2906|3
105
MS2106芯片CVBS/S-Video转USB [复制链接]
MS2106 宏晶微电子
支持CVBS转USB2.0
支持分辨率如下:
1. MJPEG模式:720×480@25Hz/20Hz/15Hz/10Hz
640×480@25Hz/20Hz/15Hz/10Hz
480×320@25Hz
2. YUV422模式:480×320@25Hz
遵循UVC/UAC协议
应用:倒车后拉线材(车机)、可视门铃机、无线图传、内窥镜手持设备
陈小姐-18925229071  QQ-3001603283
105
需要芯片资料及技术支持联系陈S-18925229071 Q-3001603283
合肥宏晶微电子科技股份有限公司
1.MS9282:  VGA/YPbPr转HDMI/DVI(Bypass)
2.MS9288A: VGA/WII转HDMI(Embedded MCU and Audio module)
3.MS1830:  VGA转AV/SV/VGA(scaler,Embedded SDRAM,OSD)
4.MS1835:   HDMI/VGA转AV/SV/VGA(Embedded MCU)
5.MS1850: AV转VGA/HDMI(scaler,OSD,Support VGA input for POP model)
6.MS1858S:  AV/SV-->HDMI(Embedded MCU)
7.MS2100: AV or S-Video转USB(only YUV mode)
8.MS2106: AV or S-Video转USB(both YUV and MJPEG mode)
9.MS7024: TV Encoder(Support AV and SV output, Support NTSC/PAL)
10.MS1820: VGA<-->HDMI(Scaler) // TTL<-->VGA // AV/HDMI<-->YPbPr(scaler,OSD) // BT656/1120-->VGA/HDMI(scaler,OSD) // ALL-->HDMI(scaler)
105
105
