5082|0
81
RockBox on mini2440 [复制链接]
My Mini2440 board just arrived.
I did copy the file rockbox.mini2440 (the Rockbox firmware which I did build before) to .rockbox folder on SD Card.
After inserted the SD Card and turned power on, and waited a few seconds, I had this image on LCD:
I have also been looking into creating a disk interface for the Mini2440, to allow 2.5" disks to be used.
Now that I have the Mini2440 playing music from the SDCard memory, it's time to think in a way to use it - I would like to use it as a home Rockbox audio player ;-)
Now I just have the board with me but I need to put it inside a box.
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
