460|0
LT8644EX HDMI 4*4/8*8/16*16国产矩阵方案首选 [复制链接]
< class="p" align="justify" >LT8644
< class="p" align="justify" style="">1. General Description
< class="p" align="justify" style="">The LT8644 is a 16×16 digital crosspoint switch, with 16 differential CML compatible inputs and 16 differential CML outputs. The LT8644 is optimized for nonreturn-to-zero (NRZ) signaling with data rates of up to 3.4 Gbps per port. Each port offers programmable level of input equalization and programmable output swing. The LT8644 supports independent channel switching through the serial control interface. The LT8644 has low latency and very low channel-to-channel skew. An I2C interface is used to control the device and provide access to advanced features.
< class="p" align="justify" style="">2. FEATURES
< class="p" align="justify" style="">• DC to 3.4 Gbps per port NRZ data rate
• Programmable receive equalization
• DC- or AC-coupled differential CML inputs
• DC- or AC-coupled differential CML outputs
• Programmable CML output levels
• 50Ω on-chip I/O termination
• Supports 8b/10b, scrambled or uncoded NRZ data
• I2C slave control interface
• ESD rating: HBM at ±7kV
< class="p" align="justify" style="">3. APPLICATIONS
< class="p" align="justify" style="">• Fiber optic network switching
• Digital video (HDMI, DVI, Display Port)
• Data storage networks
推荐帖子
关于运放的基础细节探索
本人新手,如有不对请老师们赐教。 前两天发了个帖子,原以为讨论USB接口,没想到最终是回到如何使用运放的问题上,特别是得到 ...
电压调整电路
37465那位大虾能帮我讲解一下这个电路,谢谢了
基于STM8S103的USB移动电源的全套资料【程序+原理图+PCB】
贡献一份基于STM8S103的USB移动电源的全套资料,资料包括【程序】+【原理图】+【PCB】+【原理图PDF】,原理图和PCB是用AD画的 ...
Helper2416开发板移植minigui3.0.12之一:让PC运行minigui
本帖最后由 Gyroxp 于 2015-1-25 11:30 编辑 笔者最近有时间学习嵌入式linux,于是熟悉了一下基本操作之后,选定了移植minigu ...
【跑步姿势训练鞋】No.007-自发电功能研究
本帖最后由 sipower 于 2021-6-27 03:09 编辑 上一篇介绍了蓝牙通讯程序的设计过程,这一片介绍自发电功能研究。这个可能也是 ...
MOS管在开启后的工作状态问题
MOS在开启后,是不是Rds的电阻不受Vds的电压影响吗,也就是说即使Vds=0V时,Rds的电阻和工作时的Vds电压的情况下Rds基本变化不大 ...
Fill填充块敷铜危害!
分享一个制板厂家反馈的经验 运用Fill敷铜会造成板子开路和短路及无法生成GerBer(光绘文件),正确的Layout布线请采用多 ...
STM32F103SPI工作频率的问题
我的开发板是8兆晶振 时钟配置如下: void RCC_Configuration(void) { ErrorStatus HSEStartUpStatus; ...
模拟电子系统设计指南(实践篇)
本书从半导体器件、专用集成电路和系统设计三个角度全面系统的介绍了模拟电子线路的分析和设计方法。内容包括:模拟电子技术导论 ...
供电LDO的选择
我现在需要一个3.3V和一个2.5V供电,之前的设计方案中是使用LDO分别提供这两种电压,现在我想要通过3.3V串联分压电阻得到2.5V输 ...
