6097|2
一个号称可以让电力公司倒闭的**发电机(永动机),欧美正掀起一阵diy的高潮。 [复制链接]
2009年8月9日 -在磁场的发电机,基本上是一个自由能发电机。 In other words, it uses magnets and magnetic force to induce perpetual motion.换句话说,它使用磁铁的磁力吸引永动机。 It runs by itself indefinitely without stopping, thus creating completely free electrical energy, which can fully power your home for free.它运行无限期本身不停止,从而创造完全自由的电能,它可以充分的权力,您可以免费回家。 A perpetual motion device refers to a machine that runs perpetually ie indefinitely, and produces a larger amount of energy than it consumes.阿永动机装置是指一台机器上运行,即永远无限期地,并产生更大的能量消耗比它的数额。 Thus, it produces free energy indefinitely and runs by itself without having to need a third-party device or resource to power it.因此,它产生自由能无限期地运行本身,而不必需要一个第三方设备或资源国。
The free energy devices have been suppressed by the corporate world because such devices would allow people to create their own energy for free, which would ultimately shut down the big energy corporations.自由能装置已经被抑制企业世界,因为这种装置将使人们能够创建他们自己的能量是免费的,这将最终关闭大能源公司。
By constructing the magnetic power generator, you will be able to generate completely free electric energy, ie creating energy without needing any source of renewable or non-renewable energy.通过构造磁发电机,您将能够产生电能,完全免费,即无需任何制造可再生和非再生能源的能源。 The generator powers itself and creates energy by itself without requiring solar energy, heat, water, coal or any kind of resource.该发电机的权力本身和自身产生的能源,而不需要太阳能,热,水,煤或任何类型的资源。 This generator powers itself and works indefinitely without stopping, creating a large amount of energy.该发电机的权力本身和工程无限期不停止,造成大量能源。
Here are some of the benefits that a magnetic power generator installation manual has:下面是一个磁好处发电机安装手册部分有:
• It works in every home and requires only a small amount of space •它可以在每个家庭只需要一个很小的空间
• You can eliminate your power bill by 50% or even completely, depending on how you implement the magnetic generator •您可以消除50%,甚至完全你的权力法案,取决于你如何实现磁发电机
• It works in all conditions and can work in extreme hot or cold without any problem •它可以在任何情况下,可以工作在极端高温或低温没有任何问题
• The material needed to build the magnetic generator is cheap and easily accessible anywhere in the world •需要建立的磁发电机的材料是廉价和容易获得在世界任何地方
• The process has been simplified and the steps are easy to follow, so even a complete novice would be able to follow them •这一进程已得到简化和步骤是容易做到,所以即使一个完整的新手就可以跟着他们
• The installation package contains a bonus chapter about the backgrounds and history of this amazing device. •安装包包含一个关于背景和历史的这个惊人的装置奖金的篇章。
The efficiency of a Magnetic power generator:一个磁发电机的效率:
A magnetic power generator can be efficiently used to power your home with almost zero costs on your side.在磁场的发电机可以有效地用于驱动您的几乎为零的成本站在你这一边在家。 Furthermore, the generator is eco-friendly and doesn't produce any harmful byproducts.此外,发电机环保和不产生任何有害的副产品。
Hundreds of successful magnetic power generators have been built around the world, which proves that this technology really works.成功的磁发电机已建成数百名世界各地,这证明这一技术确实有效。 It is predicted that the technology will rapidly spread, and some industry-insiders even predict that the magnetic power generator will be the energy in the future.据预测,这项技术将迅速滋生蔓延,一些业内人士甚至预言,磁发电机将成为未来能源。 These experts estimate, that by 2020 energy companies will start implementing this technology in order to create cheaper and more environment friendly energy.这些专家估计,到2020年,能源公司将开始实施这项技术,以创造更便宜和更环保的能源。 Until that time comes, you can use this technology at a very reasonable set-up cost.直到那个时候,你可以使用一个非常合理的设置,这项技术的成本。
Safe for use:安全使用:
The magnetic power generator is a safe system for use and operates well.磁发电机是一种安全使用制度和运作良好。 It doesn't produce any harmful byproducts or gases, and there isn't any hazard concerning the generator itself.它不产生任何有害的副产品或气体,并没有任何危险,有关发电机本身。 Even if you have young children, they may freely walk in the close vicinity of the generator.即使你有小孩,他们可以自由地走在发电机附近。
The magnetic power generator is also a very eco-friendly solution because it doesn't pollute the environment.磁发电机也是一个非常环保的解决方案,因为它不污染环境。 The generator itself isn't flammable or combustible, so it's completely safe.生成器本身不是易燃或可燃,所以它是完全安全的。
Saving money:节省资金:
The amount you can save by building the magnetic power generator can vary.数额你可以节省建设磁发电机可以有所不同。 If you decide to build the generator as a supplement to your current electrical installation, ie partially power your household, you can easily save anywhere in the range of 30-50%.如果您决定建立作为当前电力装置补充发电机,即部分权力您的家庭,可以轻松地保存在任何地方30-50%之间。 This means that your power bill will reduce by 30-50%.这意味着你的电费将减少30-50%。
If you decide to implement a magnetic power generator on a full-scale, it will independently power your household meaning that you won't have to pay anything to the power company.如果您决定实施全面磁场的发电机,它将独立电源给您的家庭意味着你将不必支付任何费用的电力公司。 The magnetic power generator will work by itself perpetually and generate 100% free electric energy.磁发电机将永远本身并产生100%的自由电能。
此帖出自电源技术论坛
看来是有人在宏观尺度上对能量守恒提出了挑战啊。。。。。  详情 回复 发表于 2010-1-11 22:24
77
永动机 瞎扯吧就,中学就选过说永动机是不可能的
此帖出自电源技术论坛
1780
此帖出自电源技术论坛
个人签名只有求知欲,没有求偶欲的人是植物,只有求偶欲,没有求知欲的人叫动物,既没求知欲,又没求偶欲的人是矿物。
