3306|3
6822
TMS320F28335——SCI串口 [复制链接]
一、IO配置
  以SCIA为例:使用的是GPIO35--SCITXDA    GPIOA36--SCIRXDA
  使用寄存器:
  GPBPUD :设置上拉  GPIO32-GPIO63   对应位0 使能上拉
  GPBQSEL1:
  GPBMUX1:IO模式选择
  代码如下:
    GpioCtrlRegs.GPBPUD.bit.GPIO36 = 0;    // Enable pull-up for GPIO28 (SCIRXDA)//使能内部上拉
    GpioCtrlRegs.GPBPUD.bit.GPIO35 = 0;       // Enable pull-up for GPIO29 (SCITXDA)//使能内部上拉
    GpioCtrlRegs.GPBQSEL1.bit.GPIO36 = 3;  // Asynch input GPIO28 (SCIRXDA) //设置为异步输入模式
    GpioCtrlRegs.GPBMUX1.bit.GPIO36 = 1;   // Configure GPIO28 for SCIRXDA operation  //配置为外设模式
    GpioCtrlRegs.GPBMUX1.bit.GPIO35 = 1;   // Configure GPIO29 for SCITXDA operation//配置为外设模式
 设置FIFO寄存器:
复制代码
void scia_fifo_init()
    SciaRegs.SCIFFTX.all=0xE040;//使能FIFO;清除发送中断标志位;禁止FIFO发送中断;
                                //发送中断级别定义为0;
    SciaRegs.SCIFFRX.all=0x204f;//清除FIFO溢出标志位;清除溢出接受中断标志位;禁止
                                //FF接受中断;接受中断级别为16;
    SciaRegs.SCIFFCT.all=0x0;//SCITXBUF到移位寄存器传送不延迟
复制代码
设置SCI相关寄存器:  寄存器描述见http://www.ti.com/lit/ug/sprufz5a/sprufz5a.pdf
复制代码
void scia_echoback_init()
    // Note: Clocks were turned on to the SCIA peripheral
    // in the InitSysCtrl() function
     SciaRegs.SCICCR.all =0x0007;   // 1 stop bit,  No loopback
                                   // No parity,8 char bits,
                                   // async mode, idle-line protocol
    SciaRegs.SCICTL1.all =0x0003;  // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
    SciaRegs.SCICTL2.all =0x0003;
    SciaRegs.SCICTL2.bit.TXINTENA =1;//开启接收中断
    SciaRegs.SCICTL2.bit.RXBKINTENA =1;//开启发送中断
    #if (CPU_FRQ_150MHZ)
          SciaRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 37.5MHz.
          SciaRegs.SCILBAUD    =0x00E7;
    #endif
    #if (CPU_FRQ_100MHZ)
      SciaRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 20MHz.
      SciaRegs.SCILBAUD    =0x0044;
    #endif
    SciaRegs.SCICTL1.all =0x0023;  // Relinquish SCI from Reset
复制代码
波特率计算方式:
发生一个字节:
void scia_xmit(int a)
    while (SciaRegs.SCIFFTX.bit.TXFFST != 0) {}
    SciaRegs.SCITXBUF=a;
 使用SICA  发送,串口中断接收:
  配置参数如下:
复制代码
static void Init_SCI_A(Uint32 Baud)
    //Init  IO
    Uint16 BRR=0;
    EALLOW;
    EDIS;
    //set RX  interrput function
    EALLOW;
    PieVectTable.SCIRXINTA = &SciaRxIsr;
    EDIS;
   //set SCIA register
   SciaRegs.SCICTL2.bit.TXINTENA =0;//close TX interrput
    //set Baud BRR= LSPCLK/(Baud*8)-1
   BRR = SCI_LSPCLK/(Baud*8)-1;
   SciaRegs.SCIHBAUD    = (BRR>>8);  // 9600 baud @LSPCLK = 37.5MHz.
   SciaRegs.SCILBAUD    = (BRR&0x00ff);
//   SciaRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 37.5MHz.
//   SciaRegs.SCILBAUD    =0x00E7;
   EALLOW;
   //set SCI interrput Group
    PieCtrlRegs.PIECTRL.bit.ENPIE = 1;   // Enable the PIE block
    PieCtrlRegs.PIEIER9.bit.INTx1=1;     // PIE Group 9, int1  enable SCIA_RX
    //PieCtrlRegs.PIEIER9.bit.INTx2=1;     // PIE Group 9, INT2  enable SCIA_TX
   EDIS;
复制代码
  发送数据代码:
复制代码
//send one byte data
static void scia_xmit(int a)
//send string
void scia_msg(char * msg)
    int i;
    i = 0;
    while(msg != '\0')
        scia_xmit(msg);
        i++;
SCI也是串口么 和UART一样么   详情 回复 发表于 2020-1-6 13:41
2618
不错的分享,谢谢
7228
192
SCI也是串口么 和UART一样么
SCI(Serial Communication Interface)意为“串行通信接口”,是相对于并行通信的,是串行通信技术的一种总称,最早由Motolora公司提出的。 UART(Universal Asynchronous Receiver & Transmitter)即通  详情 回复 发表于 2020-1-6 16:21
6822
常见泽1 发表于 2020-1-6 13:41 SCI也是串口么 和UART一样么
UART(Universal Asynchronous Receiver & Transmitter)即通用异步收发器,是串行通信的一种协议,它规定串行通信的波特率、起始/停止位、数据位、校验位等格式,以及各种异步握手信号。
