4564|6
66
WinCE下获得环境变量 [复制链接]
怎样在WinCE下获得环境变量?有什么API吗?
象CEPlatform,CEVersion这种跟硬件相关的环境变量
请教大虾
up  详情 回复 发表于 2007-1-28 19:56
67
用.Net2003。
有Version和OSVersion。
99
System.Envirenment.Version
System.Envirenment.OSVersion
56
我用的是WinCE 5.0
搜索文档,好像没有
最好有API,想在程序里动态获取
61
什么样的环境变量呢???
   #ifndef SHIP_BUILD
   TCHAR szVersion[256];
   OSVERSIONINFO VerInfo;
   VerInfo.dwOSVersionInfoSize = sizeof(OSVERSIONINFO);
   ::GetVersionEx(&VerInfo);
   ::wsprintf(szVersion, L"Microsoft Windows CE .NET v%d.%02d (Build %d on %s) ",
              VerInfo.dwMajorVersion, VerInfo.dwMinorVersion, VerInfo.dwBuildNumber, TEXT(__DATE__));
   if (m_hbmpDesktop && !fTileBackgroundImage)
     rc.top = rcBlt.bottom + 5;
   else
     rc.top = rc.top + (rc.bottom - rc.top) / 2 - 8;
   ::DrawText(hdc, szVersion, -1, &rc, DT_SINGLELINE | DT_CENTER | DT_TOP);
   #endif
是否有你需要的东西????
63
An environment variable contains information about an aspect of the operating system (OS) environment, such as a drive, path, or configuration string.
When you create a new OS environment with Microsoft® Platform Builder, the integrated development environment (IDE) sets specific environment variables based on the platform settings you select. Once you complete the creation process, you can set or unset the environment variables from a command prompt build window, a batch file, any application in the execution path, or in the IDE itself.
up
