2575|1
75
MSP430FR6972如何做到液晶驱动功耗最低? [复制链接]
FR6972 LCD显示功耗近20UA,FR4133  LCD显示功耗只有6UA;
电路差不多,区别就在R23/LCDCAP 接4.7uF,而FR4133 接0.1uF
VSS--4.7uF -| R23/LCDCAP
VSS--0.1uF -|R03
VSS--0.1uF -|R13
VSS--0.1uF -|R23
程序设置有错吗?
void CLOCK_Config()  // MSP430FR6972
                PJSEL0 = BIT4 | BIT5;                   // For LFXT
        // Configure LFXT 32kHz crystal
  CSCTL0_H = CSKEY >> 8;                  // Unlock CS registers
  CSCTL4 &= ~LFXTOFF;                     // Enable LFXT
  do
    CSCTL5 &= ~LFXTOFFG;                  // Clear LFXT fault flag  清除 LFXT 失效标志
    SFRIFG1 &= ~OFIFG;
  } while (SFRIFG1 & OFIFG);              // Test oscillator fault flag  如果失效标志存在
  CSCTL0_H = 0;                           // Lock CS registers
void LCD_Config(void)  // MSP430FR6972
         //Initialize LCD segments 0 - 15;  18 - 21; 24 ; 28 - 30
  LCDCPCTL0 = 0xFFFF;
  LCDCPCTL1 = 0x713C;
  LCDCPCTL2 = 0x0000;                                //设置LCD管脚 L0 - L15; L18 - L21; L24 ; 28 - 30 pins selected
  // Initialize LCD_C
  // ACLK, Divider = 1, Pre-divider = 16; 4-pin MUX
  LCDCCTL0 = LCDDIV__1 | LCDPRE__16 | LCD4MUX | LCDLP;
  // VLCD generated internally,
  // V2-V4 generated internally, v5 to ground
  // Set VLCD voltage to 2.60v
  // Enable charge pump and select internal reference for it
  LCDCVCTL = VLCD_2_96 | VLCDREF_0 | LCDCPEN;
  LCDCCPCTL = LCDCPCLKSYNC;               // Clock synchronization enabled
  LCDCMEMCTL = LCDCLRM;                   // Clear LCD memory
  //Turn LCD on
  LCDCCTL0 |= LCDON;  // 打开LCD
[url=]更多操作[/url]
点赞 关注(1)
75
void CLOCK_Config()// MSP430FR4133
        P4SEL0 |= BIT1 + BIT2;                  // Select pin4.1 pin4.2 as crystal function
        do
                CSCTL7 &= ~(XT1OFFG + DCOFFG);            // Clear XT1 and DCO fault flag  清除 XT1 DCO 失效标志
                SFRIFG1 &= ~OFIFG;
        }while (SFRIFG1 & OFIFG);                     // Test oscillator fault flag  如果失效标志存在
        CSCTL4 = SELA__XT1CLK;                                        // IMPORTANT. Select ACLK = XT1 = 32768Hz
void LCD_Config(void)   // MSP430FR4133
        uint8_t ui8Cnt;
        uint8_t *pLCD = (uint8_t *)&LCDM0;
        for (ui8Cnt = 13; ui8Cnt > 0; ui8Cnt--)                        // Clear LCD memory
        *pLCD++ = 0x00;                                        // CLR LCD
        SYSCFG2 |= LCDPCTL;                              // R13/R23/R33/LCDC1/LCDC2 pins selected  设置 LCD功耗
        LCDPCTL0 = 0xFFFF;
        LCDPCTL1 = 0x01FF;                                        //设置 LCD管脚 L0~L24 pins selected
        LCDVCTL = LCDSELVDD + LCDCPEN;                // Mode 2 设置 降低LCD 功耗 片上电荷泵
        LCDCSSEL0 = 0x000F;                                        // 设置 公共极  COM0~3
        LCDCSSEL1 = 0x0000;
  LCDM0 = 0x21;                        // L0 = COM0, L1 = COM1
  LCDM1 = 0x84;
        LCDCTL0 |= LCD4MUX + LCDLP + LCDON;        // 打开LCD: 4-mux 模式
