3536|0
ICCAVR_mega8_Proteus 跑马灯 [复制链接]
//ICC-AVR application builder : 2009-3-10 13:53:36
// Http://www.oa-only.com
// Target : M8
// Crystal: 8.0000Mhz
#include
#include
void port_init(void)
PORTB = 0x00;
DDRB  = 0x00;
PORTC = 0x00; //m103 output only
DDRC  = 0x00;
PORTD = 0x00;
DDRD  = 0x00;
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
MCUCR = 0x00;
GICR  = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
Target       :atmega8
Crystal(晶振):8M
void delay()
unsigned int i;//最大值65536
for (i=0;i<40000;i++)
Target       :atmega8
Crystal(晶振):8M
void show_LED()
unsigned char i;
DDRB=0xff;//设为输出
for (i=0;i<8;i++)
  PORTB=(1<   delay();
void main()
port_init();
init_devices();
while(1)
  show_LED();
http://www.oa-only.com/upload/20100127142953236.rar
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
第2场直播:融合热仿真与热测试提升产品可靠性
直播时间:04月17日 14:00 - 15:00
