5503|7
1593
【Gravity:AS7341测评】+ 色彩检测器的设计 (兼结题报告) [复制链接]
将可见光传感器的检测值送往串口来输出显示,在使用上总有些不方便的感觉,若为它配上一个小巧的显示屏将会为之改观,图1至图3就是配置OLED显示屏后的显示效果。
1 起始界面
4个通道值显示
3 4个通道值显示
要实现这样的显示功能,无非是在原来的色彩检测基础上再添加一个OLED 屏的显示驱动功能。
为此,我们可以令OLED屏的2I2C引脚与MCU建立如下的连接关系:
SCL1---12
SDA1---11
I/O来模拟I2C通讯所输出高低电平的语句定义为:
#define SCL1_high   digitalWrite(SCL1, HIGH)
#define SCL1_low   digitalWrite(SCL1,LOW)
#define SDA1_high   digitalWrite(SDA1, HIGH)
#define SDA1_low   digitalWrite(SDA1,LOW)
设置2个引脚为输出功能的语句为:
pinMode(SCL1, OUTPUT);
pinMode(SDA1, OUTPUT);
辅助数据传输的相关函数为:
void IIC_Start()
   SCL1_high;
   SDA1_high;
   SDA1_low;
   SCL1_low;
void IIC_Stop()
   SCL1_low;
   SDA1_low;
   SCL1_high;
   SDA1_high;
void IIC_Wait_Ack()
    SCL1_high;
    SCL1_low;
实现显示效果的关键程序为:
void setup(void)
  Serial.begin(115200);
  while (as7341.begin() != 0) {
  Serial.println("IIC init failed, please check if the wire connection is correct");
  delay(1000);
  OLED_Init();
  OLED_Clear();
  OLED_ShowString(0,0,"AS7341 TEST",16);
  OLED_ShowString(0,2,"jinglixixi",16);
  delay(1000);
  delay(1000);
  OLED_Clear();
  OLED_ShowString(0,0,"F1=0    F2=0",16);
  OLED_ShowString(0,2,"F3=0    F4=0",16);
  delay(1000);
  delay(1000);
  OLED_ShowString(0,0,"F5=0    F6=0",16);
  OLED_ShowString(0,2,"F7=0    F8=0",16);
void loop(void)
  DFRobot_AS7341::sModeOneData_t data1;
  DFRobot_AS7341::sModeTwoData_t data2;
  as7341.startMeasure(as7341.eF1F4ClearNIR);
  data1 = as7341.readSpectralDataOne();
  OLED_Clear();
  OLED_ShowString(0,0,"F1=     F2=",16);
  OLED_ShowString(0,2,"F3=     F4=",16);
  OLED_ShowNum(24,0,data1.ADF1,4,16);
  OLED_ShowNum(88,0,data1.ADF2,4,16);
  OLED_ShowNum(24,2,data1.ADF3,4,16);
  OLED_ShowNum(88,2,data1.ADF4,4,16);
  as7341.startMeasure(as7341.eF5F8ClearNIR);
  data2 = as7341.readSpectralDataTwo();
  delay(1000);
  delay(1000);
  OLED_Clear();
  OLED_ShowString(0,0,"F5=     F6=",16);
  OLED_ShowString(0,2,"F7=     F8=",16);
  OLED_ShowNum(24,0,data2.ADF5,4,16);
  OLED_ShowNum(88,0,data2.ADF6,4,16);
  OLED_ShowNum(24,2,data2.ADF7,4,16);
  OLED_ShowNum(88,2,data2.ADF8,4,16);
  delay(1000);
  delay(1000);
4 是色彩分布的区间,进行相应色彩的检测,特提取了相应的色彩样本以供显示屏来显示,参见图5所示。
https://bbs.eeworld.com.cn/data/attachment/elecplay/upload/image/20201110/1604975124279063.png
4 色彩分布的区间
5 色彩样本(F3)
以可见光传感器对色彩样本检测的结果如下:
1F1色彩样本
RGB(888)色彩值:
0x8B3DC5=( 10001011,00111101,11000101)B
RGB(565)色彩值:
0x89F8
实测值:
F1=3
F2=42(1)
F3=13
F4=12
F5=16
F6=25(2)
F7=18(3)
F8=9
2F3色彩样本
RGB(888)色彩值:
0x01 B0 F1=( 00000001,10110000,11110001)B
RGB(565)色彩值:
0x059E
实测值:
F1=4
F2=57(1)
F3=20
F4=27(3)
F5=29(2)
F6=12
F7=5
F8=3
3F5色彩样本
RGB(888)色彩值:
0x00AF50=( 00000000,10101111,01010000)B
RGB(565)色彩值:
0x056A
实测值:
F1=2
F2=12
F3=8
F4=19(2)
F5=33(1)
F6=13(3)
F7=4
F8=2
4F7色彩样本
RGB(888)色彩值:
0x FF C0 00=(11111111,11000000,00000000)B
RGB(565)色彩值:
0xFE00
实测值:
F1=5
F2=9
F3=11
F4=32
F5=41(3)
F6=69(1)
F7=48(2)
F8=22
5F6色彩样本
RGB(888)色彩值:
0x FF FF 01=( 11111111,11111111,00000001)B
RGB(565)色彩值:
0xFFE0
实测值:
F1=4
F2=7
F3=11
F4=42
F5=88(2)
F6=92(1)
F7=54(3)
F8=26
6F8色彩样本
RGB(888)色彩值:
0x C1 00 03=(11000001,00000000,00000011)B
RGB(565)色彩值:
0xC000
实测值:
F1=1
F2=4
F3=3
F4=2
F5=7
F6=29 (1)
F7=23(2)
F8=9(3)
7F2色彩样本
RGB(888)色彩值:
0x02 51 8C =( 00000010,01010000,10001100)B
RGB(565)色彩值:
0x0291
实测值:
F1=2
F2=34(1)
F3=12(2)
F4=12(3)
F5=11
F6=5
F7=3
F8=1
8F4色彩样本
RGB(888)色彩值:
0x02 FE CD =(00000010,11111110,11001101)B
RGB(565)色彩值:
0x0291
实测值:
F1=7
F2=67(3)
F3=30
F4=73(2)
F5=74(1)
F6=22
F7=7
F8=4
经实际测评,可见光传感器AS7341的性能是比较出色,尤其是在对黄色的识别上,它能够独立识别,而不是以2个色彩的和来识别。比较遗憾的是本想以彩色OLED屏来完成色彩识别仪的设计,怎奈ArduinoUNO开发板的程序存储空间稍小些,无法支撑该设想的实现,尽管单独驱动彩色OLED来完成显示输出是没有问题的,但在加上色彩传感器后,就只有显示起始界面的份儿了,传感器也无法在有限的程序空间内运转。其解决之道就是将ArduinoUNO的程序功能移植到程序存储空间比较大的MCU开发板上,当然这是需要较多时间的。
大佬,你这样的可以加一块掌控板,把数据传送到APP    这样是不是更好!   详情 回复 发表于 2022-12-6 16:29
点赞(1) 关注
7793
还好我不是色盲,最后几个F1,F2看的好谣言。
默认摸鱼,再摸鱼。2022、9、28
你测出来数字量最大是1000还是65535
也就1000  详情 回复 发表于 2021-2-25 08:45
1593
上海首席男模 发表于 2021-2-24 09:33 你测出来数字量最大是1000还是65535
也就1000
202
管理员
很漂亮~赞赞赞~
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
个人签名玩板看这里:
1593
也可以,暂时用不上,它与基本的GRB色彩模式有距离。  详情 回复 发表于 2022-12-6 22:03
1593
Wordfield 发表于 2022-12-6 16:29 大佬,你这样的可以加一块掌控板,把数据传送到APP    这样是不是更好!
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
