC_GPIO_Port->BRR = (uint32_t)EP_DC_Pin
- #define EPD_W21_DC_1 EP_DC_GPIO_Port->BSRR = (uint32_t)EP_DC_Pin
- #define EPD_W21_RST_0 EP_REST_GPIO_Port->BRR = (uint32_t)EP_REST_Pin
- #define EPD_W21_RST_1 EP_REST_GPIO_Port->BSRR = (uint32_t)EP_REST_Pin
- #define isEPD_W21_BUSY HAL_GPIO_ReadPin(EP_BUSY_GPIO_Port, EP_BUSY_Pin) // for solomen solutions
- void SPI_Write(unsigned char value);
- void EPD_W21_WriteDATA(unsigned char data);
- void EPD_W21_WriteCMD(unsigned char command);
- void EPD_GPIO_Init(void);
- void EPD_show_Temp(float temp_f, float humi_f);
- #endif /* INC_DISPLAY_EPD_W21_SPI_C_ */
2、Display_EPD_W21_spi.c这个文件主要是负责spi的数据读写
- #include "Display_EPD_W21_spi.h"
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- __HAL_RCC_GPIOC_CLK_ENABLE();
- __HAL_RCC_GPIOF_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- __HAL_RCC_GPIOB_CLK_ENABLE();
- HAL_GPIO_WritePin(GPIOA, EP_REST_Pin|EP_DC_Pin|EP_CS_Pin|EP_SCK_Pin
- |EP_MOSI_Pin, GPIO_PIN_RESET);
- GPIO_InitStruct.Pin = EP_BUSY_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- HAL_GPIO_Init(EP_BUSY_GPIO_Port, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = EP_REST_Pin|EP_DC_Pin|EP_CS_Pin|EP_SCK_Pin
- |EP_MOSI_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Pull = GPIO_PULLUP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- unsigned char i;
- for(i=0; i<8; i++)
- EPD_W21_CLK_0;
- if(value & 0x80)
- EPD_W21_MOSI_1;
- else
- EPD_W21_MOSI_0;
- value = (value << 1);
- EPD_W21_CLK_1;
- EPD_W21_CS_0;
- EPD_W21_DC_0;
- SPI_Write(command);
- EPD_W21_CS_1;
- EPD_W21_CS_0;
- EPD_W21_DC_1;
- SPI_Write(data);
- EPD_W21_CS_1;
- end file
3、Display_EPD_W21.h为墨水屏的驱动头文件:
- #ifndef INC_DISPLAY_EPD_W21_H_
- #define INC_DISPLAY_EPD_W21_H_
- #define EPD_WIDTH 128
- #define EPD_HEIGHT 296
- void Epaper_READBUSY(void);
- void Epaper_Spi_WriteByte(unsigned char TxData);
- void Epaper_Write_Command(unsigned char cmd);
- void Epaper_Write_Data(unsigned char data);
- void EPD_HW_Init(void);
- void EPD_Update(void);
- void EPD_Part_Init(void);
- void EPD_Part_Update(void);
- void EPD_WhiteScreen_White(void);
- void EPD_DeepSleep(void);
- void EPD_WhiteScreen_ALL(const unsigned char *datas);
- void EPD_SetRAMValue_BaseMap(const unsigned char * datas);
- void EPD_Dis_Part(unsigned int x_start,unsigned int y_start,const unsigned char * datas,unsigned int PART_COLUMN,unsigned int PART_LINE);
- void EPD_Dis_Part_myself(unsigned int x_startA,unsigned int y_startA,const unsigned char * datasA,
- unsigned int x_startB,unsigned int y_startB,const unsigned char * datasB,
- unsigned int x_startC,unsigned int y_startC,const unsigned char * datasC,
- unsigned int x_startD,unsigned int y_startD,const unsigned char * datasD,
- unsigned int x_startE,unsigned int y_startE,const unsigned char * datasE,
- unsigned int PART_COLUMN,unsigned int PART_LINE);
- void EPD_HW_Init_GUI(void);
- void EPD_Display(unsigned char *Image);
- #endif /* INC_DISPLAY_EPD_W21_H_ */
5、Display_EPD_W21.c这个文件为墨水屏的驱动
- #include "Display_EPD_W21.h"
- #include "main.h"
- void delay_xms(unsigned int xms)
- HAL_Delay(xms);
- const unsigned char LUT_DATA[]= {
- 0x50,
- 0xAA,
- 0x55,
- 0xAA,
- 0x11,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0xFF,
- 0xFF,
- 0x1F,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00
- const unsigned char LUT_DATA_part[]={
- 0x10,
- 0x18,
- 0x18,
- 0x08,
- 0x18,
- 0x18,
- 0x08,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x13,
- 0x14,
- 0x44,
- 0x12,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00,
- 0x00
- unsigned int Width, Height,i,j;
- Width = (EPD_WIDTH % 8 == 0)? (EPD_WIDTH / 8 ): (EPD_WIDTH / 8 + 1);
- Height = EPD_HEIGHT;
- EPD_W21_WriteCMD(0x24);
- for ( j = 0; j < Height; j++) {
- for ( i = 0; i < Width; i++) {
- EPD_W21_WriteDATA(Image[i + j * Width]);
- EPD_Update();
- unsigned char TempData;
- unsigned char scnt;
- TempData=TxData;
- EPD_W21_CLK_0;
- for(scnt=0;scnt<8;scnt++)
- if(TempData&0x80)
- EPD_W21_MOSI_1 ;
- else
- EPD_W21_MOSI_0 ;
- EPD_W21_CLK_1;
- EPD_W21_CLK_0;
- TempData=TempData<<1;
- while(1)
- if(isEPD_W21_BUSY==0) break;;
- EPD_W21_CS_1;
- EPD_W21_CS_0;
- EPD_W21_DC_0;
- Epaper_Spi_WriteByte(cmd);
- EPD_W21_CS_1;
- EPD_W21_CS_1;
- EPD_W21_CS_0;
- EPD_W21_DC_1;
- Epaper_Spi_WriteByte(data);
- EPD_W21_CS_1;
- void EPD_select_LUT(const unsigned char * wave_data)
- unsigned char count;
- Epaper_Write_Command(0x32);
- for(count=0;count<30;count++)Epaper_Write_Data(wave_data[count]);
- EPD_W21_RST_0;
- delay_xms(10);
- EPD_W21_RST_1;
- delay_xms(10);
- Epaper_READBUSY();
- Epaper_Write_Command(0x12);
- Epaper_Write_Command(0x01);
- Epaper_Write_Data(0x27);
- Epaper_Write_Data(0x01);
- Epaper_Write_Data(0x00);
- Epaper_Write_Command(0x0C);
- Epaper_Write_Data(0xD7);
- Epaper_Write_Data(0xD6);
- Epaper_Write_Data(0x9D);
- Epaper_Write_Command(0x11);
- Epaper_Write_Command(0x44);
- Epaper_Write_Data(0x0F);
- Epaper_Write_Command(0x45);
- Epaper_Write_Command(0x3C);
- Epaper_Write_Data(0x33);
- Epaper_Write_Command(0x2C);
- Epaper_Write_Data(0x9a);
- Epaper_Write_Command(0x3A);
- Epaper_Write_Data(0x1A);
- Epaper_Write_Command(0x3B);
- Epaper_Write_Data(0X08);
- Epaper_Write_Command(0x4E);
- Epaper_Write_Command(0x4F);
- EPD_select_LUT(LUT_DATA);
- EPD_W21_RST_0;
- delay_xms(10);
- EPD_W21_RST_1;
- delay_xms(10);
- Epaper_Write_Data(0x3F);
- Epaper_Write_Command(0x22);
- Epaper_Write_Data(0xC4);
- Epaper_Write_Command(0x20);
- Epaper_Write_Data(0x04);
- unsigned int i;
- Epaper_Write_Command(0x24);
- for(i=0;i<4736;i++)
- Epaper_Write_Data(*datas);
- datas++;
- EPD_Update();
- EPD_select_LUT(LUT_DATA_part);
- Epaper_Write_Data(0xC0);
- delay_xms(200);
- void EPD_SetRAMValue_BaseMap( const unsigned char * datas)
- unsigned int i;
- const unsigned char *datas_flag;
- datas_flag=datas;
- Epaper_Write_Data(0xFF);
- datas++;
- datas=datas_flag;
- Epaper_Write_Command(0x26);
- Epaper_Write_Data(0xff);
- datas++;
- EPD_Update();
- delay_xms(100);
- EPD_Part_Init();
- unsigned int i;
- unsigned int x_end,y_start1,y_start2,y_end1,y_end2;
- x_start=x_start/8;
- x_end=x_start+PART_LINE/8-1;
- y_start1=0;
- y_start2=y_start;
- if(y_start>=256)
- y_start1=y_start2/256;
- y_start2=y_start2%256;
- y_end1=0;
- y_end2=y_start+PART_COLUMN-1;
- if(y_end2>=256)
- y_end1=y_end2/256;
- y_end2=y_end2%256;
- Epaper_Write_Data(x_start);
- Epaper_Write_Data(x_end);
- Epaper_Write_Data(y_start2);
- Epaper_Write_Data(y_start1);
- Epaper_Write_Data(y_end2);
- Epaper_Write_Data(y_end1);
- for(i=0;i<PART_COLUMN*PART_LINE/8;i++)
- datas++;
- Epaper_Write_Command(0x10);
- delay_xms(100);
- unsigned int i,k;
- for(k=0;k<250;k++)
- for(i=0;i<25;i++)
- EPD_Update();
- unsigned int i;
- x_startA=x_startA/8;
- x_end=x_startA+PART_LINE/8-1;
- y_start1=0;
- y_start2=y_startA-1;
- if(y_startA>=256)
- y_end1=0;
- y_end2=y_startA+PART_COLUMN-1;
- if(y_end2>=256)
- Epaper_Write_Data(x_startA);
- Epaper_Write_Data(*datasA);
- datasA++;
- x_startB=x_startB/8;
- x_end=x_startB+PART_LINE/8-1;
- y_start1=0;
- y_start2=y_startB-1;
- if(y_startB>=256)
- y_end1=0;
- y_end2=y_startB+PART_COLUMN-1;
- if(y_end2>=256)
- Epaper_Write_Data(x_startB);
- Epaper_Write_Data(*datasB);
- datasB++;
- x_startC=x_startC/8;
- x_end=x_startC+PART_LINE/8-1;
- y_start1=0;
- y_start2=y_startC-1;
- if(y_startC>=256)
- y_end1=0;
- y_end2=y_startC+PART_COLUMN-1;
- if(y_end2>=256)
- Epaper_Write_Data(x_startC);
- Epaper_Write_Data(*datasC);
- datasC++;
- x_startD=x_startD/8;
- x_end=x_startD+PART_LINE/8-1;
- y_start1=0;
- y_start2=y_startD-1;
- if(y_startD>=256)
- y_end1=0;
- y_end2=y_startD+PART_COLUMN-1;
- if(y_end2>=256)
- Epaper_Write_Data(x_startD);
- Epaper_Write_Data(*datasD);
- datasD++;
- x_startE=x_startE/8;
- x_end=x_startE+PART_LINE/8-1;
- y_start1=0;
- y_start2=y_startE-1;
- if(y_startE>=256)
- y_end1=0;
- y_end2=y_startE+PART_COLUMN-1;
- if(y_end2>=256)
- Epaper_Write_Data(x_startE);
- Epaper_Write_Data(*datasE);
- datasE++;
- EPD_Part_Update();
6、字库文件:
- #ifndef FONTS_AP_29DEMO_H_
- #define FONTS_AP_29DEMO_H_
- const unsigned char gImage_num1[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xF7,
- 0xFF,0xDF,0xFF,0xF7,0xFF,0xDF,0xFF,0xF7,0xFF,0xDF,0xFF,0xE7,0xFF,0x80,0x00,0x07,
- 0xFF,0x00,0x00,0x07,0xFF,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xE7,0xFF,0xFF,0xFF,0xF7,
- 0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- const unsigned char gImage_num2[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xC7,0xFF,0xC1,0xFF,0x87,
- 0xFF,0x99,0xFF,0x27,0xFF,0x3F,0xFE,0x67,0xFF,0x7F,0xFC,0xE7,0xFF,0x7F,0xF9,0xE7,
- 0xFF,0x7F,0xF3,0xE7,0xFF,0x7F,0xE7,0xE7,0xFF,0x3F,0xCF,0xE7,0xFF,0x1F,0x1F,0xE7,
- 0xFF,0x80,0x3F,0xC7,0xFF,0x80,0x7E,0x07,0xFF,0xE0,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,
- const unsigned char gImage_num3[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC3,0xFE,0x1F,0xFF,0x83,0xFE,0x0F,
- 0xFF,0x83,0xFE,0x0F,0xFF,0x3F,0xFF,0xE7,0xFF,0x7F,0xBF,0xF7,0xFF,0x7F,0xBF,0xF7,
- 0xFF,0x7F,0xBF,0xF7,0xFF,0x3F,0x1F,0xF7,0xFF,0x1E,0x1F,0xE7,0xFF,0x80,0x4F,0xCF,
- 0xFF,0x80,0xC0,0x0F,0xFF,0xE1,0xE0,0x1F,0xFF,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,
- const unsigned char gImage_num4[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFF,0xFF,0xFF,0xF1,0xFF,0xFF,0xFF,0xE1,0xFF,
- 0xFF,0xFF,0x8D,0xFF,0xFF,0xFE,0x1D,0xFF,0xFF,0xFC,0x7D,0xFB,0xFF,0xF0,0xFD,0xFB,
- 0xFF,0xE3,0xFD,0xFB,0xFF,0x80,0x00,0x03,0xFF,0x00,0x00,0x03,0xFF,0x00,0x00,0x03,
- 0xFF,0x00,0x00,0x03,0xFF,0xFF,0xFD,0xFB,0xFF,0xFF,0xFD,0xFB,0xFF,0xFF,0xFD,0xFB,
- const unsigned char gImage_num5[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0xFF,0xF8,0x1E,0x0F,
- 0xFF,0x00,0x1E,0x67,0xFF,0x07,0x3F,0xF7,0xFF,0x3E,0x7F,0xF7,0xFF,0x3E,0xFF,0xF7,
- 0xFF,0x3E,0xFF,0xF7,0xFF,0x3E,0xFF,0xF7,0xFF,0x3E,0x7F,0xE7,0xFF,0x3E,0x3F,0x8F,
- 0xFF,0x3F,0x00,0x0F,0xFF,0x3F,0x80,0x1F,0xFF,0x3F,0xE0,0x7F,0xFF,0xFF,0xFF,0xFF,
- const unsigned char gImage_num6[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0xFF,0xFF,0xF0,0x00,0x3F,
- 0xFF,0xE0,0x00,0x1F,0xFF,0xC3,0x8F,0x0F,0xFF,0x9F,0x9F,0xC7,0xFF,0x3F,0x3F,0xE7,
- 0xFF,0x3F,0x7F,0xF7,0xFF,0x7F,0x7F,0xF7,0xFF,0x7F,0x7F,0xF7,0xFF,0x7F,0x3F,0xE7,
- 0xFF,0x0F,0x1F,0xCF,0xFF,0x8F,0x80,0x0F,0xFF,0xCF,0xC0,0x1F,0xFF,0xFF,0xE0,0x7F,
- const unsigned char gImage_num7[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC3,0xFF,0xFF,0xFF,0x03,0xFF,0xFF,
- 0xFF,0x0F,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0x3F,0xFE,0x07,0xFF,0x3F,0xF0,0x07,
- 0xFF,0x3F,0x80,0x07,0xFF,0x3E,0x0F,0xFF,0xFF,0x38,0x7F,0xFF,0xFF,0x21,0xFF,0xFF,
- 0xFF,0x07,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- const unsigned char gImage_num8[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x3F,0xFF,0xE1,0xF0,0x1F,0xFF,0xC0,0xE0,0x0F,
- 0xFF,0x80,0x47,0xCF,0xFF,0x1C,0x0F,0xE7,0xFF,0x3E,0x1F,0xF7,0xFF,0x7F,0x1F,0xF7,
- 0xFF,0x7F,0x9F,0xF7,0xFF,0x7F,0x8F,0xF7,0xFF,0x3F,0x87,0xE7,0xFF,0x1E,0x03,0xCF,
- 0xFF,0x80,0x60,0x0F,0xFF,0xC0,0xF0,0x1F,0xFF,0xE1,0xF8,0x3F,0xFF,0xFF,0xFF,0xFF,
- const unsigned char gImage_num9[128] = {
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x3F,0xFF,0xFF,0xC0,0x1F,0x8F,0xFF,0x80,0x0F,0x8F,
- 0xFF,0x8F,0xC7,0x87,0xFF,0x3F,0xE7,0xF7,0xFF,0x7F,0xF7,0xF7,0xFF,0x7F,0xF7,0xF7,
- 0xFF,0x7F,0xF7,0xE7,0xFF,0x7F,0xE7,0xC7,0xFF,0x3F,0xCF,0x8F,0xFF,0x8F,0x8C,0x1F,
- 0xFF,0xC0,0x00,0x3F,0xFF,0xE0,0x00,0x7F,0xFF,0xF8,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,
- const unsigned char Num[10][256] = {
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XE0,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X00,0X00,0X1F,0XFF,0XFF,
- 0XFF,0XFF,0XE0,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0X80,0X00,0X00,0X00,0XFF,0XFF,
- 0XFF,0XFE,0X00,0X00,0X00,0X00,0X3F,0XFF,0XFF,0XFC,0X00,0X00,0X00,0X00,0X1F,0XFF,
- 0XFF,0XF8,0X00,0X00,0X00,0X00,0X0F,0XFF,0XFF,0XF0,0X03,0XFF,0XFF,0XE0,0X07,0XFF,
- 0XFF,0XE0,0X3F,0XFF,0XFF,0XFE,0X03,0XFF,0XFF,0XE0,0XFF,0XFF,0XFF,0XFF,0X83,0XFF,
- 0XFF,0XC1,0XFF,0XFF,0XFF,0XFF,0XC1,0XFF,0XFF,0XC7,0XFF,0XFF,0XFF,0XFF,0XF1,0XFF,
- 0XFF,0XC7,0XFF,0XFF,0XFF,0XFF,0XF1,0XFF,0XFF,0XCF,0XFF,0XFF,0XFF,0XFF,0XF9,0XFF,
- 0XFF,0XCF,0XFF,0XFF,0XFF,0XFF,0XF9,0XFF,0XFF,0XC7,0XFF,0XFF,0XFF,0XFF,0XF1,0XFF,
- 0XFF,0XC7,0XFF,0XFF,0XFF,0XFF,0XF1,0XFF,0XFF,0XC3,0XFF,0XFF,0XFF,0XFF,0XE1,0XFF,
- 0XFF,0XE0,0XFF,0XFF,0XFF,0XFF,0X83,0XFF,0XFF,0XE0,0X3F,0XFF,0XFF,0XFE,0X03,0XFF,
- 0XFF,0XF0,0X03,0XFF,0XFF,0XC0,0X07,0XFF,0XFF,0XF8,0X00,0X00,0X00,0X00,0X0F,0XFF,
- 0XFF,0XFC,0X00,0X00,0X00,0X00,0X1F,0XFF,0XFF,0XFE,0X00,0X00,0X00,0X00,0X3F,0XFF,
- 0XFF,0XFF,0X80,0X00,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0XE0,0X00,0X00,0X03,0XFF,0XFF,
- 0XFF,0XFF,0XFE,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFC,0XFF,0XFF,0XFF,0XFF,0XF3,0XFF,0XFF,0XFC,0XFF,0XFF,0XFF,0XFF,0XF3,0XFF,
- 0XFF,0XF8,0XFF,0XFF,0XFF,0XFF,0XE3,0XFF,0XFF,0XF8,0X00,0X00,0X00,0X00,0X03,0XFF,
- 0XFF,0XF0,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XF0,0X00,0X00,0X00,0X00,0X03,0XFF,
- 0XFF,0XC0,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X00,0X03,0XFF,
- 0XFF,0XC0,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC3,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF3,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF3,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE3,0XFF,0XFF,0XFF,0XC1,0XFF,0XFF,0XFF,0X83,0XFF,
- 0XFF,0XFF,0X00,0XFF,0XFF,0XFE,0X03,0XFF,0XFF,0XFC,0X00,0X7F,0XFF,0XFC,0X03,0XFF,
- 0XFF,0XF8,0X00,0X7F,0XFF,0XF8,0X03,0XFF,0XFF,0XF0,0X00,0X7F,0XFF,0XF0,0X43,0XFF,
- 0XFF,0XF0,0X00,0X7F,0XFF,0XE1,0XC3,0XFF,0XFF,0XE1,0XF0,0X7F,0XFF,0X83,0XC3,0XFF,
- 0XFF,0XE3,0XFF,0XFF,0XFF,0X07,0XC3,0XFF,0XFF,0XE7,0XFF,0XFF,0XFE,0X0F,0XC3,0XFF,
- 0XFF,0XC7,0XFF,0XFF,0XFC,0X1F,0XC3,0XFF,0XFF,0XCF,0XFF,0XFF,0XF8,0X3F,0XC3,0XFF,
- 0XFF,0XCF,0XFF,0XFF,0XF0,0X7F,0XC3,0XFF,0XFF,0XCF,0XFF,0XFF,0XE0,0XFF,0XC3,0XFF,
- 0XFF,0XCF,0XFF,0XFF,0XC1,0XFF,0XC3,0XFF,0XFF,0XCF,0XFF,0XFF,0X83,0XFF,0XC3,0XFF,
- 0XFF,0XC7,0XFF,0XFF,0X07,0XFF,0XC3,0XFF,0XFF,0XC7,0XFF,0XFC,0X0F,0XFF,0XC3,0XFF,
- 0XFF,0XC3,0XFF,0XF0,0X1F,0XFF,0XC3,0XFF,0XFF,0XE0,0XFF,0XC0,0X3F,0XFF,0XC3,0XFF,
- 0XFF,0XE0,0X00,0X00,0X7F,0XFF,0X83,0XFF,0XFF,0XF0,0X00,0X00,0XFF,0XFF,0X83,0XFF,
- 0XFF,0XF0,0X00,0X01,0XFF,0XFE,0X03,0XFF,0XFF,0XF8,0X00,0X07,0XFF,0XF0,0X03,0XFF,
- 0XFF,0XFC,0X00,0X0F,0XFF,0XE0,0X03,0XFF,0XFF,0XFF,0X00,0X7F,0XFF,0XE0,0X0F,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X7F,0XFF,
- 0XFF,0XFE,0X07,0XFF,0XFF,0XF0,0X1F,0XFF,0XFF,0XFC,0X03,0XFF,0XFF,0XE0,0X0F,0XFF,
- 0XFF,0XF8,0X03,0XFF,0XFF,0XE0,0X07,0XFF,0XFF,0XF0,0X03,0XFF,0XFF,0XE0,0X07,0XFF,
- 0XFF,0XE0,0X03,0XFF,0XFF,0XE0,0X03,0XFF,0XFF,0XE3,0XC3,0XFF,0XFF,0XF0,0XE3,0XFF,
- 0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0XF1,0XFF,0XFF,0XC7,0XFF,0XFC,0XFF,0XFF,0XF1,0XFF,
- 0XFF,0XCF,0XFF,0XFC,0XFF,0XFF,0XF9,0XFF,0XFF,0XCF,0XFF,0XFC,0XFF,0XFF,0XF9,0XFF,
- 0XFF,0XCF,0XFF,0XF8,0X7F,0XFF,0XF9,0XFF,0XFF,0XC7,0XFF,0XF8,0X7F,0XFF,0XF1,0XFF,
- 0XFF,0XC3,0XFF,0XF0,0X7F,0XFF,0XF1,0XFF,0XFF,0XC1,0XFF,0XE2,0X3F,0XFF,0XE1,0XFF,
- 0XFF,0XE0,0X7F,0X82,0X1F,0XFF,0XC3,0XFF,0XFF,0XE0,0X00,0X03,0X0F,0XFF,0X83,0XFF,
- 0XFF,0XF0,0X00,0X07,0X01,0XFC,0X07,0XFF,0XFF,0XF8,0X00,0X0F,0X80,0X00,0X07,0XFF,
- 0XFF,0XFC,0X00,0X1F,0X80,0X00,0X0F,0XFF,0XFF,0XFE,0X00,0X3F,0XC0,0X00,0X1F,0XFF,
- 0XFF,0XFF,0X80,0XFF,0XF0,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X00,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7F,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFC,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF8,0X7F,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XE0,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X7F,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0X02,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0X0E,0X7F,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XF8,0X3E,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X7E,0X7F,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0X81,0XFE,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0X03,0XFE,0X7F,0XFF,0XFF,
- 0XFF,0XFF,0XFC,0X0F,0XFE,0X7F,0XF3,0XFF,0XFF,0XFF,0XF8,0X3F,0XFE,0X7F,0XF3,0XFF,
- 0XFF,0XFF,0XE0,0X7F,0XFE,0X7F,0XF3,0XFF,0XFF,0XFF,0XC1,0XFF,0XFE,0X7F,0XF3,0XFF,
- 0XFF,0XFF,0X03,0XFF,0XFE,0X7F,0XF3,0XFF,0XFF,0XFC,0X0F,0XFF,0XFE,0X7F,0XF3,0XFF,
- 0XFF,0XF8,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XE0,0X00,0X00,0X00,0X00,0X03,0XFF,
- 0XFF,0XE0,0X00,0X00,0X00,0X00,0X03,0XFF,0XFF,0XE0,0X00,0X00,0X00,0X00,0X03,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFE,0X7F,0XF3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X7F,0XF3,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFE,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X7F,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X3F,0XFF,0XFF,0XFF,0XF0,0X00,0X1F,0XC0,0X1F,0XFF,
- 0XFF,0XE0,0X00,0X00,0X1F,0XC0,0X0F,0XFF,0XFF,0XE0,0X00,0X00,0X1F,0XC0,0X07,0XFF,
- 0XFF,0XE0,0X00,0X0C,0X1F,0XC0,0X03,0XFF,0XFF,0XE1,0XFF,0XF8,0X7F,0XE1,0XE3,0XFF,
- 0XFF,0XE1,0XFF,0XF0,0XFF,0XFF,0XF3,0XFF,0XFF,0XE1,0XFF,0XF1,0XFF,0XFF,0XF1,0XFF,
- 0XFF,0XE1,0XFF,0XF1,0XFF,0XFF,0XF1,0XFF,0XFF,0XE1,0XFF,0XE3,0XFF,0XFF,0XF9,0XFF,
- 0XFF,0XE1,0XFF,0XE3,0XFF,0XFF,0XF9,0XFF,0XFF,0XE1,0XFF,0XE3,0XFF,0XFF,0XF9,0XFF,
- 0XFF,0XE1,0XFF,0XE1,0XFF,0XFF,0XF1,0XFF,0XFF,0XE1,0XFF,0XE1,0XFF,0XFF,0XE1,0XFF,
- 0XFF,0XE1,0XFF,0XE0,0XFF,0XFF,0XC3,0XFF,0XFF,0XE1,0XFF,0XF0,0X3F,0XFF,0X83,0XFF,
- 0XFF,0XE1,0XFF,0XF0,0X0F,0XFC,0X03,0XFF,0XFF,0XE1,0XFF,0XF8,0X00,0X00,0X07,0XFF,
- 0XFF,0XE1,0XFF,0XF8,0X00,0X00,0X0F,0XFF,0XFF,0XE1,0XFF,0XFC,0X00,0X00,0X1F,0XFF,
- 0XFF,0XE1,0XFF,0XFF,0X00,0X00,0X3F,0XFF,0XFF,0XE3,0XFF,0XFF,0X80,0X00,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XF8,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XF8,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X00,0X00,0X07,0XFF,0XFF,
- 0XFF,0XFF,0XF0,0X00,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XC0,0X00,0X00,0X00,0X7F,0XFF,
- 0XFF,0XFF,0X00,0X00,0X00,0X00,0X1F,0XFF,0XFF,0XFE,0X00,0X00,0X00,0X00,0X0F,0XFF,
- 0XFF,0XFC,0X00,0X00,0X00,0X00,0X07,0XFF,0XFF,0XF8,0X07,0XF8,0X1F,0XF8,0X07,0XFF,
- 0XFF,0XF0,0X3F,0XF0,0X7F,0XFF,0X03,0XFF,0XFF,0XF0,0XFF,0XE0,0XFF,0XFF,0X83,0XFF,
- 0XFF,0XE1,0XFF,0XE1,0XFF,0XFF,0XE1,0XFF,0XFF,0XE3,0XFF,0XE3,0XFF,0XFF,0XF1,0XFF,
- 0XFF,0XC7,0XFF,0XC3,0XFF,0XFF,0XF1,0XFF,0XFF,0XC7,0XFF,0XC7,0XFF,0XFF,0XF9,0XFF,
- 0XFF,0XCF,0XFF,0XC7,0XFF,0XFF,0XF9,0XFF,0XFF,0XCF,0XFF,0XC7,0XFF,0XFF,0XF9,0XFF,
- 0XFF,0XCF,0XFF,0XC7,0XFF,0XFF,0XF9,0XFF,0XFF,0XCF,0XFF,0XC3,0XFF,0XFF,0XF1,0XFF,
- 0XFF,0XC7,0XFF,0XC1,0XFF,0XFF,0XF1,0XFF,0XFF,0XC0,0X1F,0XC0,0XFF,0XFF,0XE3,0XFF,
- 0XFF,0XC0,0X1F,0XE0,0X7F,0XFF,0X83,0XFF,0XFF,0XE0,0X1F,0XE0,0X0F,0XF8,0X07,0XFF,
- 0XFF,0XF0,0X1F,0XF0,0X00,0X00,0X0F,0XFF,0XFF,0XF0,0X1F,0XF0,0X00,0X00,0X0F,0XFF,
- 0XFF,0XFC,0X3F,0XFC,0X00,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFE,0X00,0X00,0X7F,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XC0,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF3,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFC,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0XFF,0XFF,0XFF,0XE0,0X03,0XFF,
- 0XFF,0XE1,0XFF,0XFF,0XFE,0X00,0X01,0XFF,0XFF,0XE1,0XFF,0XFF,0XF0,0X00,0X01,0XFF,
- 0XFF,0XE1,0XFF,0XFF,0XC0,0X00,0X01,0XFF,0XFF,0XE1,0XFF,0XFF,0X00,0X00,0X01,0XFF,
- 0XFF,0XE1,0XFF,0XFC,0X00,0X00,0X01,0XFF,0XFF,0XE1,0XFF,0XE0,0X00,0X00,0X03,0XFF,
- 0XFF,0XE1,0XFF,0X80,0X0F,0XFF,0XFF,0XFF,0XFF,0XE1,0XFE,0X00,0X7F,0XFF,0XFF,0XFF,
- 0XFF,0XE1,0XFC,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0XF0,0X1F,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE1,0XC0,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE0,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0X01,0XFF,0XFF,0XFF,0XFF,0X80,0XFF,0XF8,0X00,0X7F,0XFF,
- 0XFF,0XFE,0X00,0X3F,0XF0,0X00,0X3F,0XFF,0XFF,0XFC,0X00,0X1F,0XE0,0X00,0X1F,0XFF,
- 0XFF,0XF8,0X00,0X0F,0XC0,0X00,0X0F,0XFF,0XFF,0XF0,0X00,0X07,0X80,0XFE,0X07,0XFF,
- 0XFF,0XE0,0X7C,0X03,0X07,0XFF,0X83,0XFF,0XFF,0XE1,0XFF,0X01,0X0F,0XFF,0XC3,0XFF,
- 0XFF,0XE3,0XFF,0X80,0X3F,0XFF,0XE3,0XFF,0XFF,0XC7,0XFF,0XC0,0X7F,0XFF,0XF1,0XFF,
- 0XFF,0XC7,0XFF,0XE0,0X7F,0XFF,0XF1,0XFF,0XFF,0XCF,0XFF,0XE0,0X7F,0XFF,0XF9,0XFF,
- 0XFF,0XCF,0XFF,0XF0,0X7F,0XFF,0XF9,0XFF,0XFF,0XCF,0XFF,0XF8,0X3F,0XFF,0XF9,0XFF,
- 0XFF,0XCF,0XFF,0XF8,0X3F,0XFF,0XF9,0XFF,0XFF,0XCF,0XFF,0XF8,0X1F,0XFF,0XF9,0XFF,
- 0XFF,0XC7,0XFF,0XFC,0X0F,0XFF,0XF1,0XFF,0XFF,0XC7,0XFF,0XF8,0X07,0XFF,0XF1,0XFF,
- 0XFF,0XC3,0XFF,0XF0,0X07,0XFF,0XE3,0XFF,0XFF,0XE1,0XFF,0XE1,0X01,0XFF,0XE3,0XFF,
- 0XFF,0XE0,0XFF,0X83,0X00,0XFF,0X83,0XFF,0XFF,0XF0,0X00,0X07,0X80,0X3E,0X07,0XFF,
- 0XFF,0XF0,0X00,0X07,0XC0,0X00,0X07,0XFF,0XFF,0XF8,0X00,0X0F,0XE0,0X00,0X0F,0XFF,
- 0XFF,0XFC,0X00,0X3F,0XF0,0X00,0X1F,0XFF,0XFF,0XFF,0X00,0X7F,0XFC,0X00,0X7F,0XFF,
- 0XFF,0XFF,0XFF,0XFF,0XFF,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF0,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X80,0X00,0X7F,0XFF,0XFF,0XFF,
- 0XFF,0XFE,0X00,0X00,0X3F,0XFF,0X1F,0XFF,0XFF,0XFC,0X00,0X00,0X1F,0XFC,0X0F,0XFF,
- 0XFF,0XF8,0X00,0X00,0X0F,0XFC,0X07,0XFF,0XFF,0XF0,0X00,0X00,0X07,0XFC,0X03,0XFF,
- 0XFF,0XE0,0X3F,0XF8,0X07,0XFC,0X03,0XFF,0XFF,0XE0,0XFF,0XFF,0X03,0XFC,0X01,0XFF,
- 0XFF,0XE3,0XFF,0XFF,0X83,0XFE,0X01,0XFF,0XFF,0XC7,0XFF,0XFF,0XC3,0XFF,0XF1,0XFF,
- 0XFF,0XC7,0XFF,0XFF,0XC3,0XFF,0XF9,0XFF,0XFF,0XCF,0XFF,0XFF,0XE3,0XFF,0XF9,0XFF,
- 0XFF,0XCF,0XFF,0XFF,0XE3,0XFF,0XF9,0XFF,0XFF,0XCF,0XFF,0XFF,0XE3,0XFF,0XF1,0XFF,
- 0XFF,0XCF,0XFF,0XFF,0XC3,0XFF,0XF1,0XFF,0XFF,0XCF,0XFF,0XFF,0XC3,0XFF,0XE3,0XFF,
- 0XFF,0XC7,0XFF,0XFF,0X87,0XFF,0XC3,0XFF,0XFF,0XC3,0XFF,0XFF,0X07,0XFF,0X03,0XFF,
- 0XFF,0XE1,0XFF,0XFE,0X0F,0XFC,0X07,0XFF,0XFF,0XE0,0X7F,0XFC,0X1F,0XE0,0X0F,0XFF,
- 0XFF,0XF0,0X0F,0XF0,0X38,0X00,0X1F,0XFF,0XFF,0XF8,0X00,0X00,0X00,0X00,0X3F,0XFF,
- 0XFF,0XFC,0X00,0X00,0X00,0X00,0X7F,0XFF,0XFF,0XFE,0X00,0X00,0X00,0X01,0XFF,0XFF,
- 0XFF,0XFF,0X00,0X00,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XE0,0X00,0X00,0X1F,0XFF,0XFF,
- 0XFF,0XFF,0XFC,0X00,0X01,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- const unsigned char gImage_numdot[256] = {
- 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XC3,0XFF,0XFF,0X87,0XFF,
- 0XFF,0XFF,0XFF,0X81,0XFF,0XFF,0X03,0XFF,0XFF,0XFF,0XFF,0X00,0XFF,0XFE,0X01,0XFF,
- 0XFF,0XFF,0XFF,0X00,0XFF,0XFE,0X01,0XFF,0XFF,0XFF,0XFF,0X00,0XFF,0XFE,0X01,0XFF,
- 0XFF,0XFF,0XFF,0X81,0XFF,0XFF,0X03,0XFF,0XFF,0XFF,0XFF,0XC3,0XFF,0XFF,0X87,0XFF,
- const unsigned char gImage_basemap[4736] = {
- 0XFF,0XFF,0XFF,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0X9F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XDF,0XFF,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XDF,0XFE,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XC7,0XFC,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XC1,0XF0,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF0,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF8,0X00,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF8,0X00,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFE,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XC3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0X94,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFE,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFE,0X63,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF0,0X77,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF8,0X77,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF8,0X36,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF1,0X00,0X47,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFB,0XC1,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFC,0X36,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFE,0X80,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFE,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF0,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XC0,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFE,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFC,0X00,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF0,0X00,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFB,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0X7B,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XBB,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XCE,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XDB,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF1,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF8,0X20,0X83,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFB,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XF3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XC3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XFF,0XC7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF8,0X00,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFE,0X4F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0X27,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0X93,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XC0,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF8,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF8,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF8,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF8,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF8,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XEF,0XF8,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE3,0XF8,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0XFE,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XC0,0X33,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XC0,0X61,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE1,0XFE,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE7,0XF8,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0X83,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFC,0X10,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF9,0XFF,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF3,0XFF,0X9F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE7,0XFF,0XCF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XCF,0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XDF,0XFE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XDF,0XFC,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0X9F,0XF9,0XF3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0X9F,0XF3,0XF3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XA0,0X07,0XFB,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0X9F,0XFF,0XF3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XDF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0X00,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0X00,0X01,0X87,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XE3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0X81,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0X80,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XE0,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFF,0XF8,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFE,0X03,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XFC,0X07,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XF8,0X0F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0X1F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XE0,0X3F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XC0,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- 0XFF,0XC0,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
- #endif /* FONTS_AP_29DEMO_H_ */
8、主文件:
- * [url=home.php?mod=space&uid=1307177]@File[/url] : main.c
- * [url=home.php?mod=space&uid=159083]@brief[/url] : Main program body
- * [url=home.php?mod=space&uid=1020061]@attention[/url] *
- * Copyright (c) 2023 STMicroelectronics.
- * All rights reserved.
- * This software is licensed under terms that can be found in the LICENSE file
- * in the root directory of this software component.
- * If no LICENSE file comes with this software, it is provided AS-IS.
- #include "main.h"
- #include "stm32c0xx_hal.h"
- #include "Ap_29demo.h"
- I2C_HandleTypeDef hi2c1;
- UART_HandleTypeDef huart1;
- void SystemClock_Config(void);
- static void MX_GPIO_Init(void);
- static void MX_USART1_UART_Init(void);
- static void MX_I2C1_Init(void);
- #if defined (__ICCARM__) || defined (__ARMCC_VERSION)
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #elif defined(__GNUC__)
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #endif
- unsigned char BlackImage[4736];
- * @brief The application entry point.
- * @retval int
- int main(void)
- unsigned char fen_L,fen_H,miao_L,miao_H;
- uint8_t txbuf[] = "HELLO WORLD!\r\n";
- uint8_t buf[20] = {0};
- float temp_f, humi_f;
- HAL_Init();
- SystemClock_Config();
- MX_GPIO_Init();
- MX_USART1_UART_Init();
- MX_I2C1_Init();
- SHT20_Init();
- HAL_UART_Transmit(&huart1, txbuf, sizeof(txbuf), 1000);
- EPD_GPIO_Init();
- Paint_NewImage(BlackImage, 128, 296, 270, WHITE);
- Paint_SelectImage(BlackImage);
- while (1)
- /************Normal picture display*******************/
- EPD_HW_Init();
- EPD_HW_Init();
- EPD_WhiteScreen_White();
- EPD_DeepSleep();
- HAL_Delay(2);
- EPD_HW_Init();
- EPD_SetRAMValue_BaseMap(gImage_basemap);
- for(fen_H=0;fen_H<6;fen_H++)
- for(fen_L=0;fen_L<10;fen_L++)
- for(miao_H=0;miao_H<6;miao_H++)
- for(miao_L=0;miao_L<10;miao_L++)
- EPD_Dis_Part_myself(48,90,(unsigned char *)&Num[miao_L],
- 48,122,(unsigned char *)&Num[miao_H],
- 48,162,(unsigned char *)gImage_numdot,
- 48,204,(unsigned char *)&Num[fen_L],
- 48,236,(unsigned char *)&Num[fen_H],32,64);
- if((fen_L==5)&&(miao_H==0)&&(miao_L==9))
- goto Clear;
显示效果:
播放器加载失败: 未检测到Flash Player,请到 安装
WeChat_20230411193445
