3914|5
75
求助:关于windows mobile5的gprs上网,ppp协商过程失败 [复制链接]
每次协商过程都是一样的,分析ppp协议,好像每次都是被基站拒绝,以后窜口就没有反应了。
打印信息如下:
default : Other RIL_ APIs
IOCTL_RIL_SETGPRSCONTEXT
RilDrv: Sending cmd: AT+CGDCONT=1,"IP","cmnet","",0,0
710MUX: Chnl COM7:: -> send UIH
ParseRecBytes: Accumulated response: ~?cr>OK
710MUX: Chnl COM7:: -> rec UIH
RilDrv: Accumulated response: OK
IOCTL_RIL_GETNEXTNOTIFICATION
IOCTL_RIL_DELETEREQUESTEDQUALITYOFSERVICE
RilDrv: Sending cmd: AT+CGQREQ=1
IOCTL_RIL_DELETEMINIMUMQUALITYOFSERVICE
RilDrv: Sending cmd: AT+CGQMIN=1
IOCTL_RIL_SETGPRSCONTEXTACTIVATED
IOCTL_RIL_ENTERGPRSDATAMODE
RilDrv: Sending cmd: ATD*99***1#
ParseRecBytes: Accumulated response: ~  ?cr>+CGREG:
ParseRecBytes: Accumulated response:  1,"27A0","1177"@~~?cr>+CR: GPRS邁~镢崻~~?cr>CONNECT
710MUX: Chnl COM9:: -> rec UIH
710MUX: Chnl Ctrl: -> rec UIH
710MUX: Chnl COM7:: -> modem status 0x8c
710MUX: Chnl Ctrl: -> send UIH
RilDrv: Accumulated response: +CR: GPRSCONNECT
RilDrv: Accumulated response: CONNECT
IOCTL_RIL_GETSERIALPORTHANDLEFROMCONTEXTID
RILDrv_GetSerialPortHandleFromContextID,DataPort=COM9:
710MUX: Chnl COM9:: -> send UIH
ParseRecBytes: Accumulated response: ~  飣^?}]#?}]
ParseRecBytes: Accumulated response: !}] }] }].}]"}]&}] }] }] }] }]'}]"}](}]"?}^@~
ParseRecBytes: Accumulated response: ]"}] }] }].}]"}]&}] }] }] }] }]'}]"}](}]"悴}^@~
ParseRecBytes: Accumulated response: ~  飣^?!
ParseRecBytes: Accumulated response: ~  飣^?W
ParseRecBytes: Accumulated response: ~  飣^!E
ParseRecBytes: Accumulated response: t0`滊艔?鹽^@~
ParseRecBytes: Accumulated response: t0`滊艔?}^@~
ParseRecBytes: Accumulated response: l鶀33j}]^檩}^@~
ParseRecBytes: Accumulated response: l鶀33j}]^?}^@~
ParseRecBytes: Accumulated response: l鶀33j}]^猫}^@~
ParseRecBytes: Accumulated response: ;}^@~
IOCTL_RIL_GETSIGNALQUALITY
RilDrv: Sending cmd: AT+CSQ
什么呀  详情 回复 发表于 2008-5-1 09:23
86
是想接分,也想学习
要学习,就需要可用分
要可用分,就得支持、解答
我想学习,所以希望有更多的大侠解答和关注各个问题
所以我只好大力顶帖!
希望每一帖都在头条^_^
所以,我顶完这帖顶那帖!
我也想知道,正在找這方面的資料~~~~~
什么呀
63
这只是AT命令,没看到PPP哪里失败了。
84
什么呀
站长推荐上一条 2/10 下一条
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
