1745|0
6882
TMS320F28335项目开发记录7_28335之时钟 [复制链接]
下面是InitSysCtrl函数中调用的InitPll函数进行时钟设置:
// This function initializes the PLLCR register.
void InitPll(Uint16 val, Uint16 divsel)
   // Make sure the PLL is not running in limp mode
   if (SysCtrlRegs.PLLSTS.bit.MCLKSTS != 0)
      // Missing external clock has been detected
      // Replace this line with a call to an appropriate
      // SystemShutdown(); function.
      asm("        ESTOP0");
   // DIVSEL MUST be 0 before PLLCR can be changed from
   // 0x0000. It is set to 0 by an external reset XRSn
   // This puts us in 1/4
   if (SysCtrlRegs.PLLSTS.bit.DIVSEL != 0)
       EALLOW;
       SysCtrlRegs.PLLSTS.bit.DIVSEL = 0;
       EDIS;
   // Change the PLLCR
   if (SysCtrlRegs.PLLCR.bit.DIV != val)
      EALLOW;
      // Before setting PLLCR turn off missing clock detect logic
      SysCtrlRegs.PLLSTS.bit.MCLKOFF = 1;
      SysCtrlRegs.PLLCR.bit.DIV = val;
      EDIS;
      // Optional: Wait for PLL to lock.
      // During this time the CPU will switch to OSCCLK/2 until
      // the PLL is stable.  Once the PLL is stable the CPU will
      // switch to the new PLL value.
      // This time-to-lock is monitored by a PLL lock counter.
      // Code is not required to sit and wait for the PLL to lock.
      // However, if the code does anything that is timing critical,
      // and requires the correct clock be locked, then it is best to
      // wait until this switching has completed.
      // Wait for the PLL lock bit to be set.
      // The watchdog should be disabled before this loop, or fed within
      // the loop via ServiceDog().
          // Uncomment to disable the watchdog
      DisableDog();
      while(SysCtrlRegs.PLLSTS.bit.PLLLOCKS != 1)
              // Uncomment to service the watchdog
          // ServiceDog();
      EALLOW;
      SysCtrlRegs.PLLSTS.bit.MCLKOFF = 0;
      EDIS;
    // If switching to 1/2
        if((divsel == 1)||(divsel == 2))
                EALLOW;
            SysCtrlRegs.PLLSTS.bit.DIVSEL = divsel;
            EDIS;
        // If switching to 1/1
        // * First go to 1/2 and let the power settle
        //   The time required will depend on the system, this is only an example
        // * Then switch to 1/1
        if(divsel == 3)
                EALLOW;
            SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;
            DELAY_US(50L);
            SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;
            EDIS;
