3324|1
WEDC EDI8L32512CXXX [复制链接]
EDI8L32512CXXX
参数特征(FEATURES)
1. 512Kx32 高速静态随机存储器(CMOS High Speed Static RAM)
2. 应用:DSP Memory Solution
􀂄 Motorola DSP96002
􀂄 Analog SHARC DSP
􀂄 Texas Instruments TMS320C3x, TMS320C4x
3.速度(Fast Access Times): 12*, 15, 17, and 20ns
4. TTL Compatible I/O
5.表贴封装(Surface Mount Package)
􀂄 68 Lead PLCC
􀂄 Small Footprint, 0.990 Sq. In.
􀂄 Multiple Ground Pins for Maximum Noise Immunity
6. 电压:Single +5V (±5%) Supply Operation
7. 功耗(Power Dissipation):5W
8. 级别(DEVICE GRADE):
M = Military Screened -55°C to +125°C
I = Industrial -40°C to +85°C
C = Commercial 0°C to +70°C
1239263184.pdf  详情 回复 发表于 2009-7-5 17:03
265
1239263184.pdf
1239263184.pdf
283.35 KB, 下载次数: 7
