3754|5
83
wince5.0没法启动,大家帮忙看一下哪里出问题了 [复制链接]
RomBOOT
>By www.mcuzone.com ...
FMD_DirectRead lasted 0 ms for 0x46 bytes (timer granularity is 400)
Press [ENTER] to download now or [SPACE] to cancel.
Initiating image download in   5 seconds
Ethernet Boot Loader Configuration :
0) Mac address .......... (00:12:72:72:20:20)
1) Ip address ........... (192.168.0.115)
2) Subnet Mask address .. (255.255.255.0)
3) DHCP ................. (Disabled)
4) Boot delay (seconds).. (5)
5) Frequency settings ... (core at 180, bus divider 2)
6) Download device....... (Ethernet)
7) Debug device.......... (Ethernet (EMACB))
8) Download image to..... (SDRAM)
9) Download new image at startup
l) Launch flash resident image now
d) Download from Ethernet now
s) Save configuration now
r) Restore default configuration and save now
n) Image flash menu
>System ready!
Preparing for download...
INFO: Trying to initialize the internal NIC (EMACB)...
pEmac->EMAC_SA1L=  72721200
pEmac->EMAC_SA1H= 2020
Init Emac Ethernet controler
Enter in AT91F_EmacEntry  base = 0xbffbc000
EMACB revision 0x1010c
->Enter in AT91F_EMACInit
Found Phy (DM9161A) at address 0
CONTROL REG : 0x3100
STATUS REG : 0x7849
STATUS REG : 0x786d
EMAC Init : 100 Mbit/s FULL DUPLEX (RMII)
EDBG:AT91Init Reading MAC address 0x1200 0x7272 0x2020
INFO: EMACB Ethernet controller initialized.
+EbootSendBootmeAndWaitForTftp
Sent BOOTME to 255.255.255.255
Packet has the following data:
  boot.bin[NULL]octet[NULL]
TFTP packet could have 1 name/value pairs
Locked Down Link 1
Src IP 192.168.0.115 Port 03D4   Dest IP 192.168.0.12 Port 0709
Default TFTP block size set to: 512 bytes
There were no options detected in the TFTP
EthDown::TFTPD_OPEN::boot.bin
-EbootSendBootmeAndWaitForTftp
BL_IMAGE_TYPE_BIN
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXTX underrun, resetting buffers, status = 60
bForceTX
Sent Frame error
bForceTX
Sent Frame error
XXXXrom_offset=0x0.
XXImageStart = 0x8006C000, ImageLength = 0x5EE0D8, LaunchAddr = 0x8006D000
Completed file(s):
[0]: Address=0x8006C000  Length=0x5EE0D8  Name="" Target=RAM
ROMHDR at Address 8006C044h
Got EDBG_CMD_JUMPIMG
Got EDBG_CMD_CONFIG, flags:0x00000000
Launching windows CE image by jumping at address 0x2006d000Ma-------------------
|PLLA : 199702165 Hz|
|PLLB : 95857034 Hz|
Configuring EBI1 CS0 for PSRAM...
Master Clock is 49925541 Hz
OALTimerInit
+OALTimerInit
Test : 0xc30
g_oalTimer.msecPerSysTick : 0x1
g_oalTimer.countsPerMSec : 0xc30
g_oalTimer.countsMargin : 0x0
g_oalTimer.maxPeriodMSec : 0x14f
g_oalTimer.countsPerSysTick : 0xc30
g_oalTimer.actualMSecPerSysTick : 0x1
g_oalTimer.actualCountsPerSysTick : 0xc30
g_oalTimer.curCounts : 0x0
-OALTimerInit
reset : General Reset (PowerOn)
pDrvGlobalArea->bEboot == TRUE. Forcing Clean Object store
+OEMPowerManagerInit
-OEMPowerManagerInit
OALKitlStart
Firmware Init Done.
+OEMInitWatchDogTimer
AT91SAM926x_DispWatchDog 8000!
AT91SAM926x_SetWatchDogConfiguration 20000 => 5120
Clipping The Watchdog period to the maximum : 0xFFF (15996 ms)
-OEMInitWatchDogTimer (result = 15996)
Sp=ffffc7cc
OEMIoControl: Unsupported Code 0x10100b4 - device 0x0101 func 45
+OALIoCtlHalInitRTC(...)
setrealtime 2857574912
-OALIoCtlHalInitRTC(rc = 1)
OEMIoControl: Unsupported Code 0x101008c - device 0x0101 func 35
OEMIoControl: Unsupported Code 0x10100d0 - device 0x0101 func 52
OEMIoControl: Unsupported Code 0x10100f8 - device 0x0101 func 62
SPIDriver - SPI_Init - Context: Drivers\Active\03
Loading WinCE driver for ATMEL EMACB controller
Using bootloader ethernet configuration
PHY ID : 25278624
PHY_GetConfiguration : autoneg not complete
DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\AFD). Driver cannot be unloaded.
DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\PPP). Driver cannot be unloaded.
Handle Event:0x43cf199e, sysintr=0x12Master Clock is 49925541 Hz
Display mode #0, 240x320x16bpp @ 0hz
Frame buffer is Uncached
Config2DEngine
OEMIoControl: Unsupported Code 0x10100fc - device 0x0101 func 63
TOUCH:ThrdPrio = 100, ThrdHighPrio = 100
MSIM: IM_ReadRegistry read KB 5
Explorer(V2.0) taskbar thread started.
NDISPWR:: Found adapter [EMACB1]
cable attached
M 1566,1922  1549,1897  -17,-25
应该只是显示有问题,其它的应该都是好的,尝试在你的某个驱动里边加个线程一直打印东西,如果能够一直出现打印信息说明系统已经成功启动,差的仅仅是显示驱动有问题。  详情 回复 发表于 2009-11-20 10:29
——不解,任务栏都启动了。
是不因为这句话不行?
0hz ?
这个应在在哪里修改?
是不是你的显示屏驱动有问题,系统起来了,只是屏幕没有显示
引用 3 楼 zzqccc 的回复:
觉得有可能.
62
