4712|13
帮忙看以下 这个GPIO驱动。。为什么我测不到波形了? [复制链接]
#include
#include "GpioDriver.h"
#include "stdafx.h"
typedef struct _GPIO{
        volatile unsigned int        PORTCFG0;                // 0x000 R/W Port Configuration Register 0
        volatile unsigned int        PORTCFG1;                 // 0x004 R/W Port Configuration Register 1
        volatile unsigned int        PORTCFG2;                // 0x008 R/W Port Configuration Register 2
        volatile unsigned int        PORTCFG3;                // 0x00C R/W Port Configuration Register 3
        volatile unsigned int        PORTCFG4;                // 0x010 R/W Port Configuration Register 4
        volatile unsigned int        PORTCFG5;                // 0x014 R/W Port Configuration Register 5
        volatile unsigned int        PORTCFG6;                // 0x018 R/W Port Configuration Register 6
        volatile unsigned int        PORTCFG7;                // 0x01C R/W Port Configuration Register 7
        volatile unsigned int        PORTCFG8;                // 0x020 R/W Port Configuration Register 8
        volatile unsigned int        PORTCFG9;                // 0x024 R/W Port Configuration Register 9
        volatile unsigned int        PORTCFG10;        // 0x028 R/W Port Configuration Register 10
        volatile unsigned int        PORTCFG11;        // 0x02C R/W Port Configuration Register 11
        volatile unsigned int        PORTCFG12;        // 0x030 R/W Port Configuration Register 12
        volatile unsigned int        PORTCFG13;        // 0x034 R/W Port Configuration Register 13
        volatile unsigned int        NOTDEFINE0;        // 0x038 -
        volatile unsigned int        NOTDEFINE1;        // 0x03C -
        volatile unsigned int        GPADAT;                // 0x040 R/W 0x00000000 GPA Data Register
        volatile unsigned int        GPAEN;                // 0x044 R/W 0x00000000 GPA Output Enable Register
        volatile unsigned int        GPASET;                // 0x048 W - OR function on GPA Output Data
        volatile unsigned int        GPACLR;                // 0x04C W - BIC function on GPA Output Data
        volatile unsigned int        GPAXOR;                // 0x050 W - XOR function on GPA Output Data
        volatile unsigned int        NOTDEFINE2;        // 0x054
        volatile unsigned int        NOTDEFINE3;        // 0x058
        volatile unsigned int        NOTDEFINE4;        // 0x05C
        volatile unsigned int        GPBDAT;                // 0x060 R/W 0x00000000 GPB Data Register
        volatile unsigned int        GPBEN;                // 0x064 R/W 0x00000000 GPB Output Enable Registe
        volatile unsigned int        GPBSET;                // 0x068 W - OR function on GPB Output Data
        volatile unsigned int        GPBCLR;                // 0x06C W - BIC function on GPB Output Data
        volatile unsigned int        GPBXOR;                // 0x070 W - XOR function on GPB Output Data
        volatile unsigned int        NOTDEFINE5;        // 0x074
        volatile unsigned int        NOTDEFINE6;        // 0x078
        volatile unsigned int        NOTDEFINE7;        // 0x07C
        volatile unsigned int        GPCDAT;                // 0x080 R/W 0x00000000 GPC Data Register
        volatile unsigned int        GPCEN;                // 0x084 R/W 0x00000000 GPC Output Enable Register
        volatile unsigned int        GPCSET;                // 0x088 W - OR function on GPC Output Data
        volatile unsigned int        GPCCLR;                // 0x08C W - BIC function on GPC Output Data
        volatile unsigned int        GPCXOR;                // 0x090 W - XOR function on GPC Output Data
        volatile unsigned int        NOTDEFINE8;        // 0x094
        volatile unsigned int        NOTDEFINE9;       // 0x098
        volatile unsigned int        NOTDEFINE10;        // 0x09C
        volatile unsigned int        GPDDAT;                // 0x0A0 R/W 0x00000000 GPD Data Register
        volatile unsigned int        GPDEN;                // 0x0A4 R/W 0x00000000 GPD Output Enable Register
        volatile unsigned int        GPDSET;                // 0x0A8 W - OR function on GPD Output Data
        volatile unsigned int        GPDCLR;                // 0x0AC W - BIC function on GPD Output Data
        volatile unsigned int        GPDXOR;                // 0x0B0 W - XOR function on GPD Output Data
        volatile unsigned int        NOTDEFINE11;        // 0x0B4
        volatile unsigned int        NOTDEFINE12;        // 0x0B8
        volatile unsigned int        NOTDEFINE13;        // 0x0BC
        volatile unsigned int        GPEDAT;                // 0x0C0 R/W 0x00000000 GPE Data Register
        volatile unsigned int        GPEEN;                // 0x0C4 R/W 0x00000000 GPE Output Enable Register
        volatile unsigned int        GPESET;                // 0x0C8 W - OR function on GPE Output Data
        volatile unsigned int        GPECLR;                // 0x0CC W - BIC function on GPE Output Data
        volatile unsigned int        GPEXOR;                // 0x0D0 W - XOR function on GPE Output Data
        volatile unsigned int        NOTDEFINE14[3];   //        0x0D4,0x0D8,0x0DC
        volatile unsigned int        GPFDAT;                  // 0x0E0 R/W 0x00000000 GPF Data Register
        volatile unsigned int        GPFEN;                 //0x0E4 R/W 0x00000000 GPF Output Enable Register
        volatile unsigned int        GPFSET;                 //0x0E8 W - OR function on GPF Output Data
        volatile unsigned int        GPFCLR;                 //0x0EC W - BIC function on GPF Output Data
        volatile unsigned int        GPFXOR;                 //0x0F0 W - XOR function on GPF Output Data
        volatile unsigned int        NOTDEFINE15[3];        //RESERVED 0x0F4 0x0F8 0x0FC
        volatile unsigned int        CPUD0 ;                //0x100 R/W Pull-Up/Down Control Register 0
        volatile unsigned int        CPUD1;                // 0x104 R/W Pull-Up/Down Control Register 1
        volatile unsigned int        CPUD2 ;                //0x108 R/W Pull-Up/Down Control Register 2
        volatile unsigned int        CPUD3 ;                //0x10C R/W Pull-Up/Down Control Register 3
        volatile unsigned int        CPUD4;                // 0x110 R/W Pull-Up/Down Control Register 4
        volatile unsigned int        CPUD5;                // 0x114 R/W Pull-Up/Down Control Register 5
        volatile unsigned int        CPUD6;                // 0x118 R/W Pull-Up/Down Control Register 6
        volatile unsigned int        CPUD7;                 // 0x11C R/W Pull-Up/Down Control Register 7
        volatile unsigned int        CPUD8;                 // 0x120 R/W Pull-Up/Down Control Register 8
        volatile unsigned int        CPUD9 ;                //0x124 R/W Pull-Up/Down Control Register 9
        volatile unsigned int        CPDRV0;                // 0x128 R/W Driver strength Control Register 0
        volatile unsigned int        CPDRV1;                // 0x12C R/W
        volatile unsigned int        AINCFG;                // 0x130 R/W 0x00000000 Analog Input Pad Control Register
        volatile unsigned int        EINTSEL0;                // 0x134 R/W 0x00000000 External Interrupt Select Register 0
        volatile unsigned int        EINTSEL1;                // 0x138 R/W 0x00000000 External Interrupt Select Register 1
        volatile unsigned int        IRQSEL;                // 0x13C R/W 0x00000000 Interrupt Select Register
}GPIO, *PGPIO;
#define IOCTL_GPIO_SET_PIN   0x0000050
#define IOCTL_GPIO_CLR_PIN   0x0000070
#define IOCTL_GPIO_DIS_PIN   0x0000090
//?????÷???????á????
static volatile GPIO * v_pIOPregs;
static int  g_OpenCount = 0;                                      // ?????ò???????÷
#define  BASE_ADDRESS               0xF005A000
#define  ADDRESS_INTERVAL_GPIO                0x04
#define  GPx_GPA                                        0
static BOOL MyGPIO_InitAddresses(void)
        BOOL        RetValue = TRUE;
        //        IO Register Allocation
        v_pIOPregs = (volatile GPIO *)VirtualAlloc(0, sizeof(GPIO), MEM_RESERVE, PAGE_NOACCESS);
        if (v_pIOPregs == NULL)
                ERRORMSG(1,(TEXT("For IOPregs : VirtualAlloc failed!\r\n")));
                RetValue = FALSE;
        else
                if (!VirtualCopy((PVOID)v_pIOPregs, (PVOID)(BASE_ADDRESS >> 8), sizeof(GPIO), PAGE_PHYSICAL | PAGE_READWRITE | PAGE_NOCACHE))
                        ERRORMSG(1,(TEXT("For IOPregs: VirtualCopy failed!\r\n")));
                        RetValue = FALSE;
        if (!RetValue)
                RETAILMSG (1, (TEXT("::: PIO_InitializeAddresses - Fail!!\r\n") ));
                if (v_pIOPregs)
                        VirtualFree((PVOID) v_pIOPregs, 0, MEM_RELEASE);
                v_pIOPregs = NULL;
                RetValue = FALSE;
                return RetValue;
        //?????????÷????GPIOE8
        v_pIOPregs->PORTCFG10 &= ~(0x0f << 12);
        v_pIOPregs->PORTCFG10 |= (0x01 << 12);
        v_pIOPregs->GPEEN |= (0x01 << 8);
        return(RetValue);
DWORD PIO_Init(DWORD dwContext)
        MyGPIO_InitAddresses();
        g_OpenCount = 0;
        return (DWORD)1;
BOOL DllEntry(HINSTANCE hinst_dll, DWORD reason, LPVOID reserved)
    switch (reason) {
    case DLL_PROCESS_ATTACH:
        RETAILMSG(1, (TEXT("[GPIO] Process Attach\r\n")));
        break;
    case DLL_PROCESS_DETACH:
        RETAILMSG(1, (TEXT("[GPIO] Process Detach\r\n")));
        break;
    return TRUE;
BOOL PIO_Close(DWORD Handle)
        g_OpenCount = 0;
    return TRUE;
BOOL PIO_Deinit(DWORD dwContext)
        g_OpenCount = 0;
        if (v_pIOPregs)
                VirtualFree((PVOID) v_pIOPregs, 0, MEM_RELEASE);        /* ??·??ê?????é?????? */
    return TRUE;
DWORD PIO_Open(DWORD dwData, DWORD dwAccess, DWORD dwShareMode)
        if (g_OpenCount > 0)
                return 0;
        g_OpenCount++;
    return g_OpenCount;                                                        /* ·????????????????? */
BOOL GPIO_SetPin(DWORD dwIoControlCode, BYTE PinNum)
        //?è???????????÷??1
        v_pIOPregs->GPESET |=  (0x01 << 8);
        v_pIOPregs->CPUD7 &= ~(0x03 << 30);
        v_pIOPregs->CPUD7 |= (0x01 << 30);
        return TRUE;
BOOL GPIO_ClrPin(DWORD dwIoControlCode, BYTE PinNum)
        //?è???????????÷??0
    v_pIOPregs->GPECLR |=  (0x01 << 8);
        v_pIOPregs->CPUD7 |= (0x02 << 30);
        return TRUE;
BOOL GPIO_Display(DWORD dwIoControlCode, BYTE PinNum)
   v_pIOPregs->PORTCFG10 &= ~(0x01 << 12);
   return TRUE;
BOOL
PIO_IOControl(
    DWORD Handle,
    PBYTE pInBuf,
    DWORD nInBufSize,
    PBYTE pOutBuf,
    DWORD nOutBufSize,
    PDWORD pBytesReturned
        BOOL bErr = FALSE;
        switch(dwIoControlCode)
                case IOCTL_GPIO_SET_PIN:
                    GPIO_SetPin(dwIoControlCode, *pInBuf);
                        break;
                case IOCTL_GPIO_CLR_PIN:
                    GPIO_ClrPin(dwIoControlCode, *pInBuf);
                        break;
                case IOCTL_GPIO_DIS_PIN:
                        GPIO_Display(dwIoControlCode, *pInBuf);
                        break;
    return true;
找到原因了,是因为我再Init里面对配置寄存器做的初始化,然后有可能其他驱动修改了这个值。 感谢大家。。。结贴给分!  详情 回复 发表于 2009-11-6 15:25
在PIO_IOControl,GPIO_SetPin, GPIO_ClrPin, GPIO_Display, 这几个函数都加下打印信息,看看调用是否正常
57
用示波器看看有电平变化没?
引用 2 楼 cfanlwn 的回复:
用示波器看看有电平变化没?
对哦。。。就是示波器没变化。
63
引用 1 楼 veabol 的回复:
USB连接的 用什么函数打印哦?
79
呵呵,你小子真的很热 啊
闂傚倸鍊搁崐椋庣矆娓氣偓楠炴牠顢曢妶鍡椾粡濡炪倖鍔х粻鎴犲閸ф鐓曢柟閭﹀灱閸ゅ鏌ら弶鎸庡仴闁哄本绋戦埥澶娾枎閹邦喚鈻忛梺璇插閼归箖藝娴兼潙桅闁告洦鍨扮粻鎶芥煕閳╁啨浠﹀瑙勬礈缁辨捇宕掑▎鎴濆濡炪們鍔屽Λ婵嬪极閸愵喖顫呴柣妯虹仛濞堟儳鈹戞幊閸婃洟骞婃惔銏犲姅闂傚倷绀侀悿鍥ь浖閵娧呯焼濞达綀顫夐崣蹇涙煏閸繍妲归柣鎾跺枛閺岋絽顫滈埀顒佺鐠轰警鐎堕柣鎴eГ閻撴洟鏌¢崒婵囩《缂佺姷绮妵鍕閿涘嫭鍣板Δ鐘靛仜椤戝寮崒鐐村殟闁靛濡囪ぐ銊╂⒑鐠囨煡顎楅柛妯荤矒瀹曟垿骞樼紒妯煎幈闂佸綊鍋婇崢濂稿礉閵堝棛绠鹃柛顐墯鐎氾拷闂傚倸鍊搁崐宄懊归崶顒佸剭妞ゆ劧绠戦獮銏ゆ煃鏉炴壆鍔嶆い鏂垮缁辨捇宕掑顑藉亾閸濄儳鐭欓柛鏇ㄥ灠缁狀垶鏌ㄩ悤鍌涘闂傚倸鍊搁崐鐑芥嚄閸洖绠犻柟鍓х帛閸嬨倝鏌曟繛鐐珕闁稿顑夐弻锝夊箛椤掍焦鍎撻梺缁樺笒閻忔岸濡甸崟顖氱闁规惌鍨遍弫楣冩煟鎼淬垻鍟查柟鍑ゆ嫹濠电姷鏁告慨鐑藉极閹间礁纾绘繛鎴旀嚍閸ヮ剦鏁囬柕蹇曞Х椤︻噣鎮楅崗澶婁壕闂佸憡娲﹂崑澶愬春閻愮儤鈷戦悹鎭掑妼濞呮劙鏌熼崙銈嗗
77
66
75
83
66
