2297|0
42
stm32 串口通讯 程序编译错误 vfscanf [复制链接]
stm32开发板,在使用串口通讯时,编译程序后显示如下错误。
..\USART.axf: Error: L6218E: Undefined symbol __vfscanf_char_file (referred from __0scanf.o).
程序如下
#include "usart.h"
void SZ_STM32_COMInit(void)
          GPIO_InitTypeDef GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
    /* 使能STM32的USART对应GPIO的Clock时钟 */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    /* 初始化STM32的USART的TX管脚,配置为复用功能推挽输出 */
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOA , &GPIO_InitStructure);
    /* 初始化STM32的USART的RX管脚,配置为复用功能输入 */
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        USART_InitStructure.USART_BaudRate = 115200;              //串口的波特率,例如115200 最高达4.5Mbits/s
    USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据字长度(8位或9位)
    USART_InitStructure.USART_StopBits = USART_StopBits_1;      //可配置的停止位-支持1或2个停止位
    USART_InitStructure.USART_Parity = USART_Parity_No;         //无奇偶校验
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无硬件流控制
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //双工模式,使能发送和接收
    /* 根据传入的参数初始化STM32的USART配置 */
    USART_Init(USART1, &USART_InitStructure);
    /* 使能STM32的USART功能模块 */
    USART_Cmd(USART1, ENABLE);
/* 重定义fputc函数 如果使用MicroLIB只需要重定义fputc函数即可 */
int fputc(int ch, FILE *f)
    /* e.g. write a character to the USART */
    USART_SendData(USART1, (uint8_t) ch);
    /* Loop until the end of transmission */
    while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
    return ch;
int fgetc(FILE *fp)
        int ch = 0;
    while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
    ch = (int)USART1->DR & 0xFF;
    putchar(ch); //回显
        return ch;
#include "usart.h"
#include "stm32f10x.h"
int main(void)
        uint8_t Str[80] = {0};
        SZ_STM32_COMInit();         /* 串口初始化 */
        printf("\n\r WWW.ARMJISHU.COM! \n");
    while (1)
                scanf("%s", Str);
                printf("\n\r 输入的字符串是: <%s>\n", Str);
请各位大神指教。
此帖出自stm32/stm8论坛
