9263|17
114
3382
最新的MSP430普通IO模拟IIC程序! [复制链接]
  1. #include
  2. #include
  3. #include
  4. #include
  5. //------------------------------------------
  6. #define IicWpDirOut P6DIR |= BIT5
  7. #define IicWpLow P6OUT &=~ BIT5
  8. #define IicWpHig P6OUT |= BIT5
  9. #define IicSclDirOut P6DIR |= BIT6
  10. #define IicSclLow P6OUT &=~ BIT6
  11. #define IicSclHig P6OUT |= BIT6
  12. #define IicSdaDirOut P6OUT &= ~BIT7
  13. #define IicSdaLow P6DIR |= BIT7
  14. #define IicSdaHig P6DIR &=~ BIT7
  15. #define IicSdaInSt P6IN & BIT7
  16. bool AckErr;
  17. //------------------------------ *** - 时间延时 - *** ------------------------------//
  18. void Delay(unsigned int count)
  19. {
  20. unsigned int i;
  21. _NOP();
  22. _NOP();
  23. for(i=count; i>0; i--);
  24. }
  25. void IIcDelay(void)
  26. {
  27. _NOP();
  28. }
  29. //-----***-IIC初始化-***-----//
  30. void IicInit(void)
  31. {
  32. IicWpDirOut;
  33. IicSdaDirOut;
  34. IicSclDirOut;
  35. IicWpHig;
  36. IicSdaHig;
  37. IicSclHig;
  38. }
  39. //-----***-IIC启示-***-----//
  40. void IicStart(void)
  41. {
  42. IicSdaHig;//IicSda=1;
  43. IIcDelay();
  44. IicSclHig;//IicScl=1;
  45. IIcDelay();
  46. IicSdaLow;//IicSda=0;
  47. IIcDelay();
  48. IicSclLow;//IicScl=0;
  49. IIcDelay();
  50. }
  51. //-----***-IIC停止-***-----//
  52. void IicStop(void)
  53. {
  54. IicSdaLow;//IicSda=0;
  55. IIcDelay();
  56. IicSclHig;//IicScl=1;
  57. IIcDelay();
  58. IicSdaHig;//IicSda=1;
  59. IIcDelay();
  60. }
  61. //-----***-IIC应答-***-----//
  62. void SendAcknowledge(bool ack)
  63. {
  64. IicSdaDirOut;
  65. if(ack)//IicSda=ack;
  66. {
  67. IicSdaHig;
  68. }
  69. else
  70. {
  71. IicSdaLow;
  72. }
  73. IIcDelay();
  74. IicSclHig;//IicScl=1;
  75. IIcDelay();
  76. IicSclLow;//IicScl=0;
  77. IIcDelay();
  78. }
  79. //-----***-从slave端读取一个数据-***-----//
  80. unsigned char IicReceiveByte(void)
  81. {
  82. unsigned char i;
  83. unsigned char bytedata=0;
  84. IicSdaDirOut;
  85. IicSdaHig;//IicSda=1;
  86. for(i=0;i<8;i++) { IicSclHig;//IicScl=1; IIcDelay(); bytedata<<=1; if(IicSdaInSt) { bytedata |=0x01; } else { bytedata &=0xfe; } IicSclLow;//IicScl=0; IIcDelay(); } IicSdaDirOut; return bytedata; } //-----***-传送一个 Byte 数据到 slave-***-----// void IicSentByte(unsigned char DataByte) { unsigned char i; for(i=0;i<8;i++) { if(DataByte & 0x80) { IicSdaHig;//IicSda=1; } else { IicSdaLow;//IicSda=0; } DataByte <<=1; IIcDelay(); IicSclHig;//IicScl=1; IIcDelay(); IicSclLow;//IicScl=0; IIcDelay(); } IicSdaHig;//IicSda=1;-----Y------D---IicSdaDirIn IIcDelay(); IicSclHig;//IicScl=1; IIcDelay(); IicSclLow;//IicScl=0; IIcDelay(); } //-----***-无扇区读---多字节-***-----// //读取指定器件无扇区指定地址多字节数据到指定地址 //Device=器件地址---单字节 //DataAdd=字节地址---单字节 void IicMuchByteRead(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend) { unsigned char i; _DINT(); WDT(); IicInit(); IicStart(); IicSentByte(0xa0); IicSentByte(DataAdd); IicStart(); IicSentByte(0xa1); for(i=DataLend-1;i>0;i--)
  87. {
  88. *DataDptr=IicReceiveByte();
  89. DataDptr++;
  90. SendAcknowledge(0);
  91. }
  92. *DataDptr=IicReceiveByte();
  93. SendAcknowledge(1);
  94. IicStop();
  95. WDT();
  96. Delay(500);
  97. _EINT();
  98. }
  99. //-----***-无扇区写---多字节-***-----//
  100. //写入指定器件无扇区指定地址中的多字节数据
  101. //Device=器件地址---单字节
  102. //DataAdd=字节地址---双字节
  103. //DataByte=被存放数据的地址
  104. //DataLend=被存放数据的长度
  105. void IicMuchByteWrite(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
  106. {
  107. unsigned char i;
  108. _DINT();
  109. WDT();
  110. IicInit();
  111. IicWpLow;
  112. IicStart();
  113. IicSentByte(0xa0);
  114. IicSentByte(DataAdd);
  115. for(i=DataLend;i>0;i--)
  116. {
  117. IicSentByte(*DataDptr);
  118. DataDptr++;
  119. }
  120. IicStop();
  121. WDT();
  122. Delay(3500);
  123. IicWpHig;
  124. _EINT();
  125. }
  126. //---特别说明
  127. //---利用430芯片来模拟IIC,是不能够把SDA设置为输出模式而是
  128. //---设置为输入,然后利用方向控制器来输出高或者低
  129. //---如下:
  130. #define IicSdaDirOut P6OUT &= ~BIT7
  131. #define IicSdaLow P6DIR |= BIT7
  132. #define IicSdaHig P6DIR &=~ BIT7
  133. #define IicSdaInSt P6IN & BIT7
复制代码
收藏!谢谢楼主!  详情 回复 发表于 2015-8-2 14:20
赞赏
查看全部赞赏
185
还没有用到过,先收藏了,谢谢楼主
个人签名加油学习,努力提高
谢谢楼主分享
谢谢楼主分享,还没有用到过,先收藏了,谢谢楼主
谢谢楼主分享,先收藏了,谢谢楼主
5015
裸片初长成(初级)
现在贴代码好漂亮啊,是新功能吗?
谢了,收下先
回复 楼主 空气 的帖子
正好做这块,收藏试试,
1729
不错,谢谢楼主了!
141
收藏了,谢谢楼主
先mark一下,等会慢慢看。。
楼主辛苦,感谢分享……
48
能用吗?
确定这个程序能用吗?
这个必须顶,,,
这个必须顶,,,这个必须顶,,,
48
这么多人MARK了,有人试过能用吗?
写的很工整 啊,这两天试一试。
553
好资料
收藏!谢谢楼主!
