1468|0
2015
DM642EVM的BSL源代码 [复制链接]
/*  All rights reserved. Property of Spectrum Digital Incorporated. */
*  ======== evmdm642.c ========
*  EVMDM642 board initializion implementation.
#include
#include
#include
#include
#include
#include "evmdm642.h"
#include "evmdm642_apll.h"
/* I2C handle */
I2C_Handle EVMDM642_I2C_hI2C;
/* GPIO handle */
GPIO_Handle EVMDM642_GPIO_hGPIO;
/* Initialize the board APIs */
void EVMDM642_init()
    volatile Uint32 test;
    EMIFA_Config emifaCfg0 = {
        EMIFA_FMKS(GBLCTL, EK2RATE, HALFCLK)    |
        EMIFA_FMKS(GBLCTL, EK2HZ, CLK)          |
        EMIFA_FMKS(GBLCTL, EK2EN, ENABLE)       |
        EMIFA_FMKS(GBLCTL, BRMODE, MRSTATUS)    |
        EMIFA_FMKS(GBLCTL, NOHOLD, DISABLE)     |
        EMIFA_FMKS(GBLCTL, EK1HZ, HIGHZ)        |
        EMIFA_FMKS(GBLCTL, EK1EN, ENABLE)       |
        EMIFA_FMKS(GBLCTL, CLK4EN, ENABLE)      |
        EMIFA_FMKS(GBLCTL, CLK6EN, ENABLE),
        EMIFA_FMKS(CECTL, WRSETUP, DEFAULT)    |
        EMIFA_FMKS(CECTL, WRSTRB, DEFAULT)     |
        EMIFA_FMKS(CECTL, WRHLD, DEFAULT)      |
        EMIFA_FMKS(CECTL, RDSETUP, DEFAULT)    |
        EMIFA_FMKS(CECTL, TA, DEFAULT)         |
        EMIFA_FMKS(CECTL, RDSTRB, DEFAULT)     |
        EMIFA_FMKS(CECTL, MTYPE, SDRAM64)      |
        EMIFA_FMKS(CECTL, RDHLD, DEFAULT),
        EMIFA_FMKS(CECTL, WRSETUP, OF(7))      |
        EMIFA_FMKS(CECTL, WRSTRB, OF(14))      |
        EMIFA_FMKS(CECTL, WRHLD, OF(2))        |
        EMIFA_FMKS(CECTL, RDSETUP, OF(2))      |
        EMIFA_FMKS(CECTL, TA, OF(2))           |
        EMIFA_FMKS(CECTL, RDSTRB, OF(14))      |
        EMIFA_FMKS(CECTL, MTYPE, ASYNC8)       |
        EMIFA_FMKS(CECTL, RDHLD, OF(1)),
        EMIFA_FMKS(CECTL, WRSETUP, OF(2))      |
        EMIFA_FMKS(CECTL, WRSTRB, OF(10))      |
        EMIFA_FMKS(CECTL, RDSTRB, OF(10))      |
        EMIFA_FMKS(CECTL, MTYPE, ASYNC32)      |
        EMIFA_FMKS(CECTL, RDHLD, OF(2)),
        EMIFA_FMKS(CECTL, MTYPE, SYNC32)       |
        EMIFA_FMKS(SDCTL, SDBSZ, 4BANKS)       |
        EMIFA_FMKS(SDCTL, SDRSZ, 12ROW)        |
        EMIFA_FMKS(SDCTL, SDCSZ, 8COL)         |
        EMIFA_FMKS(SDCTL, RFEN, ENABLE)        |
        EMIFA_FMKS(SDCTL, INIT, YES)           |
        EMIFA_FMKS(SDCTL, TRCD, OF(1))         |
        EMIFA_FMKS(SDCTL, TRP, OF(1))          |
        EMIFA_FMKS(SDCTL, TRC, OF(5))          |
        EMIFA_FMKS(SDCTL, SLFRFR, DISABLE),
        EMIFA_FMKS(SDTIM, XRFR, OF(0))         |
        EMIFA_FMKS(SDTIM, PERIOD, OF(2075)),
        EMIFA_FMKS(SDEXT, WR2RD, OF(1))        |
        EMIFA_FMKS(SDEXT, WR2DEAC, OF(3))      |
        EMIFA_FMKS(SDEXT, WR2WR, OF(1))        |
        EMIFA_FMKS(SDEXT, R2WDQM, OF(3))       |
        EMIFA_FMKS(SDEXT, RD2WR, OF(2))        |
        EMIFA_FMKS(SDEXT, RD2DEAC, OF(3))      |
        EMIFA_FMKS(SDEXT, RD2RD, OF(1))        |
        EMIFA_FMKS(SDEXT, THZP, OF(2))         |
        EMIFA_FMKS(SDEXT, TWR, OF(2))          |
        EMIFA_FMKS(SDEXT, TRRD, OF(0))         |
        EMIFA_FMKS(SDEXT, TRAS, OF(6))         |
        EMIFA_FMKS(SDEXT, TCL, OF(1)),
        EMIFA_CESEC_DEFAULT,
        EMIFA_FMKS(CESEC, SNCCLK, ECLKOUT2)    |
        EMIFA_FMKS(CESEC, RENEN, READ)         |
        EMIFA_FMKS(CESEC, CEEXT, ACTIVE)       |
        EMIFA_FMKS(CESEC, SYNCWL, 0CYCLE)      |
        EMIFA_FMKS(CESEC, SYNCRL, 3CYCLE)
    I2C_Config i2cCfg = {
        0x0000007f, /* I2COAR -    Not used if master */
        0x00000000, /* I2CIER -    Disable interrupts, use polling */
        0x0000001b, /* I2CCLKL -   Low period for 100KHz operation */
        0x0000001b, /* I2CCLKH -   High period for 100KHz operation */
        0x00000002, /* I2CCNT -    Data words per transmission */
        0x0000001a, /* I2CSAR -    Slave address */
        0x00004680, /* I2CMDR -    Mode */
        0x00000019  /* I2CPSC -    Prescale 300MHz to 12MHz */
    /* Initialize CSL */
    CSL_init();
    /* Unlock PERCFG through PCFGLOCK */
    *((unsigned long *)0x1b3f018) = 0x10c0010c;
    /* Enable VP0-VP2, I2C and McASP0 in PERCFG */
    *((unsigned long *)0x1b3f000) = 0x79;
    /* Read back PERCFG */
    test = *((unsigned long *)0x1b3f000);
    /* Wait at least 128 CPU cycles */
    EVMDM642_wait(128);
    /* Initialize EMIFA */
    EMIFA_config(&emifaCfg0);
    /* Open I2C handle */
    EVMDM642_I2C_hI2C = I2C_open(I2C_PORT0, I2C_OPEN_RESET);
    /* Configure I2C controller */
    I2C_config(EVMDM642_I2C_hI2C, &i2cCfg);
    /* Take I2C out of reset */
    I2C_outOfReset(EVMDM642_I2C_hI2C);
    /* Open the GPIO handle */
    EVMDM642_GPIO_hGPIO = GPIO_open(GPIO_DEV0, GPIO_OPEN_RESET);
    /* Enable caching of SDRAM */
    CACHE_enableCaching(CACHE_EMIFA_CE00);
    CACHE_enableCaching(CACHE_EMIFA_CE01);
    /* Load the FPGA from Flash */
    EVMDM642_fpgaLoad(EVMDM642_FPGAFLASH_BASE);
    /* Configure APLL in default state */
    EVMDM642_APLL_rset(EVMDM642_APLL_FSG0);
/* Read an 8-bit value from a CPLD register */
Uint8 EVMDM642_rget(Int16 regnum)
    Uint8 *pdata;
    /* Return lower 8 bits of register */
    pdata = (Uint8 *)(EVMDM642_CPLD_BASE + regnum);
    return (*pdata & 0xff);
/* Write an 8-bit value to a CPLD register */
void EVMDM642_rset(Int16 regnum, Uint8 regval)
    Uint8 *pdata;
    /* Write lower 8 bits of register */
    *pdata = (regval & 0xff);
/* Spin in a delay loop for delay iterations */
void EVMDM642_wait(Uint32 delay)
    volatile Uint32 i, n;
    n = 0;
    for (i = 0; i < delay; i++)
        n = n + 1;
/* Spin in a delay loop for delay microseconds */
void EVMDM642_waitusec(Uint32 delay)
    EVMDM642_wait(delay * 21);
*  Copyright 2003 by Spectrum Digital Incorporated.
*  ======== evmdm642_aic23_loopback.c ========
*  EVMDM642_AIC23_loopback() implementation
#include
#include
*  ======== EVMDM642_AIC23_loopback ========
*  Enable/disable codec loopback mode
void EVMDM642_AIC23_loopback(EVMDM642_AIC23_CodecHandle hCodec, Int16 mode)
    int regval;
    /* Set bypass bit if mode is true */
    regval = (mode) ? 0x8 : 0x0;
    /* Write to codec register */
    EVMDM642_AIC23_rset(hCodec, EVMDM642_AIC23_ANAPATH,
        (EVMDM642_AIC23_rget(hCodec, EVMDM642_AIC23_ANAPATH) & 0xfff7 | regval));
*  ======== evmdm642_aic23_mute.c ========
*  EVMDM642_AIC23_mute() implementation
#include
#include
*  ======== EVMDM642_AIC23_mute ========
*  Enable/disable codec mute mode
void EVMDM642_AIC23_mute(EVMDM642_AIC23_CodecHandle hCodec, Int16 mode)
    int regval;
    /* Enable mute if mode is true */
    regval = (mode) ? 0x08 : 0x00;
    /* Write to codec registers (left and right) */
    EVMDM642_AIC23_rset(hCodec, EVMDM642_AIC23_DIGPATH,
        (EVMDM642_AIC23_rget(hCodec, EVMDM642_AIC23_DIGPATH) & 0xfff7) | regval);
evmdm642_aic23_opencodec.c
*  ======== evmdm642_aic23_openCodec.c ========
*  EVMDM642_AIC23_openCodec() implementation
#include
#include
#include
#include
#include
/* AIC23 handles */
MCASP_Handle EVMDM642_AIC23_hMcASP;
MCASP_ConfigGbl mcaspCfgDataGbl = {
    0x00000000, /* PFUNC -     All pins as McASP */
    0x00000001, /* PDIR  -     XMT DATA output, rest are inputs */
    0x00000000, /* DITCTL -    DIT mode disable */
    0x00000000, /* DLBCTL -    Loopback disabled */
    0x00000000  /* AMUTE  -    Never drive AMUTE */
MCASP_ConfigRcv mcaspCfgDataRcv = {
    0xffffffff, /* RMASK -     Use all 32 bits */
    0x000080f8, /* RFMT -      MSB first, 32-bit slots, CPU bus, 0 bit delay */
    0x00000000, /* AFSRCTL -   burst, single bit frame sync, ext FS */
    0x00000080, /* ACLKRCTL -  Sample on rising CLK, divide by 1, ext CLK */
    0x00000000, /* AHCLKRCTL - External HCLK */
    0x00000001, /* RTDM -      Slots 0-31 are active */
    0x00000000, /* RINTCTL -   No interrupts */
    0x00000000  /* RCLKCHK -   Not used */
MCASP_ConfigXmt mcaspCfgDataXmt = {
    0xffffffff, /* XMASK -     Use all 32 bits */
    0x000080f8, /* XFMT -      MSB first, 32-bit slots, CPU bus, 0 bit delay */
    0x00000000, /* AFSXCTL -   burst, single bit frame sync, ext FS */
    0x000000c0, /* ACLKXCTL -  Sample on falling CLK, divide by 1, ext CLK */
    0x00000000, /* AHCLKXCTL - External HCLK */
    0x00000001, /* XTDM -      Slots 0-31 are active */
    0x00000000, /* XINTCTL -   No interrupts */
    0x00000000  /* XCLKCHK -   Not used */
MCASP_ConfigSrctl mcaspCfgDataSrctl = {
    0x0000000d, /* SRCTL0 -    Transmit, active high */
    0x0000000e, /* SRCTL1 -    Receive, active high */
    0x00000000, /* SRCTL2 -    Inactive */
    0x00000000, /* SRCTL3 -    Inactive */
    0x00000000, /* SRCTL4 -    Inactive */
    0x00000000, /* SRCTL5 -    Inactive */
    0x00000000, /* SRCTL6 -    Inactive */
    0x00000000  /* SRCTL7 -    Inactive */
MCASP_Config mcaspCfgData = {
    &mcaspCfgDataGbl,
    &mcaspCfgDataRcv,
    &mcaspCfgDataXmt,
    &mcaspCfgDataSrctl
*  ======== EVMDM642_AIC23_openCodec ========
*  Open the codec and return a codec handle
EVMDM642_AIC23_CodecHandle EVMDM642_AIC23_openCodec(Int16 id, EVMDM642_AIC23_Config *Config, Int16 direction)
    Uint32 gblctl;
    /* Configure the AIC23 */
    EVMDM642_AIC23_config(id, Config);
    /* Open and configure the McASP */
    EVMDM642_AIC23_hMcASP = MCASP_open(MCASP_DEV0, MCASP_OPEN_RESET);
    MCASP_config(EVMDM642_AIC23_hMcASP, &mcaspCfgData);
    /* Clear transmit and receive status */
    MCASP_RSETH(EVMDM642_AIC23_hMcASP, RSTAT, 0xffff);
    MCASP_RSETH(EVMDM642_AIC23_hMcASP, XSTAT, 0xffff);
    /* Clear GBLCTL */
    gblctl = 0;
    MCASP_RSETH(EVMDM642_AIC23_hMcASP, GBLCTL, gblctl);
    /* Enable transmit/receive serializers */
    if ((direction & EVMDM642_AIC23_INPUT) != 0)
        gblctl |= 0x4;
    if ((direction & EVMDM642_AIC23_OUTPUT) != 0)
        gblctl |= 0x400;
    /* Enable transmit/receive state machines */
        gblctl |= 0x8;
        MCASP_RSETH(EVMDM642_AIC23_hMcASP, XBUF0, 0);
        gblctl |= 0x800;
    return TRUE;
evmdm642_aic23_read.c
*  ======== evmdm642_aic23_read16.c ========
*  EVMDM642_AIC23_read() implementation
#include
#include
*  ======== EVMDM642_AIC23_read ========
*  Read a 32-bit value from the codec
Int16 EVMDM642_AIC23_read(EVMDM642_AIC23_CodecHandle hCodec, Uint32 *val)
    /* If McASP doesn't have new data available, return false */
    if ((MCASP_RGETH(EVMDM642_AIC23_hMcASP, SRCTL1) & 0x20) == 0) {
        return (FALSE);
    /* Read the data */
    *val = MCASP_RGETH(EVMDM642_AIC23_hMcASP, XBUF1);
    return (TRUE);
evmdm642_aic23_registers.c
*  ======== evmdm642_aic23_registers.c ========
*  EVMDM642_AIC23_rset() and EVMDM642_AIC23_rget() implementation
#include
#include
#include
#include
/* Internal codec state used to simulate read/write functionality */
static EVMDM642_AIC23_Config codecstate = EVMDM642_AIC23_DEFAULTCONFIG;
static I2C_Config aic23XmtCfg = {
    0x00004ea0, /* I2CMDR -    Mode */
*  ======== EVMDM642_AIC23_rset ========
*  Set codec register regnum to value regval
void EVMDM642_AIC23_rset(EVMDM642_AIC23_CodecHandle hCodec, Uint16 regnum, Uint16 regval)
    Uint16 data;
    I2C_Config prevI2CCfg;
    /* Mask off lower 9 bits */
    regval &= 0x1ff;
    /* Set transmit data */
    data = (regnum << 9) | regval;
    /* Wait until bus is free */
    while (I2C_bb(EVMDM642_I2C_hI2C));
    /* Save old settings */
    I2C_getConfig(EVMDM642_I2C_hI2C, &prevI2CCfg);
    /* Restore settings for AIC23 */
    I2C_config(EVMDM642_I2C_hI2C, &aic23XmtCfg);
    /* Submit the MSB for transmit */
    I2C_RSETH(EVMDM642_I2C_hI2C, I2CDXR, (data >> 8) & 0xff);
    /* Generate start condition, starts transmission */
    I2C_start(EVMDM642_I2C_hI2C);
    /* Wait until MSB transmit is done */
    while(!I2C_xrdy(EVMDM642_I2C_hI2C));
    /* Submit the LSB for transmit */
    I2C_writeByte(EVMDM642_I2C_hI2C, data & 0xff);
    /* Generate stop condition */
    I2C_sendStop(EVMDM642_I2C_hI2C);
    /* Save register value if regnum is in range */
    if (regnum < EVMDM642_AIC23_NUMREGS)
        codecstate.regs[regnum] = regval;
    /* Short delay for AIC23 to accept command */
    EVMDM642_waitusec(20);
    /* Reconfigure I2C with old settings */
    I2C_config(EVMDM642_I2C_hI2C, &prevI2CCfg);
*  ======== EVMDM642_AIC23_rget ========
*  Return value of codec register regnum
Uint16 EVMDM642_AIC23_rget(EVMDM642_AIC23_CodecHandle hCodec, Uint16 regnum)
        return codecstate.regs[regnum];
    else
        return 0;
*  ======== EVMDM642_AIC23_config ========
*  Set the default codec register config values
void EVMDM642_AIC23_config(EVMDM642_AIC23_CodecHandle hCodec, EVMDM642_AIC23_Config *Config)
    int i;
    /* Use default parameters if none are given */
    if (Config == NULL)
            Config = &codecstate;
    /* Reset the codec */
    EVMDM642_AIC23_rset(hCodec, 15, 0);
    /* Assign each register */
    for (i = 0; i < EVMDM642_AIC23_NUMREGS; i++)
        if (i != 6)
            EVMDM642_AIC23_rset(hCodec, i, Config -> regs);
    EVMDM642_AIC23_rset(hCodec, 6, Config -> regs[6]);
