7870|0
1782
至上芯片
IPC标准 [复制链接]
IPC-TR-470
Thermal Characteristics of Multilayer Interconnection Boards (多层互连板的热特性)
1/74 (orig. pub.)
IPC-TR-474
An Overview of Discrete Wiring Techniques (分立线路综观)
3/79 (orig. pub.) Reprint 1984
IPC-TR-476
How to Avoid Metallic Growth Problems on Electronic Hardware (如何避免电子硬件的合金化生长)
9/77 (orig. pub.) A 6/84
IPC-TR-480 (作废)
Results of Multilayer Test Program Round Robin IV Phase I
9/75 (orig. pub.)
IPC-TR-481
Results of Multilayer Test Program Round Robin V (多层V循环测试程序的结果)
4/81 (orig. pub.)
IPC-TR-483
Dimensional Stability Testing of Thin Laminates - Report on Phase I International Round Robin Test Program (薄层压板尺寸稳定性测试 )
4/84 (orig. pub.) 10/87 Addendums Revised 3/91
IPC-TR-484
Results of IPC Cooper Foil Ductility Round Robin Study (IPC Cooper 箔延展性研究联合报告)
4/86 (orig. pub.)
IPC-TR-485
Results of Cooper Foil Rupture Strength Test Round Robin Study (Cooper 箔断裂强度研究联合报告)
3/85 (orig. pub.)
IPC-TR-549
Measles in Printed Wiring Boards (印制板内的粉点)
11/73 (orig. pub.)
IPC-TR-551
Quality Assessment of Printed Boards Used for Mounting and Interconnecting Electronic Components (电子元件安装互连印制板的质量评定)
7/93 (orig. pub.)
IPC-DR-570
General Specification for 1/8 Inch Diameter Shank Carbide Drills for Printed Boards (1/8英寸印制板硬质合金钻头总技术规范)
1/79 (orig. pub.) A 4/84
IPC-DR-572
Drilling Guidelines for Printed Boards (印制板钻孔指南)
4/88 (orig. pub.)
IPC-TR-576(已作废)
Additive Process Evaluation
9/77 (orig. pub.)
IPC-TR-578
Leading Edge Manufacturing Technology Report - Resulting of a Round Robin Study on Minimum Conductor Width and Plated-Through Holes in Rigid, Bare Copper, Double-Sided Printed Wiring Boards (前沿制造技术报告---- )
9/84 (orig. pub.)
IPC-TR-579
Round Robin Reliability Evaluation of Small Diameter Plated Through Holes in Printed Wiring Boards (印制板小孔金属化可靠性评估联合报告)
9/88 (orig. pub.)
IPC-TR-580
Cleaning and Cleanliness Test Program Phase 1 Test Results (清洗和洁净度测试程序第1阶段测试结果)
10/89 (orig. pub.)
IPC-TR-581
IPC Phase 3 Controlled Atmosphere Soldering Study IPC Phase 3 可控气氛焊接研究)
8/94 (orig. pub.)
IPC-TR-582
IPC Phase 3 No-Clean Flux Study (IPC Phase 3免洗助焊剂研究)
11/94 (orig pub.)
IPC-A-600
Acceptability of Printed Boards (印制 板可接收条件)
orig pub. '64 A '70 B '74 C '78 D '89 E 8/95 F 11/99
IPC-QE-605A
Printed Board Quality Evaluation Handbook (印制板质量评定手册)
Revision A: 2/99
IPC-SS-605
Printed Board Quality Evaluation Slide Set (印制板质量评定,幻灯片)
IPC-A-610
Acceptability of Electronic Assemblies
(电子组装的可接收条件)
8/83 (orig. pub.) 2nd printing 1/86 3rd printing 5/88 A 3/90 B 12/94 Amendment 1/96 Revision C: 1/00
IPC-QE-615
Assembly Quality Evaluation Handbook (组装质量评定手册)
3/93 (orig. pub.)
IPC-SS-615
Assembly Quality Evaluation Slide Set (组装质量评定,幻灯片)
3/93 (orig. pub.) Revision A: 2/99
IPC-AI-640 (已作废)
User's Guidelines for Automated Inspection of Unpopulated Thick Film Hybrid Substrates
1/87 (orig. pub.)
IPC-AI-641
User's Guidelines for Automated Solder Joint Inspection (自动焊点检查用户指南)
1/87 (orig. pub.)
IPC-AI-642
User's Guidelines for Automated Inspection of Artwork, Interlayers, and Unpopulated PWB's (照相底图,内层和PCB裸板自动检查用户指南)
10/88 (orig. pub.)
IPC-OI-645
Standard for Visual Optical Inspection Aids (光学检查目测标准)
10/93 (orig. pub.)
IPC-TM-650
Test Methods Manual (测试方法手册)
Updated per test method
IPC-ET-652
Guidelines and Requirements for Electrical Testing of Unpopulated Printed Boards (PCB裸板电气测试要求和导则)
10/90 (orig. pub.)
IPC-QL-653
Qualification of Facilities that Inspect/Test Printed Boards, Components, and Material (检查/测试印制板,元件和材料的设备鉴定)
8/88 (orig. pub.) A 11/97
IPC-MI-660
Incoming Inspection of Raw Materials Manual (原材料来料检查手册)
2/84 (orig. pub.)
IPC-R-700C IPC-7711/ 7721替代
Suggested Guidelines for Modification, Rework and Repair of Printed Boards and Assemblies
9/67 (orig. pub.) A 12/71 B 9/77 C 1/88
IPC-TA-720
Technology Assessment Handbook on Laminates (层压板技术评估手册)
IPC-TA-721
Technology Assessment Handbook on Multilayer Boards (多层板技术评估手册)
IPC-TA-722
Technology Assessment of Soldering (焊接技术评估)
IPC-TA-723
Technology Assessment Handbook on Surface Mounting (表面组装技术评估手册)
IPC-TA-724
Technology Assessment Series on Cleanrooms (净化间技术评估)
4/98
IPC-PE-740
Troubleshooting Guide for Printed Board Manufacture and Assembly (印制板制造及组装故障修理指南)
1/85 (orig pub.)
A 12/97
IPC-CM-770
Printed Board Component Mounting (印制板元件安装)
9/68 (orig. pub.) A 3/76 B 10/80 C 1/87 D 1/96
IPC-SM-780
Component Packaging and Interconnecting with Emphasis on Surface Mounting (片式元件SMC的封装和互连)
3/88 (orig. pub.)
IPC-SM-782
Surface Mount Design and Land Pattern Standard (表面组装设计和焊盘图形标准)
3/87 (orig. pub.) 9/89 A 8/93 Amendment 1 10/96
IPC-EM-782
Surface Mount Design and Land Pattern Spreadsheet (表面组装设计和焊盘图形电子表格)
9/94 (orig. pub.) Addendum 12/95
IPC-SM-784
Guidelines for Chip-on-Board Technology Implementation (COB技术应用指南)
11/90 (orig. pub.)
IPC-SM-785
Guidelines for Accelerated Reliability Test of Surface Mount Solder Attachments (表面组装焊接可靠性加速试验指南)
11/92 (orig. pub.)
IPC-SM-786已被 J-STD-020替代
Procedures for Characterizing and Handling of Moisture/ Reflow Sensitive ICs
12/90 (orig. pub.) A 1/95
IPC-MC-790
Guidelines for Multichip Module Technology Utilization (多芯片模块技术应用指南)
8/92 (orig. pub.)
IPC-S-804 J-STD-003替代
Solderability Test Methods for Printed Wiring Boards
1/82 (orig. pub.) A 1/87
IPC-S-805 J-STD-002替代
Solderability Tests for Component Leads and Terminations
1/85 (orig. pub.)
IPC-MS-810
Guidelines for High Volume Microsection (显微切面指南)
10/93 (orig. pub.)
IPC-S-815 J-STD-001替代
General Requirements for Soldering Electronic Interconnections (已废除,J-STD-001替代)
11/77 (orig. pub.) A 6/81 B 12/87
IPC-S-816
SMT Process Guideline and Checklist ( SMT工艺指南和检查表)
7/93 (orig. pub.)
IPC-SM-817
General Requirements for Dielectric Surface Mounting Adhesives (绝缘性表面组装胶粘剂通用规范)
11/89 (orig. pub.)
IPC-SF-818 J-STD-004替代
General Requirement for Electronic Soldering Fluxes (用于电子组件焊接的助焊剂通用技术要求)
2/88 (orig. pub.) 12/91
IPC-SP-819 J-STD-005替代
General Requirements and Test Methods for Electronic Grade Solder Paste
10/88 (orig. pub.)
IPC-AJ-820
Assembly and Joining Manual (组装和连接手册)
8/96 (orig. pub.)
IPC-CA-821
General Requirements for Thermally Conductive Adhesives (热导胶粘剂通用技术要求)
1/95 (orig. pub.)
IPC-CC-830
Qualification and Performance of Electronic Insulating Compound for Printed Board Assemblies (印制板组装电绝缘材料的鉴定和性能)
1/84 (orig. pub.) 4/90 Reaffirmed A 10/98
IPC-SM-839
Pre and Post Solder Mask Application Cleaning Guidelines (焊接前,后阻焊膜的清洗指南)
4/90 (orig. pub.)
IPC-SM-840
Qualification and Performance of Permanent Polymer Coating (Solder Mask) for Printed Boards (印制板阻焊膜的鉴定和性能)
11/77 (orig. pub.) A 7/83 B 5/88 C 1/96
IPC-H-855 (己作废)
Hybrid Microcircuit Design Guide
10/82 (orig. pub.)
IPC-D-859
Design Standard for Thick Film Multilayer Hybrid Circuits (厚膜多层混合电路设计标准)
12/89 (orig. pub.)
IPC-HM-860
Specification for Multilayer Hybrid Circuits (多层厚膜电路技术规范)
1/87 (orig. pub.)
IPC-TF-870
Qualification and Performance of Polymer Thick Film Printed Boards (聚合物厚膜印制板的鉴定和性能)
11/89 (orig. pub.)
IPC-D-949IPC-D-275替代
Design Standard for Rigid Multilayer Printed Boards
1/87 (orig. pub.)
IPC-ML-950 IPC-RB-276替代
Performance Specification for Rigid Multilayer Printed Boards
1/66 (orig. pub.) A 9/70 B 12/77 C 11/86
IPC-ML-960
Qualification and Performance Specification for Mass Laminated Panels for Multilayer Printed Boards (多层印制板预制内层敷箔板的鉴定和性能规范)
7/94 (orig. pub.)
IPC-ML-975 IPC-D-325替代
End Product Documentation Specification for Multilayer Printed Wiring Boards
9/69 (orig. pub.)
IPC-ML-990 (作废)
Performance Specification for Flexible Multilayer Wiring
9/72 (orig. pub.)
IPC-1402/IPC-H-855
Hybrid Microcircuit Design Guide (混合微波电路设计指南)
10/82 (orig. pub.)
IPC-1710
OEM Standard for Printed Board Manufacturers' Qualification Profile (MQP印制板OEM制造商资格鉴定一览表)
2/94 (orig. pub.) 12/97 updated
IPC-1720
Assembly Qualification Profile (AQP印制板组装制造商资格鉴定一览表)
7/96 (orig. pub.)
IPC-1730
Laminator Qualification Profile (LQP) (层压板制造商资格鉴定一览表)
1/98
IPC-2141
Controlled Impedance Circuit Boards and High Speed Logic Design (阻抗调制电路板和高速逻辑电路设计)
4/96 (orig. pub.)
IPC-2221 代替 IPC-D-275
Generic Standard on Printed Board Design (印制板设计通用标准)
2/98(orig. pub.)
IPC-2222 代替 IPC-D-275
Sectional Design Standard for Rigid Organic Printed Boards (刚性有机印制板设计标准)
2/98(orig. pub.)
IPC-2223
Sectional Design Standard for Flexible Printed Boards (柔性印制板设计标准)
11/98
IPC-3406
Guidelines for Electrically Conductive Surface Mount Adhesives (表面组装导电胶导则)
7/96 (orig. pub.)
IPC-3408
General Requirements for Anistropically Conductive Adhesive Films (各向异性导电胶粘剂通用技术要求)
11/96 (orig.pub.)
IPC-4101 代替 IPC-L-108/109 IPC-L-112/115
Specification for Base Materials for Rigid and Multilayer Boards (刚性及多层印制板基材特性规范)
12/97 (orig. pub.)*
IPC-4110
Specification and Characterization Methods for Nonwoven Cellulose Based Paper for Printed Boards (非织物纤维纸印制板的特性和规格)
8/98*
IPC-4130
Specification and Characterization Methods for Nonwoven "E" Glass Mat (非织物‘E’玻璃垫规范)
9/98*
IPC-6011
Generic Performance Specification for Printed Boards (印制板通用性能规范)
7/96 (orig. pub.)*
IPC-6012
Qualification and Performance Specification for Rigid Printed Boards (刚性印制板的鉴定与性能规范)
7/96 (orig. pub.) A 10/99
IPC-6013
Qualification and Performance Specification for Flexible Printed Boards (柔性印制板的鉴定与性能规范)
11/98
IPC-6015
Qualification and Performance Specification for Organic Multichip Module (MCM-L) Mounting and Interconnecting Structures (有机多芯片模块(MCM-L)组装及互连结构的鉴定和性能规范)
2/98 (orig. pub.)
IPC-6018
Microwave End Product Board Inspection and Test (微波产品电路板的检查和测试)
1/98(orig. pub.)
IPC/JPCA-6202
Performace Guide Manual for Single- and Double-Sided Flexible Printed Wiring Boards (单、双面柔性印制电路板性能指导手册)
2/99
IPC-7711 代替 IPC-R-700C
Rework of Electronic Assemblies (电子组件的返修)
4/98 (orig. pub.)
IPC-7721 代替 IPC-R-700C
Repair and Modification of Printed Boards and Electronic Assemblies (印制板和电子组件的修理和调整)
4/98 (orig. pub.)
IPC-9191代替IPC-PC-90
General Guideline for implementation of Statistical Process Control (SPC) (SPC实施通则)
11/99 (orig.pub)
IPC-9201
Surface Insulation Resistance Handbook (表面绝缘电阻手册)
7/96 (orig. pub.)
IPC-9501
PWB Assembly Process Simulation for Evaluation of Electronic Components (电子元件组装工艺仿真的评价)
7/95 (orig. pub.) Revision A: In process
IPC-9504
Assembly Process Simulation for Evaluation of Non-IC Components (IC器件组装工艺仿真的评价)
6/98
IPC协会<|||>
IPC协会<|||>
2004-11-6
此帖出自模拟电子论坛
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
