登录注册
论坛
531
#ifdef HAVE_CONFIG_H #include "config.h" #endif #include "speex/speex_echo.h" #include "speex/speex_preprocess.h" #include <stdio.h> #include <stdlib.h> #include <string.h> #include <time.h> static uint64_t get_tm(void){ struct timespec ts; clock_gettime(CLOCK_MONOTONIC,&ts); return ts.tv_sec*1000000000ull + ts.tv_nsec; } #include <stdint.h> #include <stdio.h> #include <string.h> /* WAV解析 */ #define CHUNK_RIFF "RIFF" #define CHUNK_WAVE "WAVE" #define CHUNK_FMT "fmt " #define CHUNK_DATA "data" typedef struct { uint32_t off; uint32_t chunksize; uint16_t audioformat; uint16_t numchannels; uint32_t samplerate; uint32_t byterate; uint16_t blockalign; uint16_t bitspersample; uint32_t datasize; }wav_t; static int wav_decode_head(uint8_t* buffer, wav_t* wav) { uint8_t* p = buffer; uint32_t chunksize; uint32_t subchunksize; if(0 != memcmp(p,CHUNK_RIFF,4)) { return -1; } p += 4; chunksize = (uint32_t)p[0] | ((uint32_t)p[1]<<8) | ((uint32_t)p[2]<<16) | ((uint32_t)p[3]<<24); wav->chunksize = chunksize; p += 4; if(0 != memcmp(p,CHUNK_WAVE,4)) { return -2; } p += 4; do { if(0 == memcmp(p,CHUNK_FMT,4)) { p += 4; subchunksize = (uint32_t)p[0] | ((uint32_t)p[1]<<8) | ((uint32_t)p[2]<<16) | ((uint32_t)p[3]<<24); p += 4; /* 解析参数 */ wav->audioformat = (uint16_t)p[0] | ((uint16_t)p[1]<<8); if((wav->audioformat == 0x0001) || (wav->audioformat == 0xFFFE)) { p += 2; wav->numchannels = (uint16_t)p[0] | ((uint16_t)p[1]<<8); p += 2; wav->samplerate = (uint32_t)p[0] | ((uint32_t)p[1]<<8) | ((uint32_t)p[2]<<16) | ((uint32_t)p[3]<<24); p += 4; wav->byterate = (uint32_t)p[0] | ((uint32_t)p[1]<<8) | ((uint32_t)p[2]<<16) | ((uint32_t)p[3]<<24); p += 4; wav->blockalign = (uint16_t)p[0] | ((uint16_t)p[1]<<8); p += 2; wav ->bitspersample = (uint16_t)p[0] | ((uint16_t)p[1]<<8); p += 2; if(subchunksize >16) { /* 有ext区域 */ uint16_t cbsize = (uint16_t)p[0] | ((uint16_t)p[1]<<8); p += 2; if(cbsize > 0) { /* ext数据 2字节有效bits wValidBitsPerSample ,4字节dwChannelMask 16字节SubFormat */ p += 2; p += 4; /* 比对subformat */ p += 16; } } } else { p += subchunksize; } } else if(0 == memcmp(p,CHUNK_DATA,4)) { p += 4; subchunksize = (uint32_t)p[0] | ((uint32_t)p[1]<<8) | ((uint32_t)p[2]<<16) | ((uint32_t)p[3]<<24); wav->datasize = subchunksize; p += 4; wav->off = (uint32_t)(p- buffer); return 0; } else { p += 4; subchunksize = (uint32_t)p[0] | ((uint32_t)p[1]<<8) | ((uint32_t)p[2]<<16) | ((uint32_t)p[3]<<24); p += 4; p += subchunksize; } }while((uint32_t)(p - buffer) < (chunksize + 8)); return -3; } /* 填充44字节的wav头 */ static void wav_fill_head(uint8_t* buffer, int samples, int chnum, int freq) { /* * 添加wav头信息 */ uint32_t chunksize = 44-8+samples*chnum*16/8; uint8_t* p = (uint8_t*)buffer; uint32_t bps = freq*chnum*16/8; uint32_t datalen = samples*chnum*16/8; p[0] = 'R'; p[1] = 'I'; p[2] = 'F'; p[3] = 'F'; p[4] = chunksize & 0xFF; p[5] = (chunksize>>8) & 0xFF; p[6] = (chunksize>>16) & 0xFF; p[7] = (chunksize>>24) & 0xFF; p[8] = 'W'; p[9] = 'A'; p[10] = 'V'; p[11] = 'E'; p[12] = 'f'; p[13] = 'm'; p[14] = 't'; p[15] = ' '; p[16] = 16; /* Subchunk1Size */ p[17] = 0; p[18] = 0; p[19] = 0; p[20] = 1; /* PCM */ p[21] = 0; p[22] = chnum; /* 通道数 */ p[23] = 0; p[24] = freq & 0xFF; p[25] = (freq>>8) & 0xFF; p[26] = (freq>>16) & 0xFF; p[27] = (freq>>24) & 0xFF; p[28] = bps & 0xFF; /* ByteRate */ p[29] = (bps>>8) & 0xFF; p[30] = (bps>>16) & 0xFF; p[31] = (bps>>24) & 0xFF; p[32] = chnum*16/8; /* BlockAlign */ p[33] = 0; p[34] = 16; /* BitsPerSample */ p[35] = 0; p[36] = 'd'; p[37] = 'a'; p[38] = 't'; p[39] = 'a'; p[40] = datalen & 0xFF; p[41] = (datalen>>8) & 0xFF; p[42] = (datalen>>16) & 0xFF; p[43] = (datalen>>24) & 0xFF; } void wav_print(wav_t* wav) { printf("off:%d\r\n",wav->off); printf("chunksize:%d\r\n",wav->chunksize); printf("audioformat:%d\r\n",wav->audioformat); printf("numchannels:%d\r\n",wav->numchannels); printf("samplerate:%d\r\n",wav->samplerate); printf("byterate:%d\r\n",wav->byterate); printf("blockalign:%d\r\n",wav->blockalign); printf("bitspersample:%d\r\n",wav->bitspersample); printf("datasize:%d\r\n",wav->datasize); } #include <alsa/asoundlib.h> #define NN 128 #define TAIL 2048 int alsa_play_init(char* device, snd_pcm_t **handle, int ch, int freq) { int err; if ((err = snd_pcm_open(handle, device, SND_PCM_STREAM_PLAYBACK, 0)) < 0) { /* 最后一个参数0 阻塞模式 1非阻塞模式 */ printf("Playback open error: %s\n", snd_strerror(err)); return -1; } snd_pcm_sframes_t frames; if ((err = snd_pcm_set_params(*handle, SND_PCM_FORMAT_S16_LE, SND_PCM_ACCESS_RW_INTERLEAVED, ch, freq, 0, 100000)) < 0) { /* 0.5sec */ printf("Playback open error: %s\n", snd_strerror(err)); snd_pcm_close(*handle); return -2; } snd_pcm_hw_params_t *hwparams = NULL; snd_pcm_hw_params_malloc(&hwparams); snd_pcm_hw_params_any(*handle, hwparams); snd_pcm_hw_params_set_access(*handle, hwparams, SND_PCM_ACCESS_RW_INTERLEAVED); snd_pcm_hw_params_set_format(*handle, hwparams,SND_PCM_FORMAT_S16_LE); snd_pcm_hw_params_set_channels(*handle, hwparams,ch); snd_pcm_hw_params_set_rate(*handle, hwparams,freq,0); snd_pcm_hw_params_set_period_size(*handle, hwparams, NN, 0); snd_pcm_hw_params_set_buffer_size(*handle, hwparams, 4*NN); snd_pcm_hw_params(*handle, hwparams); snd_pcm_hw_params_free(hwparams); return 0; } int alsa_rec_init(char* device, snd_pcm_t **handle, int ch, int freq) { int err; if ((err = snd_pcm_open(handle, device, SND_PCM_STREAM_CAPTURE, 0)) < 0) { /* 最后一个参数0 阻塞模式 1非阻塞模式 */ printf("Playback open error: %s\n", snd_strerror(err)); return -1; } snd_pcm_sframes_t frames; if ((err = snd_pcm_set_params(*handle, SND_PCM_FORMAT_S16_LE, SND_PCM_ACCESS_RW_INTERLEAVED, ch, freq, 0, 100000)) < 0) { /* 0.5sec */ printf("Playback open error: %s\n", snd_strerror(err)); snd_pcm_close(*handle); return -2; } snd_pcm_hw_params_t *hwparams = NULL; snd_pcm_hw_params_malloc(&hwparams); snd_pcm_hw_params_any(*handle, hwparams); snd_pcm_hw_params_set_access(*handle, hwparams, SND_PCM_ACCESS_RW_INTERLEAVED); snd_pcm_hw_params_set_format(*handle, hwparams,SND_PCM_FORMAT_S16_LE); snd_pcm_hw_params_set_channels(*handle, hwparams,ch); snd_pcm_hw_params_set_rate(*handle, hwparams,freq,0); snd_pcm_hw_params_set_period_size(*handle, hwparams, NN, 0); snd_pcm_hw_params_set_buffer_size(*handle, hwparams, 4*NN); snd_pcm_hw_params(*handle, hwparams); snd_pcm_hw_params_free(hwparams); snd_pcm_start(*handle); return 0; } int alsa_deinit(snd_pcm_t *handle) { int err; /* pass the remaining samples, otherwise they're dropped in close */ err = snd_pcm_drain(handle); if (err < 0){ printf("snd_pcm_drain failed: %s\n", snd_strerror(err)); } snd_pcm_close(handle); return 0; } int alsa_play(snd_pcm_t *handle, const void* buffer, size_t size) { snd_pcm_sframes_t frames; frames = snd_pcm_writei(handle, buffer, (snd_pcm_uframes_t)size); /* 注意这里的size为frames即点数 而不是字节大小 */ if (frames < 0){ frames = snd_pcm_recover(handle, frames, 0); printf("snd_pcm_recover: %s\n", snd_strerror(frames)); } if (frames < 0) { printf("snd_pcm_writei failed: %s\n", snd_strerror(frames)); return -1; } if (frames > 0 && frames < (long)sizeof(buffer)){ printf("Short write (expected %li, wrote %li)\n", (long)sizeof(buffer), frames); return -2; } return 0; } int alsa_rec(snd_pcm_t *handle, void* buffer, size_t size) { int timeout = 0; snd_pcm_sframes_t frames; do{ frames = snd_pcm_avail_update(handle); if(frames < size){ usleep(1000); timeout++; if(timeout >= 1000){ printf("rec timeout\n"); return -1; } } }while(frames < size); frames = snd_pcm_readi(handle, buffer, (snd_pcm_uframes_t)size); /* 注意这里的size为frames即点数 而不是字节大小 */ if (frames < 0){ frames = snd_pcm_recover(handle, frames, 0); printf("snd_pcm_recover: %s\n", snd_strerror(frames)); } if (frames < 0) { printf("snd_pcm_writei failed: %s\n", snd_strerror(frames)); return -1; } if (frames > 0 && frames < (long)sizeof(buffer)){ printf("Short write (expected %li, wrote %li)\n", (long)sizeof(buffer), frames); return -2; } return 0; } int main(int argc, char* argv[]) { snd_pcm_t *play_handle = NULL; snd_pcm_t *rec_handle = NULL; FILE *spk_fd; FILE *out_fd; char* spk_fname; char* out_fname; char* play_dev_name; char* rec_dev_name; int res; SpeexEchoState *st; SpeexPreprocessState *den; int ctl_i; float ctl_f; uint32_t t0; uint32_t t1; uint32_t tused_max = 0; uint32_t tused_min = 0; int16_t spk_buf[NN], mic_buf[NN], out_buf[NN]; int16_t out_wr_buf[3*NN]; uint8_t spk_wav_head_buf[128]; /* 输入spk wav文件头缓存 */ uint8_t out_wav_head_buf[44]; /* 输出文件wav头缓存 */ wav_t spk_wav; int samps; /* 采样点数 */ int times; /* 读取次数 */ int sampleRate; if(argc != 5){ printf("usage:alsa_rec_wav playdev recdev spkwav outwav\r\n"); return -1; } play_dev_name = argv[1]; rec_dev_name = argv[2]; spk_fname = argv[3]; out_fname = argv[4]; spk_fd = fopen(spk_fname, "rb"); if(spk_fd < 0){ printf("open file %s err\r\n",spk_fname); return -2; } if(fread(spk_wav_head_buf, 1, sizeof(spk_wav_head_buf), spk_fd) < 44){ printf("read file %s err\r\n",spk_fname); fclose(spk_fd); return -3; } if(0 != (res=wav_decode_head(spk_wav_head_buf, &spk_wav))){ printf("decode file %s err %d\r\n",spk_fname,res); fclose(spk_fd); return -4; } fseek(spk_fd,spk_wav.off,SEEK_SET); samps = spk_wav.datasize; samps /= spk_wav.blockalign; /* 采样点数 = 数据大小 除以 blockalign */ times = samps / NN; /* 一次读取NN个点,读取times次 */ sampleRate = spk_wav.samplerate; out_fd = fopen(out_fname, "wb+"); if(out_fd < 0){ fprintf(stderr, "open file %s err\n",out_fname); fclose(spk_fd); return -5; } wav_fill_head(out_wav_head_buf, times*NN, 3, sampleRate); /* 输出文件头 3通道 spk+mic+out */ if(44 != fwrite(out_wav_head_buf, 1, 44, out_fd)){ printf("write file %s err\n",out_fname); fclose(out_fd); return -6; } res = alsa_play_init(play_dev_name,&play_handle, 1, sampleRate); if(res != 0){ fclose(spk_fd); fclose(out_fd); printf("alsa_play_init err\r\n"); return -7; } res = alsa_rec_init(rec_dev_name,&rec_handle, 1, sampleRate); if(res != 0){ fclose(spk_fd); fclose(out_fd); alsa_deinit(play_handle); printf("alsa_rec_init err\r\n"); return -8; } st = speex_echo_state_init(NN, TAIL); den = speex_preprocess_state_init(NN, sampleRate); speex_echo_ctl(st, SPEEX_ECHO_SET_SAMPLING_RATE, &sampleRate); ctl_i=1; speex_preprocess_ctl(den, SPEEX_PREPROCESS_SET_DENOISE, &ctl_i); /* 打开降噪 ctl_i=1打开 0关闭*/ ctl_i=80; speex_preprocess_ctl(den, SPEEX_PREPROCESS_SET_NOISE_SUPPRESS, &ctl_i); ctl_i=80; speex_preprocess_ctl(den, SPEEX_PREPROCESS_SET_ECHO_SUPPRESS, &ctl_i); for(int i=0; i<times; i++) { if(alsa_rec(rec_handle, mic_buf, NN) < 0){ /* 注意这里最后一个参数是frames为单位 不需要乘以ch */ printf("rec err\r\n"); fclose(spk_fd); fclose(out_fd); alsa_deinit(play_handle); alsa_deinit(rec_handle); return -9; } if(NN != fread(spk_buf, sizeof(int16_t), NN, spk_fd)){ printf("read file %s err\r\n",spk_fname); fclose(spk_fd); fclose(out_fd); alsa_deinit(play_handle); alsa_deinit(rec_handle); return -10; } if(alsa_play(play_handle, spk_buf, NN) < 0){ printf("play err\r\n"); fclose(spk_fd); fclose(out_fd); alsa_deinit(play_handle); alsa_deinit(rec_handle); return -11; } t0 = get_tm(); speex_echo_cancellation(st, mic_buf, spk_buf, out_buf); speex_preprocess_run(den, out_buf); t1 = get_tm(); if((t1-t0) > tused_max){ tused_max = t1-t0; } if(tused_min == 0){ tused_min = t1-t0; }else{ if((t1-t0) < tused_min){ tused_min = t1-t0; } } for(int i=0; i<NN; i++){ out_wr_buf[3*i+0] = spk_buf[i]; out_wr_buf[3*i+1] = mic_buf[i]; out_wr_buf[3*i+2] = out_buf[i]; } if(NN*3 != fwrite(out_wr_buf, sizeof(int16_t), NN*3, out_fd)){ printf("write file %s err\r\n",out_fname); fclose(spk_fd); fclose(out_fd); alsa_deinit(play_handle); alsa_deinit(rec_handle); return -12; } } printf("used max:%duS,used min:%duS\r\n",tused_max/1000,tused_min/1000); speex_echo_state_destroy(st); speex_preprocess_state_destroy(den); fclose(spk_fd); fclose(out_fd); alsa_deinit(play_handle); alsa_deinit(rec_handle); return 0; }
扫一扫,分享给好友
7098
看来回声消除和降噪是比较关键的步骤
Jacktang 发表于 2025-4-13 15:24 看来回声消除和降噪是比较关键的步骤
是的,移植了开源成熟的方案
发表回复 回帖后跳转到最后一页
