3022|6
1582
【AT32F421测评】+ ADC数据采集及显示 [复制链接]
在AT32F421的内部,配置有采样率高达2M SPS的12位15通道高速ADC,可充分满足高速数据采集、混合信号处理和工业控制与电机应用要求。
此外,在ADC的基础上还配置了一个内部温度采集通道,利用它可以检测片内温度的变换情况。将该功能与前面介绍的串行数码管显示模块相配合,则可以达到图示的显示效果。
片内温度显示效果图
实现显示效果的主程序为:
  • int main(void)
  •   int w;
  •   RCC_Configuration();
  •   Delay_init();
  •   DMA_Reset(DMA1_Channel1);
  •   DMA_DefaultInitParaConfig(&DMA_InitStructure);
  •   DMA_InitStructure.DMA_PeripheralBaseAddr    = ADC1_DR_Address;
  •   DMA_InitStructure.DMA_MemoryBaseAddr        = (uint32_t)&ADCConvertedValue;
  •   DMA_InitStructure.DMA_Direction             = DMA_DIR_PERIPHERALSRC;
  •   DMA_InitStructure.DMA_BufferSize            = 1;
  •   DMA_InitStructure.DMA_PeripheralInc         = DMA_PERIPHERALINC_DISABLE;
  •   DMA_InitStructure.DMA_MemoryInc             = DMA_MEMORYINC_DISABLE;
  •   DMA_InitStructure.DMA_PeripheralDataWidth   = DMA_PERIPHERALDATAWIDTH_HALFWORD;
  •   DMA_InitStructure.DMA_MemoryDataWidth       = DMA_MEMORYDATAWIDTH_HALFWORD;
  •   DMA_InitStructure.DMA_Mode                  = DMA_MODE_CIRCULAR;
  •   DMA_InitStructure.DMA_Priority              = DMA_PRIORITY_HIGH;
  •   DMA_InitStructure.DMA_MTOM                  = DMA_MEMTOMEM_DISABLE;
  •   DMA_Init(DMA1_Channel1, &DMA_InitStructure);  DMA_ChannelEnable(DMA1_Channel1, ENABLE);
  •   ADC_StructInit(&ADC_InitStructure);
  •   ADC_InitStructure.ADC_Mode              = ADC_Mode_Independent;
  •   ADC_InitStructure.ADC_ScanMode          = DISABLE;
  •   ADC_InitStructure.ADC_ContinuousMode    = ENABLE;
  •   ADC_InitStructure.ADC_ExternalTrig      = ADC_ExternalTrig_None;
  •   ADC_InitStructure.ADC_DataAlign         = ADC_DataAlign_Right;
  •   ADC_InitStructure.ADC_NumOfChannel      = 1;
  •   ADC_Init(ADC1, &ADC_InitStructure);
  •   ADC_RegularChannelConfig(ADC1, ADC_Channel_TempSensor, 1, ADC_SampleTime_239_5);
  •   ADC_DMACtrl(ADC1, ENABLE);
  •   ADC_TempSensorVrefintCtrl(ENABLE);
  •   ADC_Ctrl(ADC1, ENABLE);
  •   ADC_RstCalibration(ADC1);
  •   while(ADC_GetResetCalibrationStatus(ADC1));
  •   ADC_StartCalibration(ADC1);
  •   while(ADC_GetCalibrationStatus(ADC1));
  •   ADC_SoftwareStartConvCtrl(ADC1, ENABLE);
  •   AT_eval_smg_init();
  •   Init_MAX7219();
  •   Write_Max7219(0x0f,0x00);
  •   Write_Max7219(1,0x0f);
  •   Write_Max7219(2,0x0f);
  •   Write_Max7219(3,0x0f);
  •   Write_Max7219(4,0x0f);
  •   Write_Max7219(5,0x0f);
  •   Write_Max7219(6,0x0f);
  •   Write_Max7219(7,0x0f);
  •   Write_Max7219(8,0x0f);
  •   while (1)
  •                     Delay_sec(1);
  •                     w=(ADC_TEMP_BASE-(double)ADCConvertedValue*ADC_VREF/4096)/ADC_TEMP_SLOPE+25;
  •                     Write_Max7219(1,w%10);
  •                     Write_Max7219(2,w%100/10);
其中的显示函数Write_Max7219(i,n)的用法为:i用于指定显示的位置,由左至右是1~8;而n是显示的数值0~9。当n为0x0f时,则关闭该位的显示。
楼主测评的很好 这颗还配置了一个内部温度采集通道,不错   详情 回复 发表于 2021-5-11 07:32
赞赏
查看全部赞赏
点赞(1) 关注
管理员
不错,期待后续哈
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
感谢支持和鼓励!  详情 回复 发表于 2021-5-10 23:58
加油!在电子行业默默贡献自己的力量!:)
1930
感谢分享!期待后续测评!
1582
soso 发表于 2021-5-10 08:49 不错,期待后续哈
感谢支持和鼓励!
1582
w494143467 发表于 2021-5-10 17:34 感谢分享!期待后续测评!
7007
楼主测评的很好
这颗还配置了一个内部温度采集通道,不错
感谢支持,继续努力!  详情 回复 发表于 2021-5-11 09:17
1582
Jacktang 发表于 2021-5-11 07:32 楼主测评的很好 这颗还配置了一个内部温度采集通道,不错
感谢支持,继续努力!
猜你喜欢
【直播时间】5月28日(周三)上午10:00
