2920|0
6892
参数化串口发送程序 [复制链接]
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
--LIBRARY ALTERA;
--USE ALTERA.MAXPLUS2.ALL;
LIBRARY LPM;
USE LPM.LPM_COMPONENTS.ALL;
ENTITY Tx_Com IS
GENERIC(Tx_D_Width : POSITIVE := 8; Check: STRING:="Even";Check_En:STRING:="En");
PORT(
   Clk      : IN  STD_LOGIC;
   Rst      : IN  STD_LOGIC;
   Tx_Clk     : IN  STD_LOGIC;                              ---------串口发送时钟
   Din      : IN  STD_LOGIC_VECTOR(Tx_D_Width-1 DOWNTO 0);     ---------串口发送数据
   Tx_En     : IN  STD_LOGIC;                                ---------串口发送使能
   Txbusy     : OUT  STD_LOGIC;                                ---------串口状态
   Star_Clk    : OUT  STD_LOGIC;                                ---------串口发送时钟使能
   Tx       : OUT   STD_LOGIC                             ---------串口数据按位发送
END Tx_Com;
ARCHITECTURE Arch_Tx_Com OF Tx_Com IS
CONSTANT  Bit_Valid    : STD_LOGIC:='1';
CONSTANT  Bit_Invalid    : STD_LOGIC:='0';
CONSTANT  Idle   :STD_LOGIC_VECTOR(3 DOWNTO 0):=X"0";
CONSTANT  Par_Tx  :STD_LOGIC_VECTOR(3 DOWNTO 0):=X"1";
CONSTANT  Load_tx  :STD_LOGIC_VECTOR(3 DOWNTO 0):=X"2";
CONSTANT  Shift_tx :STD_LOGIC_VECTOR(3 DOWNTO 0):=X"3";
CONSTANT  Stop_tx  :STD_LOGIC_VECTOR(3 DOWNTO 0):=X"4";
SIGNAL   Txdiv          :   INTEGER RANGE 0 TO 10;
SIGNAL   Regdin        :  STD_LOGIC_VECTOR(Tx_D_Width-1 DOWNTO 0);
SIGNAL   Tx_reg        :  STD_LOGIC_VECTOR(Tx_D_Width+2 DOWNTO 0);
SIGNAL   Tx_En_Buf       :   STD_LOGIC;
SIGNAL   Tx_Clk1,Star_Clk1   :   STD_LOGIC;
SIGNAL   Tx_Clk_Reg      :   STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL Txbitcnt        :  INTEGER RANGE 0 TO (Tx_D_Width+3);
SIGNAL Cnt           :  INTEGER RANGE 0 TO 3;
SIGNAL Tx_Data_Buf        :   STD_LOGIC_VECTOR((Tx_D_Width+Tx_D_Width-1) DOWNTO 0);
--TYPE    STATE IS (Idle,Par_Tx,Load_tx,Shift_tx,Stop_tx);
SIGNAL  Txfsm  : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
-----  syn transmit with system clock-----------------------------------------------
PROCESS(Clk,Rst)
BEGIN
IF (Rst=Bit_Valid) THEN
Tx<=Bit_Invalid;
ELSIF Clk'EVENT AND Clk=Bit_Valid THEN
  --IF (Clk_Work="011" ) THEN
Tx <= Tx_reg(0);
IF (Tx_Clk='1') THEN
    Tx_Clk_Reg<="01";
ELSE
    Tx_Clk_Reg<="10";
END IF;
--END IF;
END IF;
END PROCESS;
-----Input Signal Delay a Clock-----------------------------------------------
PROCESS(Clk,Rst)
BEGIN
Tx_En_Buf<=Bit_Invalid;
Tx_En_Buf <= Tx_En;
--END IF;
END IF;
END PROCESS;
-- Tx_ FSM
PROCESS(Rst,Clk)
VARIABLE Pari: STD_LOGIC;
BEGIN
IF Rst=Bit_Valid THEN
    Tx_reg <= (OTHERS=> Bit_Valid);
    Txbitcnt <= 0;
    Txfsm <= Idle;
    Txbusy <= Bit_Invalid;
    Regdin <= (OTHERS=> Bit_Invalid);
          Star_Clk<=Bit_Invalid;
          Cnt<=0;
  -- IF (Clk_Work="011" ) THEN
  IF (Tx_En_Buf=Bit_Invalid) AND (Tx_En = Bit_Valid) THEN
      Tx_Data_Buf<=Tx_Data_Buf((Tx_D_Width+Tx_D_Width-1) DOWNTO Tx_D_Width) & Din;
     ELSIF (Tx_En_Buf=Bit_Valid) AND (Tx_En = Bit_Invalid)THEN
         Tx_Data_Buf<=Tx_Data_Buf((Tx_D_Width-1) DOWNTO 0) & Tx_Data_Buf((Tx_D_Width+Tx_D_Width-1) DOWNTO Tx_D_Width);
         Cnt<=Cnt+1;
     ELSE
         Tx_Data_Buf<=Tx_Data_Buf;
     END IF;
  --CASE Txfsm IS
-- WHEN Idle =>
     IF (Txfsm=Idle) THEN
   IF  (Cnt>0) THEN
    Regdin <=Tx_Data_Buf((Tx_D_Width+Tx_D_Width-1) DOWNTO Tx_D_Width);
    Pari:=Din(0);
    Txbusy <= Bit_Valid;
    Txfsm <= Par_Tx;
    Cnt<=Cnt-1;
   ELSE
    Txfsm <= Idle;
    Regdin<=(OTHERS=>Bit_Invalid);
    Pari:=Bit_Invalid;
   END IF;
  --WHEN Par_Tx=>
  ELSIF (Txfsm=Par_Tx) THEN
      FOR i IN 1 TO (Tx_D_Width-1) LOOP
          Pari:=Pari XOR Regdin(i);
      END LOOP;
      Txfsm<=load_tx;
      Star_Clk<=Bit_Valid;
  --WHEN Load_tx =>
  ELSIF (Txfsm=Load_tx) THEN
   --IF Tx_Clk=Bit_Valid THEN
     IF   Tx_Clk_Reg="01" THEN
    Txfsm <= Shift_tx;
    IF (Check_En="En")THEN
    Txbitcnt <= Tx_D_Width+3;
    IF (Check="Even") THEN
           Tx_reg <= Bit_Valid & Pari & Regdin & Bit_Invalid;
       ELSIF (Check="Odd") THEN
           Tx_reg <= Bit_Valid & (NOT Pari) & Regdin & Bit_Invalid;
       END IF;
       ELSE
          Txbitcnt <= Tx_D_Width+2;
          Tx_reg <= Bit_Valid & Bit_Valid & Regdin & Bit_Invalid;
       END IF;
   END IF;
  --WHEN Shift_tx =>
  ELSIF (Txfsm=Shift_tx) THEN
    Txbitcnt <= Txbitcnt-1;
    Tx_reg <= Bit_Valid & Tx_reg(Tx_reg'high DOWNTO 1);
    IF Txbitcnt = 1 THEN
     Txfsm <= Stop_tx;
    END IF;
   END IF;
  --WHEN Stop_tx =>
  ELSIF (Txfsm=Stop_tx) THEN
    Txfsm <= Idle;
-- WHEN OTHERS =>
    ELSE
    Txfsm <= Idle;
  --END CASE;
    END IF;
END IF;
-- END IF;
END PROCESS;
END Arch_Tx_Com;
此帖出自FPGA/CPLD论坛
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
