3420|0
dsp2407烧写问题 [复制链接]
我在把仿真时运行良好的程序烧入到flash时,总是有以下错误提示:
Flash algorithm detects Zero Bit Error. Possible causes:
1. Flash not properly cleared and erased before programming.
2. Coff file contains multiple sections mapped to same address.
(A zero bit error occurs if a bit in flash is a zero, when its
intended value is a one.)
请问是啥原因?但是并不是烧写所有的程序都这样。另外就是在返回仿真状态,烧写vector时,也是有错误(在clearing阶段),提示好像是清除失败!
