2481|2
59
模拟器问题 [复制链接]
eMbedded Visual C++ 4.0 和 Platform Builder 5.0平台
当安装SDK后,用eMbedded Visual C++ 4.0打开,不能出现自己定制的wince界面,出现以下提示:
The specified CE boot image could not be loaded.
Your virtual machine may not have enough RAM allocated. Try increasing the RAM allocation (if you are using Platform Builder open the Configure Remote Services dialog, choose the Emulator Download service, and click the configure button).
内存过小,重新定制的时候在属性页把内存调大一些…  详情 回复 发表于 2010-3-3 10:02
定制模拟器的时候分配的内存太小了吧?
77
