2148|1
IAR 5.2 外部中断 [复制链接]
各位大侠,帮我看个程序,我用的是IAR5.2编译器,不知道怎么写外部中断,不知道这样写行不,还有IAR里面启动文件时怎么加进来的。
#include
#include
__irq __arm void f_in(void);
#define IRQV 0x18
#pragma vector=IRQV
__irq __arm void irq_handler (void)
  void (*interrupt_)();
  unsigned int vector;
  vector = VICVectAddr;     // Get interrupt vector.
  interrupt_ = (void(*)())vector;
  if(interrupt_ != 0)
    interrupt_();  // Call vectored interrupt .
  else
    VICVectAddr = 0;      // Clear interrupt in VIC.
int main()
  __disable_interrupt();
  PINSEL0=  0x00000000;
  PINSEL1 |=0x0000002;
  IODIR |=  0x1<<17;
  IOCLR |=  0x1<<17;
  EXTMODE |=0x00;
  EXTPOLAR|=0x00;
  VICIntSelect |= 0x00000000;
  VICIntEnClear|= 0xFFFFFFFF;
  VICProtection = 0;
  VICVectAddr   = 0x00000000;
  VICIntEnable |=   0x1<<14;
  VICVectCntl0 = 0x20 | 14;
  VICVectAddr0 = (unsigned int)&f_in;
  __enable_interrupt();
  while(1);
__irq __arm void f_in()
/*if((IOPIN&0x00000001)==1)
    IOCLR |= 0x00000001;
  else
    IOSET |= 0x00000001; */
  IOSET |=0x1<<17;
  while((IOPIN&0x00010000)==0);//等待按键放开
  EXTINT |= 0x01;
  VICVectAddr=0x00;
NXP的没有用过 我使用ST的时候,好像在IAR的安装目录下有很多例程,你可以参考下  详情 回复 发表于 2010-4-21 22:37
78
NXP的没有用过
