1151|0
1140
MSP430的ADC转化+均值滤波 [复制链接]
由于各种干扰,MSP430在进行ADC转化时总会出现波动,为了提高数据的可靠性,可以进行软件滤波,其中均值滤波操作简单,效果良好:
//  MSP-FET430P140 Demo - ADC12, Using the Internal Reference
//  Description:
//                MSP430F149
//     Vin -->|P6.0/A0        |
//  M. Mitchell
//  Texas Instruments Inc.
//  Feb 2005
//  Built with IAR Embedded Workbench Version: 3.21A
#include  <msp430x14x.h>
#include"lcd.h"
#include"adc.h"
int meanValueFilter(void);
void DelayXms(unsigned int i);      //delay about x ms
void int2charsLcdshow1(int value);   //LCD show a value from 0 to 9999
void int2charsLcdshow2(int value);   //LCD show a value from 0 to 9999
void main(void)
   int adcValue1,adcValue2;
   WDTCTL = WDTPW+WDTHOLD;                   // Stop watchdog timer
   LcdReset();                               //initialize the lac1602
   while (1)
    adcValue1 = meanValueFilter();
    adcValue2 = GetAdcValue2();
    int2charsLcdshow1(adcValue1);
    int2charsLcdshow2(adcValue2);
    DelayXms(500);
void DelayXms(unsigned int i){
    unsigned int j;
    for( ; i>0; i--){
      for(j=0;j<200;j++);
*函数名: int2charsLcdshow1(void)                                               /
*作用  :将AD转化的结果,在LCD1602上进行显示                                   /
*返回值:无        /
*参数  :int        /
*作者  :Zhenhua Liu                                                           /
*时间  :2017.12.08                                                            /
void int2charsLcdshow1(int value){
   int bits=0,ten = 0,hundred = 0,thousand = 0;
   thousand = value/1000;
   hundred  = value%1000/100;
   ten = value%100/10;
   bits = value%10;
   Disp1Char(0,0,thousand+'0');
   Disp1Char(1,0,hundred+'0');
   Disp1Char(2,0,ten+'0');
   Disp1Char(3,0,bits+'0');
void int2charsLcdshow2(int value){
   ten = value%100/10;
   bits = value%10;
   Disp1Char(0,1,thousand+'0');
   Disp1Char(1,1,hundred+'0');
   Disp1Char(2,1,ten+'0');
   Disp1Char(3,1,bits+'0');
*函数名: meanValueFilter(void)                                                /
*作用  :启动ADC转化之后,将采集到的10次AD数据进行求和平均,均值滤波          /
*返回值:int型        /
*参数  :无        /
*作者  :Zhenhua Liu                                                          /
*时间  :2017.12.08                                                           /
int meanValueFilter(void){
    unsigned int i;
    float sum=0;
    int meanvalue=0;
    for(i=0;i<10;i++){
       sum+=GetAdcValue1();
    meanvalue = sum/10.0;           //隐式类型转化,flozt->int
    return meanvalue;
