2181|0
专为仿真/测试仪器/设备设计的MIL-STD-1553A/B总线控制器芯片 [复制链接]
FBC1502
   - 专为仿真/测试仪器/设备设计的MIL-STD-1553A/B总线控制器芯片
1.遵循MIL-STD-1553A/B标准,支持MIL-STD-1553A/B规定的全部协议;
2.可由软件配置为BC、BM或者RT;
3.寄存器操作同BU6158X完全兼容;
4.内置差错注入逻辑,可注入MIL-HDBK-1553规定的所有差错;
5.标准异步总线接口,支持8位、16位总线宽度;
6.用在1553总线的仿真、测试设备中
FBC1502 - MIL-STD-1553A/B bus controller IC specialized for simulation/test equipment
1.Conform to MIL-STD-1553A/B bus standard, support all the MIL-STD-1553A/B protocols
2.Could be configured as single BC,BM or RT
3.Register operation compatible with BU6158X
4.Built-in error injection logic, could inject all the errors defined by MIL-HDBK-1553
5.Standard parallel memory bus interface, support both 8-bit and 16-bit wide
6.Used in the MIL-STD-1553A/B bus simulation/test area
个人签名http://www.microsis.cn/
