2809|1
96
web控制led for esp8266 [复制链接]
好久不发帖了,趁感冒发烧无心工作,来一发。
直接奔入主题:
下面是main.py
  1. from machine import Pin
  2. import socket
  3. def webserver():
  4.   global  s ,red_stat,bai_stat,green_stat
  5.   s = socket.socket(socket.AF_INET,socket.SOCK_STREAM)
  6.   s.setsockopt(socket.SOL_SOCKET,socket.SO_REUSEADDR,1)
  7.   s.bind((wlan.ifconfig()[0],80))
  8.   s.listen(1)
  9.   while True:
  10.     conn,addr = s.accept()
  11.     request = conn.recv(1024)
  12.     request = str(request)
  13.     ib = request.find("Val=")
  14.     if ib >0:
  15.       ie = request.find(" ",ib)
  16.       val = request[ib+4:ie]
  17.       if val =="1":
  18.         if red.value()==0:
  19.           red.value(1)
  20.         else:
  21.           red.value(0)
  22.         print("1")
  23.       elif val =="2":
  24.         if bai.value()==0:
  25.           bai.value(1)
  26.         else:
  27.           bai.value(0)
  28.         print("2")
  29.       elif val=="3":
  30.         if green.value()==0:
  31.           green.value(1)
  32.         else:
  33.           green.value(0)
  34.         print("3")
  35.       conn.send(val.encode())
  36.     else:
  37.       with open('index.html',"r") as html:
  38.         conn.sendall(html.read())
  39.     conn.sendall("\r\n")
  40.     conn.close()
  41. def connectWifi(ssid='xxxx',passwd='xxxxx'):
  42.   global wlan
  43.   wlan=network.WLAN(network.STA_IF)
  44.   wlan.active(True)
  45.   wlan.disconnect()
  46.   wlan.connect(ssid,passwd)
  47.   while(wlan.ifconfig()[0]=='0.0.0.0'):
  48.     time.sleep(1)
  49.   return True
  50. try:
  51.   red = Pin(25,Pin.OUT)
  52.   bai = Pin(14,Pin.OUT)
  53.   green = Pin(12,Pin.OUT)
  54.   connectWifi()
  55.   webserver()
  56. except:
  57.   if (s):
  58.     s.close()
  59.     wlan.disconnect()
  60.     wlan.active(False)
复制代码
下面是index.html
  1. <html>
  2. <head>
  3. <title>WebCtrl</title>
  4. <style type="text/css" id="style">
  5.     .b{
  6.         width: 100px;
  7.         height: 100px;
  8.     }
  9. </style>
  10. <script language="javascript">
  11.     function dimSet(evt) {
  12.         var me, he;
  13.         var resp, xmlhttp=new XMLHttpRequest();
  14.         me = evt.target;
  15.         xmlhttp.open("GET","Val=" + me.value,true); xmlhttp.send()
  16.     }
  17. </script>
  18. </head>
  19. <body>
  20.     <h1>LED --- Web Control for Esp8266</h1>
  21.     <div>
  22.         <input class="b" type="button" value="1">
  23.         <input class="b" type="button" value="2">
  24.         <input class="b" type="button" value="3">
  25.         <input class="b" type="button" value="4">
  26.         <input class="b" type="button" value="5">
  27.     </div>
  28. </body>
  29. </html>
复制代码
此内容由EEWORLD论坛网友youxinweizhi原创,如需转载或用于商业用途需征得作者同意并注明出处
查看本帖全部内容,请登录或者注册
感冒了多喝水,注意休息哦~~谢谢楼主的分享~~  详情 回复 发表于 2018-7-20 14:49
点赞 关注(1)
2852
管理员
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
个人签名玩板看这里:
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
