Introduction
The co-ordinate rotation digital computer (CORDIC) reference design implements the CORDIC algorithm, which converts cartesian to polar coordinates and vice versa and also allows vectors to be rotated through a given angle.
CORDIC is an iterative process, using a series of shifts and adds. Hence it is often a hardware efficient solution over using multiplications, division and square roots.
The reference design comprises a MATLAB bit accurate model of the CORDIC algorithm implemented in hardware and a GUI test environment. The test environment allows you to configure the CORDIC reference design and test conditions and to compare the results with the theoretical results.
Altera provides separately the encrypted Verilog HDL source code, precompiled simulation files for the ModelSim simulator, and a testbench for the hardware implementation of CORDIC.
