2010|0
3836
MSP430G2553时钟及时钟中断 [复制链接]
#include "msp430G2553.h"
//************主函数***************************
void main()
  WDTCTL = WDTPW + WDTHOLD;          // Stop WDT
  BCSCTL1 = CALBC1_1MHZ; //时钟为1M,课设8M、12M和16M
  DCOCTL = CALDCO_1MHZ;  //同上(并同时设置)
  BCSCTL2 |=SELM_1+DIVM_3;//SELM_1时钟源选择,0、1为DCOCLK,
                          //2为XT2CLK/LFXTCLK,3为LFXTCLK
            //DIVM_1,为所选的时钟分频,0不分频,1为2分频,2为4分频,3为8分频
  P1DIR|=0x41; //P1.6和P1.0为输出,控制LED
  P1OUT |=0x01;
  P1OUT &=~0x40;
  TACTL |= TASSEL_2+ID_3+MC_1;
  //TASSEL_x计数器时钟源选择,x=0,外时钟TACLK,1选ACLK,2选SMCLK,3选外部时钟
  // ID_x是分频选择,x=0不分频,1是2分频,2是4分频,3是8分频后(125K)
  // MC_x是计数模式,x=0,停止,1是up到CCR0的值,2是连续到满0xffff,
  //3增减计数,先增到CCR0的值,再减到0
  TACCR0 =25000;  //计到2500,约20ms
  TACCTL0 |= CCIE; // CCR0 interrupt enabled
  _BIS_SR(GIE);              //开总中断
  while(1);
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A(void)
  //TACCTL0&=~ CCIE; //关中断
  static int cc=0;
  cc+=1;
  if(cc==20)  //1s=1000ms=20*50 定时
   P1OUT^=0x41; //P1.6 LED取反
   cc=0;
