RVB2601驱动MPU6050陀螺仪模块
陀螺仪中4根针脚,VCC,GND,SCL,SDA分别接入RVB2601的3.3,GND,PA8,PA9中
.c代码如下:
#include "mpu6050.h"
#include <drv/iic.h>
#include <aos/aos.h>
#include <drv/pin.h>
#include <math.h>
#define IIC_IDX 0
static csi_iic_t master_iic;
static aos_timer_t mpu_timer;//定时器
int16_t rawAccX=0,rawAccY=0,rawAccZ=0,rawGyroX=0,rawGyroY=0,rawGyroZ=0;//6项原始数据
float angleX=0, angleY=0, angleZ=0;
float angleAccX=0,angleAccY=0; //由mpu6050_tockn加计算的加速度角度
float gyroX, gyroY, gyroZ;
//float gyroXoffset=0,gyroYoffset=0,gyroZoffset=0;
int iic_init(void)
csi_error_t ret;
csi_pin_set_mux(PA8, PA8_IIC0_SCL);
csi_pin_set_mux(PA9, PA9_IIC0_SDA);
ret = csi_iic_init(&master_iic, IIC_IDX);
if (ret != CSI_OK) {
printf("csi_iic_initialize error\n");
return -1;
/* config iic master mode */
ret = csi_iic_mode(&master_iic, IIC_MODE_MASTER);
printf("csi_iic_set_mode error\n");
return -1;
/* config iic 7bit address mode */
ret = csi_iic_addr_mode(&master_iic, IIC_ADDRESS_7BIT);
printf("csi_iic_set_addr_mode error\n");
return -1;
/* config iic standard/fast speed*/
ret = csi_iic_speed(&master_iic, IIC_BUS_SPEED_FAST);//IIC_BUS_SPEED_STANDARD);
printf("csi_iic_set_speed error\n");
return -1;
return 0;
//写寄存器
void MPU6050_WriteReg(uint8_t REG_Address, uint8_t REG_data)
uint8_t buf[2];
buf[0]=REG_Address;
buf[1]=REG_data;
csi_iic_master_send(&master_iic, SLAVE_ADDR, buf, 2, 100);
//读寄存器
void MPU6050_ReadReg(uint8_t REG_Address)
uint8_t buf;
buf=REG_Address;
csi_iic_master_send(&master_iic, SLAVE_ADDR, &buf, 1, 100);
//读数据
int16_t MPU6050_ReadData(uint8_t REG_Address)
uint8_t H,L;
uint8_t buf[2]={0,0};
MPU6050_ReadReg(REG_Address);
csi_iic_master_receive(&master_iic, SLAVE_ADDR, buf, 2, 100);
H=buf[0];
L=buf[1];
return (H<<8)|L;
void MPU6050_Get_Data()
float accX, accY, accZ;
// float homeAccX,homeAccY;
//6项原始数据
rawAccX = MPU6050_ReadData(ACCEL_XOUT_H);
rawAccY = MPU6050_ReadData(ACCEL_YOUT_H);
rawAccZ = MPU6050_ReadData(ACCEL_ZOUT_H);
rawGyroX = MPU6050_ReadData(GYRO_XOUT_H);
rawGyroY = MPU6050_ReadData(GYRO_YOUT_H);
rawGyroZ = MPU6050_ReadData(GYRO_ZOUT_H);
//计算重力加速度的g数
accX = ((float)rawAccX) / 16384.0;//+-2g,65536/4=16384
accY = ((float)rawAccY) / 16384.0;
accZ = ((float)rawAccZ) / 16384.0;
//角速度
gyroX = ((float)rawGyroX) / 65.536;//+-500
gyroY = ((float)rawGyroY) / 65.536;
gyroZ = ((float)rawGyroZ) / 65.536;
//由重力加速度计算X、Y轴的角度,tockn库
angleAccX = atan2(accY, accZ + abs(accX)) * RAD_TO_DEG;//360 / 2.0 / PI;
angleAccY = -atan2(accX, accZ + abs(accY)) * RAD_TO_DEG;
//angleAccY += MPU_OFFSET_Y;
angleAccY += 1.15;//此参数为陀镙仪固定在小车上的角度物理误差,根据经验调整
// gyroX -= gyroXoffset;
// gyroY -= gyroYoffset;
// gyroZ -= gyroZoffset;
// //平衡小车之家的融合算法
// homeAccX = 0;
// homeAccY = -atan2((float)rawAccX, (float)rawAccZ) * RAD_TO_DEG;
// homeAccY+=MPU_OFFSET_Y;
// homeX = 0.02 * homeAccX + 0.98 * (homeX + gyroX * 0.01);
// homeY = 0.02 * homeAccY + 0.98 * (homeY + gyroY * 0.01);
//tockn库角度融合算法,上次的角度+10ms的角速度占98%,本次的角度占2%
angleX = (0.98f * (angleX + gyroX * 0.01)) + (0.02f * angleAccX);
angleY = (0.98f * (angleY + gyroY * 0.01)) + (0.02f * angleAccY);
angleZ = gyroZ*0.01;
//定时器回调函数
static void timer_mpu6050(void *arg1, void* arg2)
MPU6050_Get_Data();
//pid_car();
static int t=0;
t++;
t%=10;
if(t==0){
printf("%12f,%12f,%12f\r\n",angleX,angleY,angleZ);
void mpu6050_init()
iic_init();//初始化iic总线
MPU6050_WriteReg(SMPLRT_DIV, 0x00); //陀螺仪125hz
MPU6050_WriteReg(CONFIG, 0x00); //21HZ滤波 延时A8.5ms G8.3ms 此处取值应相当注意,延时与系统周期相近为宜
MPU6050_WriteReg(GYRO_CONFIG, 0x08); //陀螺仪 0x00为+-250 0x08为+-500 0x10为+-1000 0x18为+-2000度
MPU6050_WriteReg(ACCEL_CONFIG, 0x00);//加速度 0x00为+-2g 0x08为+-4g 0x10为+-8g 0x18为+-16g
MPU6050_WriteReg(PWR_MGMT_1, 0x01); //解除休眠状态
aos_timer_new(&mpu_timer, timer_mpu6050, NULL, 10, 1);//10ms定时器
.h文件的代码如下:
#ifndef _MPU6050_H_
#define _MPU6050_H_
#include <stdio.h>
#define PI 3.141593
#define RAD_TO_DEG 57.295779513082320876798154814105
#define SMPLRT_DIV 0x19 //陀螺仪采样率,典型值:0x07(125Hz)
#define CONFIG 0x1A //低通滤波频率,典型值:0x06(5Hz)
#define GYRO_CONFIG 0x1B //陀螺仪自检及测量范围,典型值:0x18(不自检,2000deg/s)
//bit3 bit4为量程调节 0:+-250度/s 1:+=500 2:+-1000 3:+-2000度
//0x00为+-250 0x08为+-500 0x10为+-1000 0x18为+-2000度
#define ACCEL_CONFIG 0x1C //加速计自检、测量范围及高通滤波频率,典型值:0x01(不自检,2G,5Hz)
#define ACCEL_XOUT_H 0x3B // 存储最近的X轴、Y轴、Z轴加速度感应器的测量值
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
#define TEMP_OUT_H 0x41 // 存储的最近温度传感器的测量值
#define TEMP_OUT_L 0x42
#define GYRO_XOUT_H 0x43 // 存储最近的X轴、Y轴、Z轴角速度感应器的测量值
#define GYRO_XOUT_L 0x44
#define GYRO_YOUT_H 0x45
#define GYRO_YOUT_L 0x46
#define GYRO_ZOUT_H 0x47
#define GYRO_ZOUT_L 0x48
#define PWR_MGMT_1 0x6B //电源管理,典型值:0x00(正常启用)
#define WHO_AM_I 0x75 //IIC地址寄存器(默认数值0x68,只读)
#define SLAVE_ADDR 0x68
#define SLAVE_ADDRWT 0xD0 //IIC写入时的地址字节数据,(0x68<<1)表示写
#define SLAVE_ADDRRD 0xD1 //IIC写入时的地址字节数据,(0x68<<1)|1表示读
extern int16_t rawAccX,rawAccY,rawAccZ,rawGyroX,rawGyroY,rawGyroZ;//6项原始数据
extern float angleX, angleY, angleZ;//+-90.0
extern float gyroX, gyroY, gyroZ;//+-500
void mpu6050_init();
void MPU6050_Get_Data();
#endif
主函数中调用mpu6050_init();即可
这样,你的串口调试助手中会不断的打印出陀螺仪的角度了。。。
当然也可以打印到OLED屏中,用曲线的形式
728fd92fe466af5cfe8033cc689ba53c
