2524|3
7044
【GD32F310G-START】OLED之HELLO EEWORLD——硬件I2C [复制链接]
【GD32F310G-START】HELLO WORLD - GD32 MCU - 电子工程世界-论坛 (eeworld.com.cn)
继串口驱动,经过一晚的劳累,终于驱动了硬件I2C,用实战SSD1306向大家提交了工程:
硬件I2C的实初始化分三步
1、开启GPIO以及I2C0的时钟:
  \brief enable the peripheral clock
  \param[in] none
  \param[out] none
  \retval none
static void rcu_config(void)
    /* enable GPIOB clock */
    rcu_periph_clock_enable(RCU_GPIOB);
    /* enable I2C0 clock */
    rcu_periph_clock_enable(RCU_I2C0);
2、配置IO的输出:
  \brief configure the GPIO ports
  \param[in] none
  \param[out] none
  \retval none
static void gpio_config(void)
    /* connect PB6 to I2C0_SCL */
    gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_6);
    /* connect PB7 to I2C0_SDA */
    gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_7);
    /* cofigure GPIO pins of I2C0 */
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_6);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_7);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, GPIO_PIN_7);
3、配置I2c的输出模式、从机地址等
  \brief   configure the I2C0 and I2C1 inter faces
  \param[in] none
  \param[out] none
  \retval none
static void i2c_config(void)
    /* I2C clock configure */
    i2c_clock_config(I2C0, 100000, I2C_DTCY_2);
    /* I2C address configure */
    i2c_mode_addr_config(I2C0, I2C_I2CMODE_ENABLE, I2C_ADDFORMAT_7BITS, I2C0_SLAVE_ADDRESS7);
    /* enable I2C0 */
    i2c_enable(I2C0);
    /* enable acknowledge */
    i2c_ack_config(I2C0, I2C_ACK_ENABLE);
4、发送数据:
  \brief   I2C0发送数据
  \param[in] 需要发送的buff
  \param[in] 发送数据的长度
  \param[in] 从机地址
  \param[out] 向从机发送len长度的数据
  \retval none
void i2c0_send(uint8_t *buff, int len, uint16_t slave_address)
  int i;
      /* wait until I2C bus is idle */
    while(i2c_flag_get(I2C0, I2C_FLAG_I2CBSY));
    /* send a start condition to I2C0 bus */
    i2c_start_on_bus(I2C0);
    /* wait until SBSEND bit is set */
    while(!i2c_flag_get(I2C0, I2C_FLAG_SBSEND));
    /* send slave address to I2C bus */
    i2c_master_addressing(I2C0, slave_address, I2C_TRANSMITTER);
    /* wait until ADDSEND bit is set */
    while(!i2c_flag_get(I2C0, I2C_FLAG_ADDSEND));
    /* clear ADDSEND bit */
    i2c_flag_clear(I2C0, I2C_FLAG_ADDSEND);
    /* wait until the transmit data buffer is empty */
    while(!i2c_flag_get(I2C0, I2C_FLAG_TBE));
    for(i = 0; i < len; i++)
        /* data transmission */
        i2c_data_transmit(I2C0, buff[i]);
        /* wait until the TBE bit is set */
    /* send a stop condition to I2C bus */
    i2c_stop_on_bus(I2C0);
    while(I2C_CTL0(I2C0) & 0x0200);
昨天是根据GD其他的库一个字一个字的输了一遍,对I2C的初始化、使用等印象又深了一步,我发现呀,如果有时间,还是得自己输一次,既使是抄别人的。
然后我再写了一遍SSD1306的驱动。现在展示如下:
工程包转上来给大家: Template-i2c.7z (487.27 KB, 下载次数: 20)
以前总是想抄一下作业,然后可以用就行了,现在想呀,不要CTRL+C,CTRL+V。一个一个字敲了,印象才深。不过就是费时间,昨天一不小心就到了12点,漏了一句,示波器、分析仪都没找出来,一晚睡不着,早上6点起来继续,清醒才找到原因:一个stop信号没给。。。
唉,实属不易,大家给点个赞吧,下面入手SPI。
此帖出自GD32 MCU论坛
辛苦辛苦,注意劳逸结合。点赞。   详情 回复 发表于 2022-5-6 09:34
2853
管理员
给你点个大赞!注意身体呀,晚上还是要早点休息,别太晚了
此帖出自GD32 MCU论坛
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
谢谢关心呀!今天的SPI +LCD是搞不定了,准备早点休息。明天继续。  详情 回复 发表于 2022-5-5 21:44
7044
okhxyyo 发表于 2022-5-5 21:39 给你点个大赞!注意身体呀,晚上还是要早点休息,别太晚了
此帖出自GD32 MCU论坛
管理员
辛苦辛苦,注意劳逸结合。点赞。
此帖出自GD32 MCU论坛
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
加油!在电子行业默默贡献自己的力量!:)
