2707|1
PIC18 K40系列的串口 发送不出去....求帮助 [复制链接]
5芯积分
之前做过PIC16的串口,PIC18K20的DEMO软件也看过,然后觉得在K40上面应该不会太困难
谁知道,,,第一次使用PIC18F67K40,用USART5模块...
一个普通的测试发送 用示波器测量没有任何波形,但是while(!TXSTA5bits.TRMT); 在debug却可以通
过......请各位帮帮忙 给点意见...... 硬件上IO口除了上拉电阻没有接任何其他东西.
感谢各位了!!!!!!!!!!!!
// CONFIG1L
#pragma config FEXTOSC = OFF    // External Oscillator mode Selection bits (Oscillator not enabled)
#pragma config RSTOSC = HFINTOSC_64MHZ// Power-up default value for COSC bits (HFINTOSC with HFFRQ = 64 MHz and CDIV = 1:1)
// CONFIG1H
#pragma config CLKOUTEN = OFF   // Clock Out Enable bit (CLKOUT function is disabled)
#pragma config CSWEN = ON       // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
// CONFIG2L
#pragma config MCLRE = INTMCLR  // Master Clear Enable bit (If LVP = 0, MCLR pin function is port defined function; If LVP =1, RG5 pin fuction is MCLR)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (Power up timer disabled)
#pragma config LPBOREN = OFF    // Low-power BOR enable bit (ULPBOR disabled)
#pragma config BOREN = SBORDIS  // Brown-out Reset Enable bits (Brown-out Reset enabled , SBOREN bit is ignored)
// CONFIG2H
#pragma config BORV = VBOR_2P45 // Brown Out Reset Voltage selection bits (Brown-out Reset Voltage (VBOR) set to 2.45V)
#pragma config ZCD = OFF        // ZCD Disable bit (ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON)
#pragma config PPS1WAY = ON     // PPSLOCK bit One-Way Set Enable bit (PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle)
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config DEBUG = OFF      // Debugger Enable bit (Background debugger disabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Extended Instruction Set and Indexed Addressing Mode disabled)
// CONFIG3L
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = OFF       // WDT operating mode (WDT Disabled)
// CONFIG3H
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT input clock selector (Software Control)
// CONFIG4L
#pragma config WRT0 = OFF       // Write Protection Block 0 (Block 0 (000800-001FFFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection Block 1 (Block 1 (002000-003FFFh) not write-protected)
#pragma config WRT2 = OFF       // Write Protection Block 2 (Block 2 (004000-005FFFh) not write-protected)
#pragma config WRT3 = OFF       // Write Protection Block 3 (Block 3 (006000-007FFFh) not write-protected)
// CONFIG4H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-30000Bh) not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
#pragma config SCANE = ON       // Scanner Enable bit (Scanner module is available for use, SCANMD bit can control the module)
#pragma config LVP = ON         // Low Voltage Programming Enable bit (Low voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored)
// CONFIG5L
#pragma config CP = OFF         // UserNVM Program Memory Code Protection bit (UserNVM code protection disabled)
#pragma config CPD = OFF        // DataNVM Memory Code Protection bit (DataNVM code protection disabled)
// CONFIG5H
// CONFIG6L
#pragma config EBTR0 = OFF      // Table Read Protection Block 0 (Block 0 (000800-001FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection Block 1 (Block 1 (002000-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection Block 2 (Block 2 (004000-005FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection Block 3 (Block 3 (006000-007FFFh) not protected from table reads executed in other blocks)
// CONFIG6H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
void main(void)
    PORT_init();
    Open5USART();
    while(1)
        TX5REG = 0X55;
    return;
void PORT_init(void)
    ANSELE = 0X00;
    PORTE = 0xFF;
    TRISE = 0x00;
void Open5USART(void)
  TRISEbits.TRISE2 = 0;
  TRISEbits.TRISE3 = 1;
  RX5PPS = 0X23;
  TX5PPS = 0X22;
  UART5MD = 0;
  TXSTA5bits.CSRC = 0;
  TXSTA5bits.TX9   = 0;
  TXSTA5bits.TXEN = 1;     // Enable transmitter
  TXSTA5bits.SYNC = 0;
  TXSTA5bits.BRGH = 1;
  RCSTA5bits.RX9  = 0;
  RCSTA5bits.CREN = 0;
  RCSTA5bits.SPEN  = 1;  // Enable receiver
  BAUDCON5bits.BRG16 = 1;
  BAUDCON5bits.SCKP  = 0;
  SP5BRG = 1665; // HFINTOSC with HFFRQ = 64 MHz       9600
  PIE4bits.RC5IE   = 0;  // Interrupt on receipt
  PIE4bits.TX5IE   = 0;  // Interrupt on transmission
其他COM口可以吗  详情 回复 发表于 2018-5-30 16:49
3241
其他COM口可以吗
个人签名为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
