最近在弄一个家庭影院系统,在MTK解码芯片里(8032核心)实现从USB种读出文件然后给另一个MCU通过UART升级。之前用查询的方式实现了基本功能,但是有小概率出现死机问题。现在想用中断方式来发送和接收。代码如下,我在调发送时,用串口助手接收发现:比如要发0x55,0x56,0x57,0x58四个数据,但是在
接收端总是显示接收到4个0x00或者4个0x4.请路过的英雄帮忙看看问题,出在哪里。
#if 1
#define _USART_C_
#define COM_RECV_BUF_SIZE 10
#define COM_SEND_BUF_SIZE 10
BYTE xdata _bComRecvBuf[COM_RECV_BUF_SIZE];
BYTE xdata _bComRecvBufWrPoint;
BYTE xdata _bComRecvBufRdPoint;
BYTE xdata _bComRecvBufNs;
#define COM_RECV_BUF_EMPTY() (_bComRecvBufNs == 0)
#define COM_RECV_BUF_FULL() (_bComRecvBufNs >= COM_RECV_BUF_SIZE)
BYTE xdata _bComSendBuf[COM_SEND_BUF_SIZE];
BYTE xdata _bComSendBufWrPoint;
BYTE xdata _bComSendBufRdPoint;
BYTE xdata _bComSendBufNs;
#define COM_SEND_BUF_EMPTY() (_bComSendBufNs == 0)
#define COM_SEND_BUF_FULL() (_bComSendBufNs >= COM_SEND_BUF_SIZE)
void vUart_int_Service(void)
if(RI)
RI = 0;
if(!COM_SEND_BUF_FULL())
_bComRecvBuf[_bComRecvBufWrPoint] = SBUF;
_bComRecvBufNs++;
_bComRecvBufWrPoint++;
if(_bComRecvBufWrPoint >= COM_RECV_BUF_SIZE)
_bComRecvBufWrPoint = 0;
else
// Notice!! It will caause date lost
if(TI)
TI = 0;
if(!COM_SEND_BUF_EMPTY())
_bComSendBufNs--;
_bComSendBufRdPoint++;
if(_bComSendBufRdPoint >= COM_SEND_BUF_SIZE)
_bComSendBufRdPoint = 0;
SBUF = _bComSendBuf[_bComSendBufRdPoint];
#pragma disable
BYTE bGetRecvData(BYTE *pbRecvData) large
if(COM_SEND_BUF_EMPTY())
return 0;
*pbRecvData = _bComRecvBuf[_bComRecvBufRdPoint];
_bComRecvBufNs--;
_bComRecvBufRdPoint++;
if(_bComRecvBufRdPoint >= COM_RECV_BUF_SIZE)
_bComRecvBufRdPoint = 0;
return 1;
#pragma disable
BYTE bGetRecvNData(BYTE *pbRecvData, BYTE bNum) large
BYTE i;
if(bNum > _bComRecvBufNs)
return 0;
for(i = 0; i < bNum; i++)
*(pbRecvData + i) = _bComRecvBuf[_bComRecvBufRdPoint];
_bComRecvBufNs--;
return 1;
void vClrRecvBuf(void) large
_bComRecvBufNs = 0;
_bComRecvBufRdPoint = _bComRecvBufWrPoint;
#pragma disable
BYTE putbyte(BYTE bSendData) large
BYTE fgSending;
if(COM_SEND_BUF_FULL())
return 2;
_bComSendBuf[_bComSendBufWrPoint] = bSendData;
fgSending = !COM_SEND_BUF_EMPTY();
_bComSendBufNs ++;
_bComSendBufWrPoint++;
if(_bComSendBufWrPoint >= COM_SEND_BUF_SIZE)
_bComSendBufWrPoint = 0;
if(!fgSending)
SBUF = bSendData;
return 1;
void vClrSendBuf(void)large
_bComSendBufNs = 0;
_bComSendBufRdPoint = _bComSendBufWrPoint;
void vInitUART(unsigned char bBaudRateMod) large
_STCL_Flag.inbufsign=0;
_STCL_Flag.out_buf_full=0;
_STCL_Flag.out_finish=0;
_STCL_Flag.in_buf_full=0;
_STCL_Flag.in_finish=0;
Setup TIMER1 to generate the proper baud rate.
SM0 = 0; SM1 = 1; /* serial port MODE 1 */
SM2 = 0;
REN = 1; /* enable serial receiver */
Clear transmit interrupt and buffer.
TI = 0; /* clear transmit interrupt */
RI = 0;
Set timer 1 up as a baud rate generator.
TR1 = 0; /* stop timer 1 */
ET1 = 0; /* disable timer 1 interrupt */
// PCON &=0x7f; // 表示baud rate / 2
PCON |=0x80; /*/ 表示baud rate = 真实的 baud rate*/
TMOD &= ~0xF0; /* clear timer 1 mode bits */
TMOD |= 0x20; /* put timer 1 into MODE 2 */
//: 1. the real speed clock of 80C32 is 22Mhz(Philips mode set) (can't support 76.8Kbps)
//: 2. Baud rate Timer Count (0xFF-n) PCON.7 (double speed) timing-error-ratio
//: 300 190(189.972) 0 0.01%
//: 600 190(189.972) 1 0.01%
//: 1200 94(94.486) 1 0.51%
//: 2400 47(46.743) 1 0.55%
//: 3600 31(30.829) 1 0.56%
//: 7200 15(14.914) 1 0.57%
//: 9600 11(10.936) 1 0.59%
//: 14400 7(6.957) 1 0.62%
//: 19200 5(4.968) 1 0.65%
//: 28800 3(2.979) 1 0.72%
//: 38400 2(1.984) 1 0.81%
//: 57600 1(0.989) 1 1.08%
//: 115200 0(-0.005) 1 0.50%
TH1 = 0xFF-UART_BAUDRATE_9600 ;//(unsigned char) (256 - (22000000 / (16L * 12L * baudrate)));
TL1 = 0xFF-UART_BAUDRATE_9600;
TR1 = 1; /* start timer 1 */
//ET1 = 0;
ES = 1;
#endif
