2092|0
求解DSP端通过EMIF口读FPGA端数据的一个小函数 [复制链接]
#define  ADDR_NORMAL_DATA     *(volatile Uint32  *)0xA0200014
函数传给形参addr的为RD_ADDR_KEY_0,其宏定义如下:
#define  RD_ADDR_KEY_0    1
int RDNormal(unsigned int addr){
   unsigned int data;
   ADDR_NORMAL_DATA = 0x7FFF & (((addr & 0x7F) << 8) + (0 & 0xFF));
   data = ADDR_NORMAL_DATA;
   data = data & 0xFF;
   return data;
电源解决方案和技术 | DigiKey 应用探索站
