5153|2
22
51FPGA通信..的程序谁能帮我注释一下,,看不懂...跟贴在后面 [复制链接]
//单片机程序:
#include
#include
#include
void outportb(unsigned char port, unsigned char nVal);
unsigned char inportb(unsigned char port);
unsigned char swap(unsigned char nVal);
main()
while(1)
   unsigned char idata temp;
temp = inportb(0);  //读入拨码开关的值
outportb(2,temp ); //传送拨码开码值给cpld
void outportb(unsigned char nPort, unsigned char nVal)
unsigned char xdata *exAddress;
  exAddress=0xff00+nPort;
*exAddress = nVal;
unsigned char inportb(unsigned char nPort)
   unsigned char nVal;
   nVal = *exAddress;
   return nVal;
--作为单片机和CPLD的简单示例,演示如何采用地址数据总线方式和CPLD通讯
--单片机读取拨码开关值,并将其开关状态用写入cpld
--cpld的led显示
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY MCU IS
   PORT (
      rst                     : IN std_logic;
      clk                     : IN std_logic;
--********单片机接口信号********--
      data                    : INOUT std_logic_vector(7 DOWNTO 0);   --数据地址总线,
        --即单片机的P0端口
      mcu_ale                 : IN  std_logic;    -- mcu的ALE 地址锁存信号
      mcu_nrd                 : IN  std_logic;    -- mcu的rd
      mcu_nwr                 : IN  std_logic;    -- mcu的wr
--*******外围控制器件接口*******--
      dial                    : IN  std_logic_vector(7 downto 0);
      ledout                  : OUT std_logic_vector(7 downto 0)
  --    EN                      : buffer std_logic_vector(1 downto 0);
  --    segdata                 : OUT std_logic_vector(7 downto 0)
END MCU;
ARCHITECTURE arch OF MCU IS
attribute clock_buffer  : string;
attribute   clock_buffer  of  mcu_ale :signal is "ibuf";
attribute   clock_buffer  of   mcu_nwr  :signal is "ibuf";
SIGNAL LA: std_logic_vector(1 DOWNTO 0); --低位地址锁存信号
SIGNAL state : std_logic_vector(4 DOWNTO 0);
SIGNAL DIN : std_logic_vector(7 DOWNTO 0);--总线输入
SIGNAL DOUT : std_logic_vector(7 DOWNTO 0);--总线输出
SIGNAL REG2 : std_logic_vector(7 DOWNTO 0);--led灯状态寄存器
BEGIN
process(mcu_ale)
begin
  if(mcu_ale='1')THEN
  LA<=DIN(1 DOWNTO 0);
  END IF;
END PROCESS;
ledout <=reg2;
DOUT<= dial WHEN LA ="00" ELSE
       "11111111";
DIN    <= DATA;
DATA   <= DOUT WHEN mcu_nrd ='0' AND mcu_ale='0' ELSE "ZZZZZZZZ";
READ :PROCESS(mcu_nwr,rst)
      BEGIN
            IF rst='0' THEN
            REG2<="00000000";
            ELSIF mcu_nwr'EVENT AND mcu_nwr='0' THEN
            CASE LA IS  --- Address input
              WHEN "10"=>
                REG2 <= DIN;
              WHEN OTHERS =>
            END CASE;
            END IF;
      END PROCESS READ;
END arch;
//搞不清楚,,单片机的读写过程,,我的理解是从P0读入开关状态,,送往P2口..然后FPGA接收,显示LED,,可是VHDL代码中怎么会有,ALE,WR,RD,这些信号?好象又用串口....
拜托高手指点!!!
跟贴在后面
此帖出自FPGA/CPLD论坛
通过总线和通过IO还有区别的呢  详情 回复 发表于 2008-8-12 15:33
228
HDL程序要配合电路图才能完整地理解
假如从Px口直接读开关,直接控制LED的话,就没FPGA什么事了。 现在这里的代码用了读写等总线控制信号,说明FPGA是通过总线跟CPU连接的,而不是通过I/O口。
此帖出自FPGA/CPLD论坛
22
通过总线和通过IO还有区别的呢
此帖出自FPGA/CPLD论坛
【回帖赢京东卡】说说无线技术那些事儿
即日起—2月28日,参与回帖讨论都有机会赢取【30元京东卡】
