5085|9
411
stm32F4想用TIM+DMA+DAC转换,大神帮忙看看程序差哪 [复制链接]
stm32F4想用TIM+DMA+DAC转换,大神帮忙看看程序差哪,示波器显示不出波形
这个是主函数
#include "dac.h"
#include "sys.h"
#include "delay.h"
#include "led.h"
u16 Sine12bit[32] = {
2047, 2447, 2831, 3185, 3498, 3750, 3939, 4056, 4095, 4056,
3939, 3750, 3495, 3185, 2831, 2447, 2047, 1647, 1263, 909,
599, 344, 155, 38, 0, 38, 155, 344, 599, 909, 1263, 1647  };
int main(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  TIM6_Config(5000-1,840-1);
    delay_init(168);
  while (1)
        DAC_DeInit();
        DAC_Ch2_SineWaveConfig();
//        DAC_SetChannel2Data(DAC_Align_12b_R, 100);
//        DAC_SetChannel2Data(DAC_Align_12b_R, 3000);
这个是DAC+TIM+DMA的函数
#include "dac.h"
#include "sys.h"
#include "led.h"
extern u16 Sine12bit[32];
void TIM6_Config(u16 arr, u16 psc)
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = arr;
  TIM_TimeBaseStructure.TIM_Prescaler = psc;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
  TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
  TIM_Cmd(TIM6, ENABLE);
void DAC_Ch2_SineWaveConfig(void)
    DMA_InitTypeDef DMA_InitStructure;
    DAC_InitTypeDef  DAC_InitStructure;
  DMA_DeInit(DMA1_Stream6);
  DMA_InitStructure.DMA_Channel = DMA_Channel_7;
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&DAC->DHR12R2;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&Sine12bit;
  DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  DMA_InitStructure.DMA_BufferSize = 32;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA1_Stream6, &DMA_InitStructure);
    DMA_Cmd(DMA1_Stream6, ENABLE);
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;
//    DAC_InitStructure.DAC_Trigger = DAC_Trigger_None;
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
    DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_LFSRUnmask_Bit0;
  DAC_Init(DAC_Channel_2, &DAC_InitStructure);
  DAC_Cmd(DAC_Channel_2, ENABLE);
  DAC_DMACmd(DAC_Channel_2, ENABLE);
//    DAC_SetChannel2Data(DAC_Align_12b_R,0);
这个是.h文件
#ifndef __dac_H
#define __dac_H
#include "sys.h"
void TIM6_Config(u16 arr, u16 psc);
void DAC_Ch2_SineWaveConfig(void);
#endif
期待大神。。。
DAC0.rar
4.29 MB, 下载次数: 33
DAC+TIM+DMA未成功程序
此帖出自stm32/stm8论坛
AFIO 时钟没有开启   详情 回复 发表于 2019-6-11 11:04
点赞 关注(1)
4005
没必要重复的   DAC_DeInit();
另外有tim就不用dma了有一个就行。
此帖出自stm32/stm8论坛
第一句我理解了,可是第二句没懂。TIM是控制触发时间的,DMA是管传输的,二者没有功能重合的地方啊,为什么只要有一个就行?  详情 回复 发表于 2018-7-25 18:43
411
另外有tim就不用dma了有一个就行。
此帖出自stm32/stm8论坛
dma传输的作用是减少mcu的传输时间占用,你定时器触发下次转换前对上一次的数据进行处理就行了。 不是不可以,是没必要。  详情 回复 发表于 2018-7-26 16:57
9720
24
官方有现成的代码 可以了解下
此帖出自stm32/stm8论坛
嗯,我找找  详情 回复 发表于 2018-7-26 08:39
411
littleshrimp 发表于 2018-7-25 21:50
官方有现成的代码 可以了解下
嗯,我找找
此帖出自stm32/stm8论坛
4005
shijizai 发表于 2018-7-25 18:43
第一句我理解了,可是第二句没懂。TIM是控制触发时间的,DMA是管传输的,二者没有功能重合的地方啊,为什 ...
是可以的,我看错了。DAC可以
此帖出自stm32/stm8论坛
嗯嗯  详情 回复 发表于 2018-7-26 18:36
411
huo_hu 发表于 2018-7-26 16:57
是可以的,我看错了。DAC可以
嗯嗯
此帖出自stm32/stm8论坛
请问问题解决了吗?
此帖出自stm32/stm8论坛
解决了,不过有点久远了,我抽空回想回想,把解决办法发这个帖子上  详情 回复 发表于 2019-5-7 18:38
411
666liuliuliu 发表于 2019-4-23 09:43
请问问题解决了吗?
此帖出自stm32/stm8论坛
21
AFIO 时钟没有开启
此帖出自stm32/stm8论坛
