3665|0
720
菜鸟求助高手啦 [复制链接]
Build target 'Target 1'
assembling Startup.s...
compiling main.c...
linking...
Program Size: data=1168 const=66161 code=5076
creating hex file from "UART"...
"UART" - 0 Error(s), 0 Warning(s).
Load "G:\\ARM\\并口液晶 LPC2132例程\\keil\\UART.ELF"
Full Chip Erase Done.
No Algorithm found for: 00010000H - 00010380H
No Algorithm found for: 00010384H - 00011647H
Partial Programming Done (areas with no algorithms skipped!)
Partial Verify OK (areas with no algorithms skipped!)
Application running ...
编译时出现这些是怎么回事,是常量数据太大么?
