4570|6
1098
至上芯片
USB_M8_RGBLED彩灯 [复制链接]
用M8控制RGBLED测试了一下,效果不错。并做了一个上位机软件,通过USB控制,现将资料整理上传与君共享!
usb_彩灯.rar
1.52 MB, 下载次数: 146
此帖出自单片机论坛
有兴趣,请问软件用什么语言写的 ?  详情 回复 发表于 2008-7-17 09:38
1098
至上芯片
USB_M8_RGBLED彩灯
调光效果
此帖出自单片机论坛
1098
至上芯片
USB_M8_RGBLED彩灯
为查阅直观,下位机主要控制源码如下:
* rgbCtrl.h
* Copyright XiaoCui' Products
* DESCRIPTION:
* modification history
* 01a, 01jan2008, cuiqingwei written
#include
#include
#include
#include
#include "usbdrv.h"
Explanation of the HSV color space:
H: Hue        - 色调(如红,蓝,黄,绿...)
S: Saturation - 饱和度
V: Value      - 亮度
Scaling of the HSV values:
H: [0-255] 0 = red,   42  = yellow, 85 = green, 128 = turquoise, 171 = blue, 214 = purple
S: [0-255] 0 = white, 255 = pure colors
V: [0-255] 0 = off,   255 = maximum brightness
typedef struct {
        unsigned char r;
        unsigned char g;
        unsigned char b;
} RGB;
#define        Ledport         PORTD                // RGB Led Port
#define DDR_Ledport        DDRD
#define R_PIN           5                // R Output
#define G_PIN           6                // G
#define B_PIN           7                // B
/* 函数声名 */
void init(void);
void hsv_to_rgb (unsigned char h, unsigned char s, unsigned char v, RGB * out);
/* 全局变量 */
RGB lamp = {0,0,0};
unsigned char type,H,S,V;
// Init
void init(void)
          PORTD = 0;
         PORTB = 0;                // no pullups on USB and ISP pins
          DDRD = ~(1 << 2);        // all outputs except PD2 = INT0
          DDRB = 0;                   // all USB and ISP pins inputs
        DDR_Ledport = (1<
        TCCR0 = 1;
        TIMSK = (1<
uchar usbFunctionSetup(uchar data[8])
        usbRequest_t *rq = (void *)data;
    if( rq->bRequest )
                type = 1;
                H = rq->wValue.bytes[0];
                S = rq->wValue.bytes[1];
                V = rq->wValue.bytes[2];
        else
                    type = 0;
                lamp.r = rq->wValue.bytes[0];
                lamp.g = rq->wValue.bytes[1];
                lamp.b = rq->wValue.bytes[2];
          //computeOutputStatus();
    return 0;
// Main
此帖出自单片机论坛
1098
至上芯片
USB_M8_RGBLED彩灯
int main(void)
        cli();
        init();
         usbInit();
           sei();
           H = 180;
        S = 255;
        V = 355;
        type = 1;
        for(;;)
                usbPoll();
                if ( type )
                        type = 0;
                        hsv_to_rgb(H,S,V,&lamp);
        return 0;
// Converts HSV to RGB
        unsigned char r=0,g=0,b=0, i, f;
        unsigned int p, q, t;
        if( s == 0 ) {
                r = g = b = v;
        else
        {        i=h/43;
                f=h%43;
                p = (v * (255 - s))/256;
                q = (v * ((10710 - (s * f))/42))/256;
                t = (v * ((10710 - (s * (42 - f)))/42))/256;
                switch( i )
                {        case 0:
                                r = v; g = t; b = p; break;
                        case 1:
                                r = q; g = v; b = p; break;
                        case 2:
                                r = p; g = v; b = t; break;
                        case 3:
                                r = p; g = q; b = v; break;
                        case 4:
                                r = t; g = p; b = v; break;
                        case 5:
                                 r = v; g = p; b = q; break;
        out->r=r; out->g=g; out->b=b;
// Timer  0 Interrupt, f/256
SIGNAL (SIG_OVERFLOW0)
        static unsigned char PWM_cnt;
        static unsigned char prescale;
        if(prescale++){
                prescale=0;                // Used to halve the PWM frequency
                return;
        if (PWM_cnt                 Ledport |= (1 << R_PIN);
        else
                Ledport &=~(1 << R_PIN);
        if (PWM_cnt                 Ledport |= (1 << G_PIN);
        else
                Ledport &=~(1 << G_PIN);
        if (PWM_cnt                 Ledport |= (1 << B_PIN);
        else
                Ledport &=~(1 << B_PIN);
        PWM_cnt++;
                                0ooo
                       ooo0     (   )
                        \ (     (_/
                         \_)        By:cuiqingwei [gary]
此帖出自单片机论坛
1098
至上芯片
USB_M8_RGBLED彩灯
调试一角
此帖出自单片机论坛
87
不错 哦
能给点资料我嘛,qwrwrwet@163.com
此帖出自单片机论坛
有兴趣,请问软件用什么语言写的 ?
此帖出自单片机论坛
