2808|4
75
请教一个WINCE的问题: [复制链接]
  各位朋友是这样的:WINCE控制面板里的程序一打开,为什么它们的窗口大小和我们的屏幕的大小不一致呢?怎么样可以让它们和我们的屏幕大小一致辞呢?
此帖出自WindowsCE论坛
This function changes the size, position, and z-order of a child, pop-up, or top-level window. Child, pop-up, and top-level windows are ordered according to their appearance on the screen. The topmost window receives the highest rank and is the first window in the z-order. Syntax BOOL SetWindowPos(   HWND hWnd,   HWND hWndInsertAfter,   int X,   int Y,   int cx,   int cy,   UINT uFlags ); Parameters hWnd [in] Handle to the window. hWndInsertAfter [in] Handle to the window to precede the positioned window in the z-order. This parameter must be a window handle or one of the following values. Value  Description   HWND_BOTTOM Places the window at the bottom of the z-order. If the hWnd parameter identifies a topmost window, the window loses its topmost status and is placed at the bottom of all other windows. HWND_NOTOPMOST Places the window above all non-topmost windows (that is, behind all topmost windows). This flag has no effect if the window is already a non-topmost window. This value is not supported in Windows CE 1.0 and 1.01. HWND_TOP Places the window at the top of the z-order. HWND_TOPMOST Places the window above all non-topmost windows. The window maintains its topmost position even when it is deactivated. This value is not supported in Windows CE 1.0 and 1.01. For more information about how this parameter is used, see the Remarks section. X [in] Specifies the new position of the left side of the window, in client coordinates. Y [in] Specifies the new position of the top of the window, in client coordinates. cx [in] Specifies the new width of the window, in pixels. cy [in] Specifies the new height of the window, in pixels. uFlags [in] Specifies the window sizing and positioning flags. This parameter can be a combination of the following values. Value  Description   SWP_DRAWFRAME Draws a frame (defined in the window's class description) around the window. This value is not supported in Windows CE 1.0 and 1.01. SWP_FRAMECHANGED Causes the operating system to recalculate the size and position of the windows client area, even if the window size is not being changed. If this flag is not specified, the client area is recalculated only when the size or position of the window changes. SWP_HIDEWINDOW Hides the window. SWP_NOACTIVATE Does not activate the window. If this flag is not set, the window is activated and moved to the top of either the topmost or non-topmost group (depending on the setting of the hWndInsertAfter parameter). SWP_NOCOPYBITS Discards the entire contents of the client area. If this flag is not specified, the valid contents of the client area are saved and copied back into the client area after the window is sized or repositioned. This value is not supported in Windows CE 2.10 and later. SWP_NOMOVE Retains the current position (ignores the X and Y parameters). SWP_NOOWNERZORDER Does not change the owner window's position in the z-order. SWP_NOREPOSITION Same as the SWP_NOOWNERZORDER flag. SWP_NOSIZE Retains the current size (ignores the cx and cy parameters). SWP_NOZORDER Retains the current z-order (ignores the hWndInsertAfter parameter). SWP_SHOWWINDOW Displays the window. Return Value Nonzero indicates success. Zero indicates failure. To get extended error information, call GetLastError. Remarks If the specified window is a visible top-level window and the SWP_NOACTIVATE flag is not specified, this function activates the window. If the window is the currently active and the SWP_HIDEWINDOW flag is specified, the activation is passed on to another visible top-level window. A window can be made a topmost window either by setting the hWndInsertAfter parameter to HWND_TOPMOST and ensuring that the SWP_NOZORDER flag is not set, or by setting a window's position in the z-order so that it is above any existing topmost windows. When a non-topmost window is made topmost, its owned windows are also made topmost. Its owners, however, are not changed. If neither the SWP_NOACTIVATE nor SWP_NOZORDER flag is specified (that is, when the application requests that a window be simultaneously activated and its position in the z-order changed), the value specified in hWndInsertAfter is used only in the following circumstances. Neither the HWND_TOPMOST nor HWND_NOTOPMOST flag is specified in hWndInsertAfter. The window identified by hWnd is not the active window. When you set the SWP_FRAMECHANGED flag in the nFlags parameter to this function, Windows Embedded CE redraws the entire non-client area of the window, which may change the size of the client area. This is the only way to get the non-client area to be recalculated and is typically used after you have changed the window style by calling SetWindowLong. If the SWP_SHOWWINDOW or SWP_HIDEWINDOW flag is set, the window cannot be moved or sized. If you have changed certain window data using SetWindowLong, you must call SetWindowPos to have the changes take effect. Use the following combination for uFlags: SWP_NOMOVE | SWP_NOSIZE | SWP_NOZORDER | SWP_FRAMECHANGED. SetWindowPos always causes a WM_WINDOWPOSCHANGED message to be sent to the window. The flags passed in this message are exactly the same as those passed into the function. No other messages are sent by this function. If an owned window was created with the WS_OVERLAPPED style, SetWindowPos uses the parent window coordinates to reposition it. If the owned window was created using the WS_POPUP style, it is repositioned using screen coordinates. An application cannot activate an inactive window without also bringing it to the top of the z-order. Applications can change an activated window's position in the z-order without restrictions, or it can activate a window and then move it to the top of the topmost or non-topmost windows. If a topmost window is repositioned to the bottom (HWND_BOTTOM) of the z-order or after any non-topmost window, it is no longer topmost. When a topmost window is made non-topmost, its owners and its owned windows are also made non-topmost windows. A non-topmost window can own a topmost window, but the reverse cannot occur. Any window (for example, a dialog box) owned by a topmost window is itself made a topmost window, to ensure that all owned windows stay above their owner. If an application is not in the foreground, and should be in the foreground, it must call the SetForegroundWindow function. Requirements OS Versions: Windows CE 1.0 and later. Header: Winuser.h.  详情 回复 发表于 2008-5-27 16:07
控制面板里的程序有两种大小,240x320,640x480,编译的时候选择 Quater VGA Resources(User interface下面)就是240x320
没试过自定义大小
此帖出自WindowsCE论坛
64
不太明白。
此帖出自WindowsCE论坛
82
不行呀,加了了就超过了屏幕高度了,不加,就会超过屏幕宽度!
此帖出自WindowsCE论坛
49
Syntax
BOOL SetWindowPos(
  HWND hWnd,
  int X,
  int Y,
  int cx,
  int cy,
  UINT uFlags
Parameters
hWnd
hWndInsertAfter
Value  Description
HWND_BOTTOM
HWND_NOTOPMOST
HWND_TOP
HWND_TOPMOST
X
Y
cx
cy
uFlags
Value  Description
SWP_DRAWFRAME
SWP_FRAMECHANGED
SWP_HIDEWINDOW
Hides the window.
SWP_NOACTIVATE
SWP_NOCOPYBITS
SWP_NOMOVE
SWP_NOOWNERZORDER
SWP_NOREPOSITION
SWP_NOSIZE
SWP_NOZORDER
SWP_SHOWWINDOW
Return Value
Remarks
Requirements
Header: Winuser.h.
此帖出自WindowsCE论坛
