2253|1
83
SIRIUS 无线模块 [复制链接]
SIRIUS  ISR3500介绍:
#        Technical info        "Siriusisr35xx" 1        Chipset Solution        "Infineon E-GOLDvoice(PMB7880)" 2        Core processor        26MHz MCU, 16-bit 3        Cellular Radio        "Dual Band (850/1900MHz, 900/1800MHz)" 4        Cellular Data        GSM / GPRS class 10 5        Cellular Voice        Speech Codec (EFR/FR/HR/AMR) 6        Dimension (mm)        28.0 x 26.8  x 2.7 7        Weight (gram)        2.4 8        Plug-in connector        80pin B2B Connector 9        RF connector         MHF series receptacle 10        Supply Voltage        "3.4V - 4.2V,Nominal: 3.8V" 11        Output Power        "Class 4(2W) at 850/900 MHz,Class 1(1W) at 1800/1900 MHz" 12        Rx Sensitivity        "-110dBm at 850/900 MHz, -109dBm at 1800/1900 MHz" 13        Power consumption        "Power off < 400μA,Idle mode < 4mA,Call Average   详情 回复 发表于 2010-3-1 12:43
7        Weight (gram)        2.4
13        Power consumption        "Power off < 400μA,Idle mode < 4mA,Call Average <300mA,Transient Max < 1.6A,Sleep mode < 2.0mA"
14        Operating Temperature        -20°C ~ 55°C
15        Interfaces        "8 bits parallel bus,SSC / SPI interface,UART (115.2kbps),
I2C bus,Keypad interface,LCD interface,SIM card interface,1 Open ADC,"
16        Configurable GPIO pins        27
17        Supported battery type        Ni-MH & Li-ion
18        Fax data        Class 2
19        SIM Toolkit        release 99, Class 3
20        AT Commands        "GSM 07.07 AT command Sets + proprietary AT commands +
Extended TCPIP (HTTP, FTP, SOCKET, etc)"
