2624|3
105
LT8619C-Receiver-HDMI to RGB/LVDS [复制链接]
需要芯片资料及技术支持联系陈S-18925229071 Q-3001603283
1. Description
The Lontium’s LT8619C is a high performance HDMI/Dual-mode DP receiver chip based on ClearEdge Technology, compliant with the HDMI 1.4 specification. The TTL output can support RGB, BT656, BT1120 and the output resolution can support up to 4Kx2K@30Hz resolution.
For easy implement of a multi-media system, LT8619C supports 8-channel high quality I2S audio or SPDIF audio output.
2. Features
• HDMI/Dual-Mode DP Input
• Single/Dual-Port LVDS Transmitter
• TTL Output
• Video and Audio
• Miscellaneous
3. Applications
• Car Entertainment
• TV
• Monitor
• Pico Projector
• Smart Projector
• Etc.
105
RK的盒子BOM里的标配芯片
105
360全景方案也在批量使用哦
105
成熟稳定的方案
