- from machine import Timer
- from mpython import *
- import urequests
- import network
- import ntptime
- import music
- import json
- touch_threshold = {'P': 400, 'Y': 400, 'T': 400, 'H': 400, 'O': 400, 'N': 400}
- tim12 = Timer(12)
- _status_p = _status_y = _status_t = _status_h = _status_o = _status_n = 0
- def on_touchpad_P_pressed():pass
- def on_touchpad_P_unpressed():pass
- def on_touchpad_Y_pressed():pass
- def on_touchpad_Y_unpressed():pass
- def on_touchpad_T_pressed():pass
- def on_touchpad_T_unpressed():pass
- def on_touchpad_H_pressed():pass
- def on_touchpad_H_unpressed():pass
- def on_touchpad_O_pressed():pass
- def on_touchpad_O_unpressed():pass
- def on_touchpad_N_pressed():pass
- def on_touchpad_N_unpressed():pass
- def timer12_tick(_):
- global _status_p, _status_y, _status_t, _status_h, _status_o, _status_n
- try:
- touchPad_P.read();pass
- except:
- return
- if touchPad_P.read() < touch_threshold['P']:
- if 1 != _status_p:_status_p = 1;on_touchpad_P_pressed()
- elif 0 != _status_p:_status_p = 0;on_touchpad_P_unpressed()
- if touchPad_Y.read() < touch_threshold['Y']:
- if 1 != _status_y:_status_y = 1;on_touchpad_Y_pressed()
- elif 0 != _status_y:_status_y = 0;on_touchpad_Y_unpressed()
- if touchPad_T.read() < touch_threshold['T']:
- if 1 != _status_t:_status_t = 1;on_touchpad_T_pressed()
- elif 0 != _status_t:_status_t = 0;on_touchpad_T_unpressed()
- if touchPad_H.read() < touch_threshold['H']:
- if 1 != _status_h:_status_h = 1;on_touchpad_H_pressed()
- elif 0 != _status_h:_status_h = 0;on_touchpad_H_unpressed()
- if touchPad_O.read() < touch_threshold['O']:
- if 1 != _status_o:_status_o = 1;on_touchpad_O_pressed()
- elif 0 != _status_o:_status_o = 0;on_touchpad_O_unpressed()
- if touchPad_N.read() < touch_threshold['N']:
- if 1 != _status_n:_status_n = 1;on_touchpad_N_pressed()
- elif 0 != _status_n:_status_n = 0;on_touchpad_N_unpressed()
- def weather_getWeather(_weather, _city):
- if weather_serveraddr=="http://www.tianqiapi.com":
- nowResult = urequests.get(weather_serveraddr+"/api/?appid="+weather_appid+"&appsecret="+weather_appsecret+"&version=v6&cityid="+_city)
- json=nowResult.json()
- nowResult.close()
- return json[_weather]
- else:
- nowResult = urequests.get(weather_serveraddr+"/api/weather/?appid="+weather_appid+"&appsecret="+weather_appsecret+"&version=v6&cityid="+_city)
- nowResult.close()
- brightness=9
- weather_serveraddr = "http://www.tianqiapi.com"
- weather_appid = "85215611"
- weather_appsecret = "Kx8r5ZCY "
- global g_my_variable
- music.pitch(147, 500)
- oled.fill(0)
- oled.DispChar("上海", 0, (1-1)*16, 1)
- oled.DispChar(weather_getWeather("wea", "101020100"), 0, (2-1)*16, 1)
- oled.DispChar((str("最低温度:") + str(weather_getWeather("tem2", "101020100"))), 0, (3-1)*16, 1)
- oled.DispChar((str("最高温度:") + str(weather_getWeather("tem1", "101020100"))), 0, (4-1)*16, 1)
- oled.show()
- music.pitch(175, 500)
- oled.fill(0)
- oled.DispChar("重庆", 0, (1-1)*16, 1)
- oled.DispChar(weather_getWeather("wea", "101040100"), 0, (2-1)*16, 1)
- oled.DispChar((str("最低温度:") + str(weather_getWeather("tem2", "101040100"))), 0, (3-1)*16, 1)
- oled.DispChar((str("最高温度:") + str(weather_getWeather("tem1", "101040100"))), 0, (4-1)*16, 1)
- oled.show()
- music.pitch(247, 500)
- oled.fill(0)
- oled.DispChar("福州", 0, (1-1)*16, 1)
- oled.DispChar((str("天气情况:") + str(weather_getWeather("wea", "101230101"))), 0, (2-1)*16, 1)
- oled.DispChar((str("最低温度:") + str(weather_getWeather("tem2", "101230101"))), 0, (3-1)*16, 1)
- oled.DispChar((str("最高温度:") + str(weather_getWeather("tem1", "101230101"))), 0, (4-1)*16, 1)
- oled.show()
- music.pitch(196, 500)
- oled.fill(0)
- oled.DispChar("深圳", 0, (1-1)*16, 1)
- oled.DispChar(weather_getWeather("wea", "101280601"), 0, (2-1)*16, 1)
- oled.DispChar((str("最低温度:") + str(weather_getWeather("tem2", "101280601"))), 0, (3-1)*16, 1)
- oled.DispChar((str("最高温度:") + str(weather_getWeather("tem1", "101280601"))), 0, (4-1)*16, 1)
- oled.show()
- music.pitch(165, 500)
- oled.fill(0)
- oled.DispChar("北京", 0, (1-1)*16, 1)
- oled.DispChar(weather_getWeather("wea", "101010100"), 0, (2-1)*16, 1)
- oled.DispChar((str("最低温度:") + str(weather_getWeather("tem2", "101010100"))), 0, (3-1)*16, 1)
- oled.DispChar((str("最高温度:") + str(weather_getWeather("tem1", "101010100"))), 0, (4-1)*16, 1)
- oled.show()
- music.pitch(220, 500)
- oled.fill(0)
- oled.DispChar("济南", 0, (1-1)*16, 1)
- oled.DispChar(weather_getWeather("wea", "101120101"), 0, (2-1)*16, 1)
- oled.DispChar((str("最低温度:") + str(weather_getWeather("tem2", "101120101"))), 0, (3-1)*16, 1)
- oled.DispChar((str("最高温度:") + str(weather_getWeather("tem1", "101120101"))), 0, (4-1)*16, 1)
- oled.show()
- tim12.init(period=100, mode=Timer.PERIODIC, callback=timer12_tick)
- my_wifi = wifi()
- my_wifi.connectWiFi("zh","zy1567")
- while not (my_wifi.sta.isconnected()):
- pass
- rgb[1] = (0*brightness//9, 102*brightness//9, 0*brightness//9)
- rgb.write()
- music.pitch(131, 50)
- ntptime.settime(8, "ntp.ntsc.ac.cn")
- oled.fill(0)
- oled.DispChar("触摸按键选城市", 0, (1-1)*16, 1)
- oled.DispChar("P 上海 Y 福州", 0, (2-1)*16, 1)
- oled.DispChar("T 北京 H 重庆", 0, (3-1)*16, 1)
- oled.DispChar("O 深圳 N 济南", 0, (4-1)*16, 1)
- oled.show()
