1571|0
6802
CCS5.5.0编译问题之” version of compiler版本不同” [复制链接]
编译警告:
This project was created using a version of compiler that is not currently installed: 6.0.3 [C2000]. Another version of the compiler will be used during build: 6.2.0. Please install the compiler of the required version, or migrate the project to one of the available compiler versions by adjusting project properties
解决方法:
右键工程 à 属性 à General à Compiler version
TI v6.2.0
