【GD32F310G-START】ADC获取片内温度并显示
【GD32F310G-START】HELLO WORLD - GD32 MCU - 电子工程世界-论坛 (eeworld.com.cn)
【GD32F310G-START】OLED之HELLO EEWORLD——硬件I2C - GD32 MCU - 电子工程世界-论坛
【GD32F310G-START】SPI驱动ST7735 - GD32 MCU - 电子工程世界-论坛 (eeworld.com.cn)
【GD32F310G-START】硬件SPI驱动ST7735 - GD32 MCU - 电子工程世界-论坛 (eeworld.com.cn)
adc 是常用的外设之一,今天根据例程获取片内温度值,并用LCD屏显示:
1、初始化ADC:
\brief 初始化ADC
\param[in] none
\param[out] none
\retval none
void my_adc_init(void)
/* 开启时ADC时钟 */
rcu_periph_clock_enable(RCU_ADC);
/* config ADC clock */
rcu_adc_clock_config(RCU_ADCCK_APB2_DIV6);
/* ADC channel length config */
adc_channel_length_config(ADC_INSERTED_CHANNEL, 2U);
/* ADC temperature sensor channel config */
adc_inserted_channel_config(0U, ADC_CHANNEL_16, ADC_SAMPLETIME_239POINT5);
/* ADC internal reference voltage channel config */
adc_inserted_channel_config(1U, ADC_CHANNEL_17, ADC_SAMPLETIME_239POINT5);
/* ADC trigger config */
adc_external_trigger_source_config(ADC_INSERTED_CHANNEL, ADC_EXTTRIG_INSERTED_NONE);
/* ADC data alignment config */
adc_data_alignment_config(ADC_DATAALIGN_RIGHT);
/* ADC SCAN function enable */
adc_special_function_config(ADC_SCAN_MODE, ENABLE);
/* ADC temperature and Vrefint enable */
adc_tempsensor_vrefint_enable();
adc_external_trigger_config(ADC_INSERTED_CHANNEL, ENABLE);
/* enable ADC interface */
adc_enable();
delay_1ms(1U);
/* ADC calibration and reset calibration */
adc_calibration_enable();
2、获取温度:
float get_gd32f310g_temper(void)
float temperature;
adc_software_trigger_enable(ADC_INSERTED_CHANNEL);
/* value convert */
temperature = (1.45f - ADC_IDATA0 * 3.3f / 4096) * 1000 / 4.3f + 25;
return temperature;
3、在主循环里获取温度并刷到LCD屏上:
main.c
#include "gd32f3x0.h"
#include "gd32f310g_eval.h"
#include "my_i2c.h"
#include "systick.h"
#include "ssd1306.h"
#include "lcd.h"
#include "lcd_init.h"
#include "adc.h"
uint8_t i2c_transmitter[16];
\brief main function
\param[in] none
\param[out none
\retval none
int main(void)
float temper_val;
uint8_t str_temper[10];
systick_config();
// my_i2c0_init();
// oled_display_test();
LCD_Init();//LCD初始化
LCD_Fill(0,0,LCD_W,LCD_H,BLUE);
LCD_ShowString(12,0,"GD32F320G",WHITE,BLUE,32,0);
LCD_ShowString(18,36,"EEWORDL",WHITE,BLUE,32,0);
LCD_ShowString(16,72,"2022-5-7",BLACK,BLUE,32,0);
LCD_ShowString(12,100,"gd32f310g_adc_demo",RED,BLUE,16,0);
my_adc_init();
/* infinite loop */
while(1)
temper_val = get_gd32f310g_temper();
sprintf(str_temper,"T:%.2f ",temper_val);
LCD_ShowString(18,36,str_temper,WHITE,BLUE,32,0);
delay_1ms(500);
显示效果:
【总结】通过ADC的例程可以轻松的搞定,但是片内温度只反映MCU的温度,跟外环境的温度不成正比,所以还外用外置传感器来获取温度才行。
