231|0
亚马逊加拿大玩具SOR/2011-17认证CCPSA办理要多久玩具加拿大亚马逊平台审核 [复制链接]
亚马逊加拿大玩具SOR/2011办理需要多久玩具加拿大亚马逊平台审核
卖家邮件如下:
Testreport from an ISO 17025-accredited testing laboratory confirming that each product was tested and meets these requirements, if applicable: Canada Toys Regulations(SOR/2011-17), Consumer Products Containing Lead Regulations (SOR/2018-83), Phthalates Regulations(SOR/2016-188), Surface Coating Materials Regulations(SOR/2016-193), Small Parts Warning, Age Grading and Applicable Warning Labels.
The document must meet the following requirements:
Must be issued by a ISO 17025-accredited testing laboratory
Must show passing test results for all applicable Canadian toy standards
测试内容介绍:
SOR/2011-17物理机械参考ASTM F963-1/EN71-1
SOR/2018-83总铅含量测试参考ASTM F963 sec 8.3
SOR/2016-188邻苯二盐(8P)参考CPSC-CH-C1001-09.4
SOR/2016-193涂层中铅含量参考CPSC-CH-E1003-09.1
Small Parts Warning: 3岁以上使用需要标注小部件警示语
Age Grading:需要在包装上体现适用年龄段
Applicable Warning Labels :比如小部件警示语,不同产品警示属性不一样。
SOR/2011-17(玩具)和 SOR/2016-188(邻苯二甲酸盐)、SOR/2016-193(表面涂层)、SOR/2018-83(铅)(如适用)和小零件警告
SOR/2011-17测试周期一般在收到样品后:5-7个工作日内完成
