代码在这里:
- typedef struct _HW_DEVICE_EXTENSION
- //省略原来部分,下面这些是我添加的,最后一行是DPC对象
- PULONG BAR0;
- BYTE FrameCount;
- PHW_STREAM_REQUEST_BLOCK CurrentSRB;
- PUCHAR CurrentVirtualAddress;
- ULONG CurrentCount;
- KDPC DpcForIsr;
- } HW_DEVICE_EXTENSION, *PHW_DEVICE_EXTENSION;
- BOOLEAN STREAMAPI HwInitialize ( IN OUT PHW_STREAM_REQUEST_BLOCK pSrb )
- STREAM_PHYSICAL_ADDRESS adr;
- ULONG Size;
- PUCHAR pDmaBuf;
- int j;
- PPORT_CONFIGURATION_INFORMATION ConfigInfo = pSrb->CommandData.ConfigInfo;
- PHW_DEVICE_EXTENSION pHwDevExt = (PHW_DEVICE_EXTENSION)ConfigInfo->HwDeviceExtension;
- DbgLogInfo(("Testcap: HwInitialize()\n"));
- /* 有无硬件无所谓
- if (ConfigInfo->NumberOfAccessRanges != 0)
- DbgLogError(("Testcap: illegal config info\n"));
- pSrb->Status = STATUS_NO_SUCH_DEVICE;
- return (FALSE);
- // ReadCfg();
- pHwDevExt->BAR0 = (PULONG)(ULONG_PTR)(ConfigInfo->AccessRanges[0].RangeStart.LowPart);
- // pHwDevExt->BAR2 = (PULONG)(ULONG_PTR)(ConfigInfo->AccessRanges[2].RangeStart.LowPart);
- pHwDevExt->ioBaseLocal = (PULONG)(ULONG_PTR)(ConfigInfo->AccessRanges[1].RangeStart.LowPart);
- DbgLogInfo(("TestCap: Number of access ranges = %lx\n", ConfigInfo->NumberOfAccessRanges));
- DbgLogInfo(("TestCap: Memory Range = %lx\n", pHwDevExt->ioBaseLocal));
- DbgLogInfo(("TestCap: IRQ = %lx\n", ConfigInfo->BusInterruptLevel));
- pHwDevExt->Irq = (USHORT)(ConfigInfo->BusInterruptLevel);
- ConfigInfo->StreamDescriptorSize = sizeof (HW_STREAM_HEADER) + DRIVER_STREAM_COUNT * sizeof (HW_STREAM_INFORMATION);
- pDmaBuf = StreamClassGetDmaBuffer(pHwDevExt);
- adr = StreamClassGetPhysicalAddress(pHwDevExt, NULL, pDmaBuf, DmaBuffer, &Size);
- // Init VideoProcAmp properties
- pHwDevExt->Brightness = BrightnessDefault;
- pHwDevExt->BrightnessFlags = KSPROPERTY_VIDEOPROCAMP_FLAGS_AUTO;
- pHwDevExt->Contrast = ContrastDefault;
- pHwDevExt->ContrastFlags = KSPROPERTY_VIDEOPROCAMP_FLAGS_AUTO;
- pHwDevExt->ColorEnable = ColorEnableDefault;
- pHwDevExt->ColorEnableFlags = KSPROPERTY_VIDEOPROCAMP_FLAGS_MANUAL;
- // Init CameraControl properties
- pHwDevExt->Focus = FocusDefault;
- pHwDevExt->FocusFlags = KSPROPERTY_CAMERACONTROL_FLAGS_AUTO;
- pHwDevExt->Zoom = ZoomDefault;
- pHwDevExt->ZoomFlags = KSPROPERTY_CAMERACONTROL_FLAGS_AUTO;
- // Init VideoControl properties
- pHwDevExt->VideoControlMode = 0;
- // Init VideoCompression properties
- pHwDevExt->CompressionSettings.CompressionKeyFrameRate = 15;
- pHwDevExt->CompressionSettings.CompressionPFramesPerKeyFrame = 3;
- pHwDevExt->CompressionSettings.CompressionQuality = 5000;
- pHwDevExt->PDO = ConfigInfo->RealPhysicalDeviceObject;
- pHwDevExt->FDO = ConfigInfo->ClassDeviceObject;
- DbgLogInfo(("TestCap: Physical Device Object = %lx\n", pHwDevExt->PDO));
- for (j = 0; j < MAX_TESTCAP_STREAMS; j++)
- // For each stream, maintain a separate queue for data and control
- InitializeListHead (&pHwDevExt->StreamSRBList[j]);
- InitializeListHead (&pHwDevExt->StreamControlSRBList[j]);
- KeInitializeSpinLock (&pHwDevExt->StreamSRBSpinLock[j]);
- pHwDevExt->StreamSRBListSize[j] = 0;
- // Init ProtectionStatus
- pHwDevExt->ProtectionStatus = 0;
- // The following allows multiple instance of identical hardware
- // to be installed. GlobalDriverMediumInstanceCount is set in the Medium.Id field.
- pHwDevExt->DriverMediumInstanceCount = GlobalDriverMediumInstanceCount++;
- /****************2009年10月21日初始化IO定时器、DPC和FrameCount***************/
- IoInitializeTimer( pHwDevExt->PDO, OnTimer, &(pHwDevExt->FrameCount) );
- pHwDevExt->FrameCount = 0;
- [color=#FF0000]KeInitializeDpc( &(pHwDevExt->DpcForIsr), DpcForIsrRoutine, pHwDevExt );[/color]//此句初始化DPC对象
- DbgLogInfo(("TestCap: Exit, HwInitialize()\n"));
- pSrb->Status = STATUS_SUCCESS;
- return (TRUE);
- BOOLEAN HwInterrupt( IN PHW_DEVICE_EXTENSION pHwDevExt )
- const int Count = 192;
- PHYSICAL_ADDRESS address;
- BOOLEAN fMyIRQ = FALSE;
- ULONG InterruptFlag;
- ULONG Length;
- ULONG BytesLeave;
- InterruptFlag = READ_REGISTER_ULONG( pHwDevExt->BAR0+0X10/4 );
- if(InterruptFlag)
- WRITE_REGISTER_ULONG( pHwDevExt->BAR0+0X10/4, 0 );
- fMyIRQ = TRUE;
- if( pHwDevExt->CurrentCount )
- /* if( InterruptFlag&0x00000010 )
- pHwDevExt->VCount = 1;
- //将地址修改为最后一行 即添加768*767
- address = StreamClassGetPhysicalAddress( pHwDevExt, pHwDevExt->CurrentSRB,
- pHwDevExt->CurrentVirtualAddress + 768*767, SRBDataBuffer, &Length );
- // address = MmGetPhysicalAddress ( pHwDevExt->CurrentVirtualAddress );
- WRITE_REGISTER_ULONG( pHwDevExt->BAR0+10, address.LowPart );
- if( Length < 768 )
- WRITE_REGISTER_ULONG( pHwDevExt->BAR0+12, Length/4 );
- BytesLeave = 768 - Length;
- pHwDevExt->CurrentVirtualAddress+Length + 768*767,
- SRBDataBuffer, &Length );
- WRITE_REGISTER_ULONG( pHwDevExt->BAR0+12, BytesLeave/4);
- else
- WRITE_REGISTER_ULONG( pHwDevExt->BAR0+12, Count );
- pHwDevExt->CurrentCount -= Count * 4;
- else
- if( pHwDevExt->VCount )
- pHwDevExt->CurrentVirtualAddress + 768 * (767-pHwDevExt->VCount),
- // address = MmGetPhysicalAddress ( (pHwDevExt->CurrentVirtualAddress) + 768*(pHwDevExt->VCount) );
- pHwDevExt->CurrentVirtualAddress + 768 * (767-pHwDevExt->VCount)+Length,
- else
- ++pHwDevExt->VCount;
- else
- WRITE_REGISTER_ULONG( pHwDevExt->BAR0+10, pHwDevExt->DMABaseAddress );
- WRITE_REGISTER_ULONG( pHwDevExt->BAR0+12, Count);
- // [color=#FF0000]IoRequestDpc( pHwDevExt->FDO, pHwDevExt->CurrentSRB->Irp, NULL);[/color]//此处调用DPC对象
- */ WRITE_REGISTER_ULONG( pHwDevExt->BAR0+10, pHwDevExt->DMABaseAddress+4 );
- WRITE_REGISTER_ULONG( pHwDevExt->BAR0+12, 128 );
- pHwDevExt->CurrentCount -= 768;
- else
- if(pHwDevExt->CurrentSRB)
- CompleteStreamSRB ( pHwDevExt->CurrentSRB );
- pHwDevExt->CurrentSRB = NULL;
- pHwDevExt->CurrentVirtualAddress = NULL;
- pHwDevExt->DMABaseAddress = 0;
- return fMyIRQ;
复制代码 |
