5069|0
1148
Application of Inverter in Constant Pressure Water Supply Co [复制链接]
Abstract: It is found in present water supply engineering project that throttling
valve independent with big barrel grooves or virtual consumption can sustain
constant pressure water supply. It is the technical challenge in water supply
engineering. This article briefly discusses the technical application of Delta VFD-F
series inverter in constant pressure water supply control system.
3859.pdf
86.6 KB, 下载次数: 14
